How do I use all the 512 ram?
Posted: Thu Dec 13, 2012 12:30 am
by EdwinJ85
Hi guys. I just installed the latest rasbian build on my 512mb ram pi. What do I need to do to make sure I am using all of it?
I have heard you can't just go edit the memory split in the config file without updating the drivers. Does anybody have any more information?
Thanks.
Re: How do I use all the 512 ram?
Posted: Thu Dec 13, 2012 12:53 am
by Dweeber
If it is the latest raspian - 2012-10-28-wheezy-raspbian after you do the setup (which includes raspi-config and doing the update), you should be able to edit the /boot/config.txt file and add the GPU split you want.
The minimum split is 16, the default is 64
gpu_mem GPU memory in megabyte. Sets the memory split between the ARM and GPU. ARM gets the remaining memory. Min 16. Default 64
or
gpu_mem_512 GPU memory in megabyte for the 512MB Raspberry Pi. Ignored by the 256MB RP. Overrides gpu_mem. Max 448. Default not set
Ref:
http://elinux.org/RPiconfig#Memory
Posted: Thu Dec 13, 2012 4:06 pm
by EdwinJ85
Dweeber wrote:If it is the latest raspian - 2012-10-28-wheezy-raspbian after you do the setup (which includes raspi-config and doing the update), you should be able to edit the /boot/config.txt file and add the GPU split you want.
or
Ref:
I've done everything but the update. What command do I need to run for that?
Thanks,
Edwin.
Posted: Thu Dec 13, 2012 4:09 pm
by Dweeber
One of the menu options of raspi-config
$ sudo raspi-config
Posted: Thu Dec 13, 2012 11:11 pm
by EdwinJ85
Thanks, I set it to 256mb, seems to be a slight improvement in system speed. Task manager says I am using 248mb of ram, so as the minimum gpu ram is 16 I assume it must have worked.
What is the best split for running a desktop on though - I am guessing I am giving the GPU too much memory. I can see in task manager that most processes have loads of data in virtual memory and swapping it in and our is hammering the cpu.
Thanks.
Posted: Fri Dec 14, 2012 7:22 am
by Lob0426
If you are not seeing all of your memory with;
cat /proc/meminfo
then type at the prompt;
sudo apt-get update && sudo apt-get upgrade
This updates your RasPi system to the newest firmware.
You can then check your config.txt file for the gpu_mem settings.
sudo nano /boot/config.txt
It should be set to 64(MB) as they stated above. If not add this to the bottom of the file.
gpu_mem=64
then ctrl +x then Y then enter, that saves the changes to config.txt.
Posted: Fri Dec 14, 2012 1:15 pm
by EdwinJ85
I have already done that. but is 64mb really enough for the GPU when running LXDE? It seems not to be very much memory at all.
I know the 256/256 split I have now is a bad idea but I still want to give the GPU a little breathing room, I was wondering what setups are recommended?
Thank you for the command to check the memory from the cli btw, that will be helpful!
