Aardappeltaart
Pi4, TV-hat and WIFI AP compatiblilty
Sat Nov 02, 2019 7:02 pm
I'm using the Pi4 for watching DVB-TV and also as a wireless AP.
Both work great separate, but not together. When I'm watching TV, the Pi is losing all connected devices on the AP.
iw dev wlan0 station dump | grep St
gives nothing
I tried a ribbon extension cable for the TV-Hat, but that doesn't help.
Seems there is interference between the TV-hat and WIFI.
Or can the problem be caused by the an insufficient power supply?
The Pi does not throttle:
vcgencmd measure_volts;vcgencmd get_throttled;vcgencmd measure_temp
volt=0.8472V
throttled=0x0
temp=51.0'C
AFAICR there was a second batch of TV-hats, because the first hat caused interference, but I can't find any info about it now.
Can someone elaborate on that?
when I disable WIFI completely,
sudo ifconfig  wlan0 down
I'm seeing higher SNR and less UNC in `femon -H`
The TV-Hat worked fine before on a RPI3+, but I never used Wifi on that device.
Aardappeltaart
Re: Pi4, TV-hat and WIFI AP compatiblilty
Sun Nov 03, 2019 12:23 pm
Ordered an official PSU, could sould the problem.
Still anyone any ideas about TV-hat and WIFI interference (on a PI4), or a slightly patched second TV-Hat batch?
Aardappeltaart
Tue Nov 05, 2019 3:21 pm
Official power supply arrived, but halas no improvements.
So we can rule out insufficient power. It's a nice supply though.
Problem stays: something playing in Kodi, AP is dropping al connections.
But doesn't matter if it's DVB-TV or some h264 content from local disk.
Problem solved it when I force a high WIFI channel in hostapd (11-13) for 2.4GHZ
Channel 3-6; all devices are immediately dropped when playing something in Kodi.
Seems like interference between CPU/GPU and WIFI 2.4GHZ.
Anybody similar WIFI problems with the Pi4?
Aardappeltaart
Mon Nov 25, 2019 5:43 pm
HDMI interference, other cable solved the problems.
https://www.raspberrypi.org/forums/view ... 0#p1571440
Aardappeltaart
Mon Dec 02, 2019 8:51 am
That said other monitor solved the problem.
Strange, but that seems to be the case:
https://www.raspberrypi.org/forums/view ... 5#p1573994
