I have a weird problem with the RPi HDMI output. I'm connecting it to a monitor through an HDMI cable plus an HDMI-to-DVI adapter and I'm powering the board from an external wall adapter (5V 2A). It turns out that the monitor only works if i connect the RPi ground to the earth of my electrical system (or a metallic pipe, or anything else connected to earth). Until I was using the USB to power the RPi I did't experience this problem because apparently the PC USB ground is connected to the electrical system ground and therefore that already did the trick.
Has this any sense whatsoever? Maybe the HDMI adapter I'm using is missing some required pins?
Thank you for any thoughts.
L.
