peanutbutter71
Raspberry pi 4b peripherals still powered on after shutdown
Mon Oct 21, 2019 2:17 am
I have a Raspberry pi 2 and 3 and on both of those when I shut them down the periperals like a connected usb drive also power down. On the Raspberry pi 4b I just purchased, when I shutdown, the ethernet is still on, and the connected usb hard drive is still spinning and its light is on too. Is this by design?
In raspbian I've tried sudo shutdown -h now as well as sudo poweroff. Same behavior from Libreelec shutdown too.
peanutbutter71
Re: Raspberry pi 4b peripherals still powered on after shutdown
Sat Oct 26, 2019 4:54 pm
I think I figured this out here:
https://www.raspberrypi.org/documentati ... _config.md
by reprogramming the bootloader and setting POWER_OFF_ON_HALT=1
alphanumeric
Sat Oct 26, 2019 5:12 pm
Just be aware that this also affects booting back up. Grounding GPIO 3 will no longer boot up your Pi 4B. I don't think the RUN pin will work either? You'll have to momentarily ground Global_EN pin or power cycle you Pi.
jcyr
Sat Oct 26, 2019 5:13 pm
That will turn off the 3.3V rail on shutdown. The 5V rail is always on.
It's um...uh...well it's kinda like...and it's got a bit of...
Sat Oct 26, 2019 5:42 pm
The USB 5V should power down too.
Birdybird
Wed Oct 30, 2019 10:34 am
The USB 5V should power down too. No it does not powerdown.
jcyr
Wed Oct 30, 2019 12:51 pm
It doesn't.
BDL42
Fri Nov 01, 2019 3:48 pm
I followed the instructions to edit the bootloader configuration on: https://www.raspberrypi.org/documentati ... _config.md
Setting POWER_OFF_ON_HALT=1 does not turn off +3.3V on halt, or upon shutdown. This is in conflict with the documentation. Since I have a fan connected to 3.3V, it is pretty easy to see if there is power or not. In the past, I have used the fan blades stopping to tell me it is safe to turn off the power. This no longer works.
Linux rpi4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Nov  1 11:11:31 2019
[email protected]:~ $ vcgencmd bootloader_config
BOOT_UART=0
WAKE_ON_GPIO=1
POWER_OFF_ON_HALT=1
FREEZE_VERSION=0
[email protected]:~ $ sudo halt
Connection to rpi4.local closed by remote host.
Connection to rpi4.local closed.
Fan still runs after halt. Waited 1 minute and still running.
Either the command doesn't do what it supposed to do, or the instructions are incorrect, or something else?
Tested on RPI4B 2GB.
jdb
Fri Nov 01, 2019 4:07 pm
You need to also set WAKE_ON_GPIO=0. WAKE_ON_GPIO=1 implies POWER_OFF_ON_HALT=0, as detailed in the documentation.
Rockets are loud.
https://astro-pi.org
BDL42
Fri Nov 01, 2019 4:29 pm
jdb, thank you for your instruction! That seemed to do the trick. Upon rereading the documentation, it was very clear. For some reason, I didn't catch it the first time through. The 3.3V fan now turns off using both halt and shutdown. Thanks again.
