1uke_
Need help with composite output
Fri Oct 25, 2019 9:25 pm
I am attempting to get teefax working which requires me to output video via the composite cable.
I am using a Raspberry Pi 2b+ running Raspbian Stretch. My TV uses the PAL UK signal.
I have modified the /boot/config.txt file to have the following
sdtv_mode=2
#hdmi_force_hotplug=1
I have put my full config file here - https://pastebin.com/c3KVASK5
Can any one suggest my composite video isn't working and what I might do to resolve it?
Thank you in advance :)
rpiMike
Re: Need help with composite output
Fri Oct 25, 2019 9:27 pm
Which model of Raspberry Pi are you using?
Which composite format does your TV use eg PAL,NTSC?
1uke_
Fri Oct 25, 2019 9:29 pm
Thanks for the heads up Mike, (I really should know better!)
I have updated the original post above to include that I am running a Raspberry Pi 2b+ with Raspbian Stretch. And that my TV uses PAL UK
Thanks again for mentioning that I forgot this vital information :/
rpiMike
Fri Oct 25, 2019 9:31 pm
Are you using a cable that specifies compatible with the Pi?
https://thepihut.com/products/av-compos ... 3-x-rca-3m
1uke_
Fri Oct 25, 2019 9:33 pm
I'm not. It's just a random cable I got from eBay ........ (I think I know where this might be going) :D
rpiMike
Fri Oct 25, 2019 9:35 pm
I suggest you buy a recommended cable - there are at least 4 different wiring combinations.
If you have a multimeter you can check your cable : https://www.youtube.com/watch?v=UEWs_bxDWic
drgeoff
Fri Oct 25, 2019 9:36 pm
A large proportion of the difficulties with composite video are caused by not using an appropriately wired cable between the 3.5mm socket on the RPi and the TV.
See eg https://www.raspberrypi.org/forums/view ... 22#p653422 for details.
klricks
Sat Oct 26, 2019 12:07 am
If you have the very common camcorder cable then connect RED of the cable to YELLOW on the TV.
Sat Oct 26, 2019 5:02 am
There is no 2B+ model, you are mistaken:
https://www.raspberrypi.org/documentati ... /README.md
Regards composite out, test the cable:
https://www.raspberrypi-spy.co.uk/2014/ ... ideo-jack/
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
hippy
Sat Oct 26, 2019 1:43 pm
Presumably you mean a "Pi 2 Model B Version 1.2" which uses a BCM2837 ( perhaps even a BCM2837B these days ) rather than the BCM2836 fitted to the original 2B boards.
I also tend to think of that as a "2B+" to discriminate between the two but that is not its official designation.
There is no reason I can see why composite wouldn't work with any 2B and would also suspect the problem being an incorrectly wired connector cable.
About a third of the 3.5mm jack to video cables I have are directly compatible with the Pi wiring scheme, the others not. As suggested, you can use a resistance meter as a continuity checker to figure out how what you have is wired.
