A lot of users have reported a problem with files become corrupted from over clocking. But I think it can happen even running at stock.
My own experience;
512mb board running openelec xbmc;
To start it was believed that overclocking the gpu was the cause, if I overclocked it by even 1 it would corrupted the ext4 partition first reboot. But if I only overclocked the cpu too 800, it would corrupt the ext4 partition too after a few reboots. But even running at stock it eventually corrupts.
I have used different SD cards so I dont think it is a faulty card.
I have run openelec on a 256mb board with much more aggressive overclocking and never had a single instance of corruption.
Other users have reported boards that were able to overclock quite high and never experienced any corruption are now starting to find every reboot they suffer corruption. Is this because firmware has changed and even more R-Pi's are susceptible to corruption.
I dont understand where the fault lies, is it that some hardware is not very reliable or is the firmware the cause of this issue?
