DavidMS
Motion failing
Tue Dec 18, 2012 9:59 pm
Has anyone seen problems with Motion failing after a period of time - generally after 6 to 12 hours. I am running on a new 'made in the UK pi with the latest up to date Raspbian, running head less. There are no power supply issues and I have a powered hub. I have it configured to auto switch into tubo mode on demand. I had essentially the same setup running in Sept without problems on an earlier pi, with the only problem that the wifi dropped out a lot [This is now much better].
http://meanderingpi.wordpress.com/
11 Raspberry Pi's and counting....
DavidMS
Re: Motion failing
Wed Dec 19, 2012 6:39 am
sorry forgot this is the error message "[1] v4l2_next: VIDIOC_DQBUF: EIO (s->pframe 3): Input/output error"
akash73
Re: Motion failing
Thu Jan 03, 2013 3:30 pm
Hi, try to read this post:
http://www.raspberrypi.org/phpBB3/viewt ... 8&p=219521
it helped me.
cheers
Andrea
Pi 256 Mb
http://www.akash.it/category/informatica/raspberry-pi/
lingon
Re: Motion failing
Fri Jan 04, 2013 10:26 am
If you search the forums you will find that many people have problems with motion on the Raspberry Pi.
I would guess that this is due to the remaining issues with the USB-driver. I have been able to get motion to run stably by reading the output from mjpeg-streamer as input to motion, as I describe in this post:
http://www.raspberrypi.org/phpBB3/viewt ... 28&t=27186
