Pi 4 - Can't get composite video working
Posted: Sat Oct 12, 2019 8:53 pm
by sweston
Hi all,
I am using a raspberry pi for a retro robot project. I am making use if an old black and white 5 1/2 inch CRT TV with a composite input as the screen (which is my robot's face). I was using a raspberry pi 3, but decide my project would benefit from something with a bit more power, so now using a raspberry pi 4. Unfortunately I cannot get the Pi4 to correctly work with the TV (the Pi3 still works fine).
I have used a freshly flashed buster image and created the ssh and wpa_supplicant.conf files in order to access the Pi through ssh from my windows laptop.
The Pi3 just seemed to automatically work after first boot. The Pi4 just gives me a blank tv screen after first boot, but must be booting up as I can access it via ssh.
My config.txt file is as below:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
sdtv_mode=2
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
I have already navigated the forum as best I can and discovered the tvservice command. The result of the tvservice -s command is as below
state 0x120001 [TV is off]
When I try to force power on the SDTV mode with tvservice --sdtvon="PAL 4:3" I just get a flickering on the TV.
Any suggestions on what I am doing wrong and how to get this working?
Thank is advance for any help.
Re: Pi 4 - Can't get composite video working
Posted: Sat Oct 12, 2019 10:34 pm
by klricks
The RPi 4 has composite disabled by default. Use sudo raspi-config to enable composite mode. (Advanced menu A9 --> V2)
Posted: Sun Oct 13, 2019 8:39 am
by sweston
Thanks klricks. That worked perfectly. :D
Posted: Sun Oct 13, 2019 9:25 am
by Imperf3kt
Isn't it actually Raspbian itself that has composite disabled by default from Buster and onwards?
Posted: Sun Oct 13, 2019 9:47 am
by jamesh
No, it's Pi4 specific. Composite requires slower clocks which affects overall performance, so we disable by default.
