tam94131
Ping RaspPi using Hostname _without_ .local?
Tue Nov 26, 2019 7:08 pm
Hi all,
At a previous location, I had a network of RaspPis happily talking to each other (during REST calls) using the RaspPi's hostname -- but without ".local" -- and all worked fine. I've now moved to a new location (which has a new network) and I can no longer use just the hostname (e.g., "ping some-hostname"). Instead, I have to append a ".local" to the hostname (e.g., "ping some-hostname.local") or use the IP address.
Is there something I'm doing wrong, or was I supposed to be always using ".local". Some of python programs to change if that's the case....
Insight appreciated!
Re: Ping RaspPi using Hostname _without_ .local?
Tue Nov 26, 2019 8:23 pm
If you want that you'll need to hard-code IP addresses in /etc/hosts.
jj_0
Tue Nov 26, 2019 8:43 pm
Add
search .local
to /etc/resolv.conf, or maybe to a new.conf file in e.g.
/usr/lib/systemd/resolved.conf.d/
. More info at https://www.freedesktop.org/software/sy ... .conf.html.
epoch1970
Tue Nov 26, 2019 9:07 pm
Add
search .local
to /etc/resolv.conf
I can't test. Does this work?
According to this I would believe a few extra steps are required.
Not a great idea, anyway.
tam94131
Wed Nov 27, 2019 7:45 pm
@dougie, I'm trying not to have hard-coded IP addresses anywhere which is why I'm using hostname. Of that is not working too well.
@jj_0, I add 'search .local' to the config file and it doesn't seem to anything
I guess it doesn't hurt that any time I refer to RaspPi on the intranet that I suffix the hostname with '.local'. It doesn't hurt but I will have to change a bunch of programs....
