Pi 4 B Will not boot, no green LED [Solved]
Posted: Sun Dec 01, 2019 12:27 am
by BrodyStone21
I recently purchased a Raspberry Pi 4 B 4GB model and it came in today, so I plugged in the class 10 micro SD card that came preloaded with NOOBS and nothing showed up, I then tried editing the config.txt and tried to force HDMI, nothing. So I formatted the SD card and tried just installing Rasbian Lite, also didn't work. I then tried installing Rasbian Desktop once again didn't work. I have so far tried two different monitors and one HDTV all with different resolutions. The latest thing I tried was following this video tutorial https://www.youtube.com/watch?v=JYrGoLbiyj8 however when I plug the Pi in after extracting everything and inserting the SD card my LEDs are not flashing. Do I have a dead board if not how do I fix this? If I do have a dead board how do I get a replacement?
Edit: Turns out I was using a fan and inserting it into the wrong GPIO pins, if anyone runs into this issue in the future try unplugging the fan and then booting into your OS.
Re: Pi 4 B Will not boot, no green LED
Posted: Sun Dec 01, 2019 10:09 am
by pcmanbob
HI.
I suggest you go read the boot problem sticky , it has the combined knowledge of most, if not all, of the problems when booting.
https://www.raspberrypi.org/forums/view ... 28&t=58151
look at the last page which is specific to the pi4B
you might also need the info here on recovery
https://www.raspberrypi.org/downloads/
One thing that has not made it to the boot sticky which might affect your pi4B is one user found that the SD card he was using was not making good contact in the SD card slot so he added a little packing to make it a tighter fit and then it worked just fine.
https://www.raspberrypi.org/forums/view ... 8&t=257916
Posted: Wed Dec 04, 2019 6:05 pm
by BrodyStone21
Hello and thank you for the reply, I figured out what the problem was my pi came with a fan and case and I did not correctly install the fan so if I plugged it in before it would boot up it wouldn't boot up at all and then if I rebooted it with it plugged in it wouldn't turn back on. I had to insert the fan into the correct GPO pins. Sorry for being dumb xD thanks for the help though I appreciate it.
Posted: Wed Dec 04, 2019 6:21 pm
by pcmanbob
May be if you had said you were connecting a fan to the gpio, we might have stood a chance of solving the problem.
If you don't give us all the information we are working at a disadvantage and in the dark.
Posted: Wed Dec 04, 2019 6:35 pm
by BrodyStone21
You know, thinking back now, it probably would've been a good idea... I tried at least 5 different installs haha.
Also, this is a little off-topic but do you somehow get notifications here? I just have to go look at my posts and look to see if the number of replies has changed.
Posted: Wed Dec 04, 2019 7:09 pm
by andersdk
There is a small spanner icon you can click on top or botoom of ths reply window - next to the red button.
Click on the small arrow next to the spanner and select subcribe to topic.
You can do this on every topic you want to follow.
Then you get an email to your registered emal address as notification.
This email contains a quick link to the new reply on the topic(s) you subscribed to.
The mail will also have a quick link to UNsubscribe notifications from the topic.
If you subscribe to several recent topics, you will probably get a ton of notifications in your inbox.
Thats how you learn ...
Posted: Wed Dec 04, 2019 8:58 pm
by BrodyStone21
Awesome! Thank you for the help I appreciate it. Also, am I supposed to somehow close a thread when it has been solved?
Posted: Wed Dec 04, 2019 10:18 pm
by davidcoton
... am I supposed to somehow close a thread when it has been solved?
You can close the thread by editing your OP and adding "[Solved]" to the title.
It won't prevent further posts, but should indicate that there is no outstanding issue.
(If you feel it should be locked, report your own post and ask a Moderator to lock it. Not sure what the policy is, threads are normally only locked when they get acrimonious or when necro'ed after some years.)
Re: Pi 4 B Will not boot, no green LED [Solved]
Posted: Wed Dec 04, 2019 10:20 pm
by BrodyStone21
Already did the [Solved] a couple of hours ago because I wasn't sure, but thank you for the response.
