dominic03
Can't resize windows or close them by clicking the X after I used the 'Openbox Configuration Manager'
Mon Dec 30, 2019 11:51 pm
I used the 'Openbox Configuration Manager' application to change a few openbox settings, and now I can't resize or move windows or close them with the X, even after reverting the changes! I've had this problem before, and the only way I fixed it was by reinstalling. Do I need to reinstall again?
(The only app responding to drag/resize/close is Chromium)
Raspberry Pi 4B running Raspbian Buster v3.1 (via PINN)
Kingston 32 GB C10 (U1) microSD
Sceptre E225W 22" 75hz 1080p monitor
Flash drive for backups and swap
-or-
pi-top 3 running Raspbian with drivers and pi-topHUB 2.0 / 16GB SanDisk C10 microSD
klricks
Re: Can't resize windows or close them by clicking the X after I used the 'Openbox Configuration Manager'
Tue Dec 31, 2019 12:43 am
This thread may help to restore the config file: https://www.raspberrypi.org/forums/view ... 1&t=245458
dominic03
Tue Dec 31, 2019 2:23 am
That solution fixed the problem, thanks! However, is there any way to change the settings without the described problems occuring?
-or-
scruss
Tue Dec 31, 2019 2:54 am
Yes, you can restore one of the screen defaults (Preferences → Appearance Settings → Defaults: pick one), then
sudo apt update
sudo apt -y full-upgrade
then reboot.
Assuming you're running Buster, this should allow obconf to run without messing everything up
related github issue (now closed): https://github.com/RPi-Distro/raspberry ... /issues/22
