Paolo2710
Raspberry Pi 4 don't boot whit all
Wed Dec 18, 2019 12:16 pm
Hi, I'm Paolo Banci from Italy.
I tried in every way to start my Raspberry Pi 4
Official feeder, 3 different microsd cards.
I tried to fix the corrupted firmware. The LED flashes quickly as shown in the instructions, but then when I insert a sd card with software for raspberry pi4 it does not work.
W. H. Heydt
Re: Raspberry Pi 4 don't boot whit all
Wed Dec 18, 2019 3:31 pm
What version of which OS are you trying to use?
Paolo2710
Wed Dec 18, 2019 5:58 pm
Raspbian buster
Paolo2710
Wed Dec 18, 2019 6:00 pm
Also other programs for raspberry pi 4 are not loaded.
alphanumeric
Wed Dec 18, 2019 7:41 pm
How are you creating your SD cards? What software and what method?.
Paolo2710
Wed Dec 18, 2019 7:43 pm
Balena Etcher
alphanumeric
Wed Dec 18, 2019 7:47 pm
Ok, thats the default way to do it. As a double check you could redownload Buster just in case the first one was corrupted. And use a different Sd card. I do believe with no SD card inserted you should see 4 green status LED flashes, that just repeats over and over. Its what I got with a bad SD card.
Paolo2710
Wed Dec 18, 2019 8:01 pm
is a new sd card....
alphanumeric
Wed Dec 18, 2019 8:06 pm
Although unlikely, it could still be a dud, it happens. Bought from a reputable source? There are lots of fake cards out there.
Paolo2710
Wed Dec 18, 2019 8:20 pm
Sandisk. Buy in any store. Thanks.
alphanumeric
Wed Dec 18, 2019 8:29 pm
SanDisk is what I buy when I can. I had a brand new SanDisk card bought from a reputable retailer that was a dud. Etcher formatted and verified the card but no Pi would boot from it.
https://www.raspberrypi.org/forums/vie ... #p1577463
Paolo2710
Wed Dec 18, 2019 8:32 pm
But from USB ?
alphanumeric
Wed Dec 18, 2019 9:28 pm
The Pi 4B, last time I checked, doesn't yet support booting directly from USB. You still need an SD card to boot from and transfer the system to USB.
Paolo2710
Wed Dec 18, 2019 9:37 pm
I have seen. I hope to find a good microsd. Thanks.
Paolo2710
Sat Dec 21, 2019 10:26 am
I bought a 32 GB Lexar 1000x. Raspebrry starts to load and then the red LED stays on and that's it as always.
rpiMike
Sat Dec 21, 2019 10:33 am
Did you download Raspbian Buster with Desktop from here https://www.raspberrypi.org/downloads/raspbian/ ?
Did you unzip the image - there is no need to unzip when using Etcher and can corrupt the image ?
Do you have a screen connected with an HDMI cable to hdmi port 0 (nearest power connection) as well as mouse and keyboard?
Does anything appear on screen?
Paolo2710
Sat Dec 21, 2019 10:36 am
I tried to connect or not an LCD display, nothing changes. Etcher for software. I insert the microsd card the green LED starts its activity and after 2-3 seconds everything stops.
Paolo2710
Sat Dec 21, 2019 10:38 am
Of course raspbian buster is downloaded from the official link
Paolo2710
Sat Dec 21, 2019 10:53 am
I have two raspberry pi 3b + and have never had a problem. This doesn't want to work at all. 4 different microsd. Software for raspberry pi 4. Nothing.
Paolo2710
Sat Dec 21, 2019 2:37 pm
I found the solution in this video! I could hardly believe it worked, and instead after a month I can finally use it.
https://www.youtube.com/watch?v=JejOz8r45YI
rpiMike
Sat Dec 21, 2019 3:08 pm
So the Pi couldn't recognise your screen correctly.
Setting the following in /boot/config.txt, according to the youtube video, disabled checking of the EDID/display data on both displays:
hdmi_ignore_edid=0xa5000080
hdmi_ignore_edid:1=0xa5000080
https://www.raspberrypi.org/documentati ... t/video.md
Paolo2710
Mon Jan 27, 2020 4:33 pm
I don't know why but it doesn't work again. It starts and I no longer see anything on the monitor.
It was just the worst purchase I could make!
Paolo2710
Sat Feb 01, 2020 4:20 pm
Is there any way to get the raspberry replaced? Because I am not receiving any signal on the monitor. Not even with different monitors.
Sat Feb 01, 2020 4:34 pm
Any warranty is from the place you bought your RPi..
RPi 4B 4GB (SSD Boot)..
Sat Feb 01, 2020 4:58 pm
For any EU citizens there's a statutory 2 year warrnty for defective equipment (NOT for anything you might have destroyed). [That will even count in the UK until 31st Dec while we're in the EU limbo transition period.]
