WolfRamiO
Power Supply Advice.
Thu Oct 31, 2019 6:10 pm
Hi there!
I have a Pi4 with 4 GB and sometimes i get low voltage warnings with my current power supply, so i need a new one...
The power supply is a Generic Qualcomm 3.0 Quick Charge GA-QC810 and output is: 5v-3000mA, 9v-2000mA and 12v-1500mA
The warning show up when the power supply is cold and when i OC the Pi only 100 MHz. Also i have attached an 1TB USB 3.0 HDD that eat up to 1A. and a 60mm fan over pasive Armor case...
So i think the new power supply should be up to 3500mA or more (what is the max current that Pi4 can handle?), also other requirements are: Lowest price possible, Stable output, Cold operation and secure to run 24/7 and the more important one!, should be available in AliExpress.
Thanks! and sorry for my bad English.
B.Goode
Re: Power Supply Advice.
Thu Oct 31, 2019 6:14 pm
This is what Raspberry Pi themselves recommend -
https://www.raspberrypi.org/products/ty ... er-supply/
Will probably not be available via AliExpress.
HawaiianPi
Thu Oct 31, 2019 6:23 pm
Phone chargers are not power supplies. Phones only require a little over 4.2V to charge. Because of that, many phone chargers have poor voltage regulation and will not maintain a stable 5V under load.
Get the official Raspberry Pi 5.1V/3.0A USB-C power supply.
WolfRamiO
Thu Oct 31, 2019 6:33 pm
Can the official one handle the 1 Amp. USB HDD and OC? also my Pi is at 100% CPU usage almost all day.
B.Goode
Thu Oct 31, 2019 7:13 pm
You have a link to the specification for the supply that 2 people have mentioned.
Raspberry Pi have published maximum and typical current requirements for their boards. https://www.raspberrypi.org/documentati ... /#pi-power
You know the details for your own add-ons.
Time to do the arithmetic?
