nabil.guellati
A problem appears in my raspberry pi 3B+ after 3 of 4 running days.
Sun Oct 20, 2019 11:14 am
Hello every one,
I writing this post to ask you a question about a problem I am having with the Raspberry Pi 3 B+.
I am using Raspbian Stretch (2018-06-27) and I am writing a code with Qt 4.8.7. In my application I use Linux commands as follows:
system("sudo shutdown now");
or
system("/opt/vc/bin/vcgencmd measure_temp > /home/pi/temp.txt");
My application works very fine without any problems. However, since I run the raspberry without stop, after 3 or 4 days of running, Linux commands stop working !!!
I don’t know if this is a problem in Raspbian OS or in the hardware ???
If anyone has an idea about this problem, please answer me.
Best regards.
pcmanbob
Re: A problem appears in my raspberry pi 3B+ after 3 of 4 running days.
Sun Oct 20, 2019 1:11 pm
Hi.
The one important thing you have not told us is how you are entering the commands ,
1. via keyboard directly connected to pi with a screen also connected
2. via ssh
3. via vnc/terminal
if using option 2 or 3 how is your pi connected to the network wifi/LAN
nabil.guellati
Sun Oct 20, 2019 6:47 pm
Hi pcmanbob, thanks for the answer.
The raspberry is connected to a screen and I plug a keyboard only when I modify the application, otherwise there is only a screen plugged to the raspberry running without stopping. I use Linux commands in my C++ code using the instruction "system". For example, I write :
int value_returned = std::system("echo \"on 0\" | cec-client -s -d 1");
in order to power on the screen.
The above line works perfectly for 3 or 4 days, and after that all commands written in the application stop working !!!
For example, the line :
works fine returning the temperature in the beginning, and after 3 or 4 running days it returns an empty file "temp.txt".
Best regards.
pcmanbob
Mon Oct 21, 2019 12:00 pm
I cant help with the C++ programming , but you could try changing your system call that gets the temperature so that it collects all the results of command including any errors
system("/opt/vc/bin/vcgencmd measure_temp >> /home/pi/temp.txt 2>&1");
assuming that would not cause any problems with you program.
You might also try running the free -m command every minute in cron and piping the results to a file to see if you are running out of memory.
and lastly when your program stops working can you still enter commands at the command line ?
if you can try running the free -m command then to see if you have any free memory.
nabil.guellati
Mon Oct 21, 2019 6:04 pm
Thanks a lot for the advice.
I will try these stuff and answer you.
Best regards.
