witteherder
Rasbian is not starting up after update
Wed Oct 09, 2019 1:01 pm
I did the follwing commands:
sudo apt-get update.
sudo apt-get dist-upgrade.
After this Rasbian is not starting up
He gives the splash screen and then it turns into black
Also my Domiticz is working on this so my smarthouse is UPSET
I can reach recovery mode.
Green is flashing for times.
Red light is on all the time.
I m booting from a SSD Drive (USB) instead of SD Card
Can anybody help me please?
Raspberry Pi 3B+
Domoticz V4.10717
Toon 2 Rooted User
Firmware version: 5.9.6
7 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
gkaiseril
Re: Rasbian is not starting up after update
Wed Oct 09, 2019 2:27 pm
Which version of Raspbian were you using?
The "dist-upgrade" may be upgrading the major OS version from stretch to buster. If you have tried to upgrade to buster without adjusting the boot partition, your upgrade will fail. Also there are a number of other steps that are necessary to attempt an OS upgrade using this approach.
If you are updating your packages use the following commands:
sudo apt-get update
If there are updates to be installed use:
sudo apt-get upgrade
Anf if you receive a message about packages no longer needed them use:
sudo apt-get autoremove
It is possible to use just "apt" and not "apt-get" in the above commands.
Have you used the SD card duplicate to create a backup of your system?
I am afraid you will need to build your system form scratch.
You might want to add a step to backup your system and test the backup prior to updating your software.
Do not use the "dist-upgrade" unless told to do so by an experienced user and make a backup of your SD card prior to attempting this command.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
witteherder
Wed Oct 09, 2019 2:35 pm
I installed Rasbian Buster
But I m using a USB SSD Hard disk so how to go further now?
I did make an Backup but i dont know how to get that back on the SSD Card
Raspberry Pi 3B+
Domoticz V4.10717
Toon 2 Rooted User
B.Goode
Wed Oct 09, 2019 3:07 pm
Really?
That is directly contrary to the advice given by Raspberry Pi themselves:
Next, upgrade all your installed packages to their latest versions with the following command:
Generally speaking, doing this regularly will keep your installation up to date for the particular major Raspbian release you are using (e.g. Stretch). It will not update from one major release to another, for example, Stretch to Buster.
Ref: https://www.raspberrypi.org/documentati ... pdating.md
Kendek
Wed Oct 09, 2019 3:29 pm
Because the dist-upgrade (= full-upgrade) doesn't by itself upgrade the current system to the next major OS version.
witteherder
Thu Oct 10, 2019 1:33 pm
I did a backup img from august and it was working again
Then I did this again
And again it is stuck
Should i give other commands?
While upgrading he was not giving faults by the way
Raspberry Pi 3B+
Domoticz V4.10717
Toon 2 Rooted User
