Redstevo
Pi 4b not setting my acer monitor at correct resolution
Fri Oct 11, 2019 8:47 pm
Hi all, probably a newbie question but I've bought an acer monitor for my pi 4 and it boasts a max resolution of 1920 x 1080 - but both the monitor and os don't let me change to this from a default of 1080 x 788. Also the monitor is widescreen and despite setting screen config to 1 x 16 it still looks stretched. Am I missing something really obvious. The monitor is budget so maybe it doesnt really do 1920 x 1080 in a normal environment?
redstevo
W. H. Heydt
Re: Pi 4b not setting my acer monitor at correct resolution
Sat Oct 12, 2019 5:43 am
What model is the monitor?
Man in a van
Sat Oct 12, 2019 10:28 am
Have you tried this?
Open a terminal:
sudo raspi-config > Advanced options > Resolution > select mode 82
save,exit and reboot.
On the desktop:
Applications menu > Preferences > Screen configuration > Configure > Screens > HDMI-1 > Resolution > 1920x1080 > Configure > Apply > OK
ronnie
Xmantium
Sat Oct 12, 2019 3:41 pm
I had the same issue
Fixed my using the micro hdmi input next to usb-c and not the one the right!
Redstevo
Sat Oct 12, 2019 10:41 pm
sudo raspi-config did trick - thank you!
Steve
