pete051
Broken file manager
Fri Nov 15, 2019 7:53 pm
After running apt-get update, apt-get upgrade the file manager appears when clicked then instantly disappears again, anybody else getting this or even better knows a cure?
DirkS
Re: Broken file manager
Fri Nov 15, 2019 8:06 pm
Assuming you're running standard Raspbian with desktop:
- which version?
- did you reboot after update / upgrade?
- try running 'pcmanfm' in a terminal window. It may give some error messages / warnings, etc. If it does: post the full message here.
Fri Nov 15, 2019 8:25 pm
FTFY. No worries.
pete051
Fri Nov 15, 2019 8:43 pm
Same result no feedback on the terminal
pete051
Fri Nov 15, 2019 8:45 pm
Yes it is Raspbian desktop on a pi 4
PI342
Sat Nov 16, 2019 4:24 am
Trash can't open too.
Please someone help.
dustnbone
Sat Nov 16, 2019 4:29 am
Recent updates include pcmanfm, lxpanel, pipanel and raspberrypi-ui-mods. I haven't updated this Pi yet, so I'll take an image and install them one at a time to try narrow it down.
PI342
Sat Nov 16, 2019 4:56 am
:D I saw the reporting information displaying on terminal when it was upgrading. but I could only know they were successfully upgraded then it prompted me to reboot and choose the appearance's setting. After reboot, the file manager could not use then.
too_uneeq
Sat Nov 16, 2019 11:48 am
Same here. Just set up a new pi 4, downloaded all the updates, etc. The File Manager opens for a second and then disappears.
pete051
Sat Nov 16, 2019 1:18 pm
Problem solved did a apt-get dist-upgrade this morning and everything's ok now :)
PI342
Sat Nov 16, 2019 1:57 pm
:D It works, thank you.
junbo
Sat Nov 16, 2019 4:28 pm
Hi Pete051,
Thank you very much for letting us know the solution to the broken File Manager issue.
My question to you is how did you come up to this solution? Are you a member of the developers of Raspbian?
I am new to the Raspberry community and would like to know how issues are to be dealt with.
When the instruction "apt-get dist-upgrade" is run, it is accessing some files somewhere. Where are these files located?
Please direct me to the information to the upgrade.
Thank you very much.
Junbo
go77310
Sat Nov 16, 2019 9:59 pm
Bonjour
J'ai le même problème identifié ci dessus.
Mon historique:
- Installation de Buster Rpi4 sur carte de 16 Go. Durant une semaine , tous à fonctionné correctement jusqu'à ce que je fasse une coupure brusque de l'alimentation et le boot était cassé.
- Installation de Buster Rpi4 sur carte de 64 Go. Après update et upgrade et un reboot, le gestionnaire de fichier ne fonctionnait plus.
- dans terminal exécution de pcmanfm: gestionnaire cassé sans indication d'erreur.
- exécution de sudo pcmanfm: gestionnaire cassé avec indication de l'erreur suivante:
message: 00:36:12.051: X-terminal-emulator has very limited support. consider chose another terminal. Erreur de segmentation
- exécution de 'apt-get dist-upgrade' avant reboot le gestionnaire de fichier a fonctionné. Après reboot, il ne fonctionnait plus.
Nota: j'ai constaté que lorsque le gestionnaire a fonctionné, un click droit sur l'image du bureau ne faisait pas apparaître le menu déroulant de OpenBox mais un autre menu. Quand le gestionnaire est planté, un click droit sur l'image fait apparaître le menu d'OpenBox
J'espère que j'aurais été utile à la résolution de ce problème.
PS: je vais installer un autre gestionnaire de fichiers que pcmanfm, je vous tiens au courant ...
too_uneeq
Sun Nov 17, 2019 1:36 am
Yes, worked great. Thanks!
dustnbone
Sun Nov 17, 2019 5:20 am
Apt is the command line tool for installing, removing, updating and otherwise managing the software packages that make up the Debian distribution. It's something you really want to know about.
https://wiki.debian.org/AptCLI
Hi Pete051,
Junbo
Adam777
Sun Nov 17, 2019 1:04 pm
After I did "apt-get dist-upgrade" and tried to open File Manager without restart, the whole desktop just froze and I had to pull the plug. After upgrade and restart the result is the same, File Manager closes right after opening, running pcmanfm in terminal shows no error messages.
sarahpts
Mon Nov 18, 2019 9:38 am
Same issue here.
Did a simple
sudo apt-get upgrade
And PCManFM immediately crashes when I click on „preferences“ in the menu. Sometimes I don’t even get to the filemanager window because PCManFM crashes/closes the window immediately.
For now I just did a reinstall and didn’t upgrade the packages anymore. This way pcmanfm still works as intended and without issues.
This is a big problem for me because I use the Pi2 and Raspbian as a system & device for my daily use. It’s my „desktop“ PC.
I also want to mention the bug that with a fresh install of Raspbian Buster right now, you can’t mount LUKS encrypted hard drives without first installing the package libblockdev-crypto2 and doing "systemctl restart udisks2.service"
This is a known bug from LXDE it seems:
https://github.com/pop-os/pop/issues/163
https://www.askmeaboutlinux.com/?p=3444
Mon Nov 18, 2019 11:09 am
Please use
apt full-upgrade
rather than
 apt-get upgrade
This should fix the problem.
Please see this thread https://www.raspberrypi.org/forums/view ... 5#p1567915
