Sun Dec 08, 2019 3:12 pm
Note that one of the things that got chmod'd was /usr/bin/sudo - you chmod'd it to 777, when it needs to be 47xx (the x's don't really matter) in order to work. That's why sudo doesn't work anymore.
Yes, you need to re-install the OS.
P.S. Actually, you could do the init=/bin/bash trick - this would allow you to boot up into a root shell. From there, you could at least look around and maybe fix /usr/sbin/sudo. But note that everything else on the system is still hosed, so you really do need to just re-install it.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
