Raspberry Pi 3B+ Unable to sync to correct time
Posted: Thu Oct 03, 2019 4:32 pm
by Nathan.Rivard
I am attempting to get my raspberry pi to set the time in accordance with a time zone. I have already set the time zone as being relative to the Chicago timezone and it still does not sync correctly with CST. I have also been using the manual input for setting time which works for a bit, until the pi crashes, which it does at least once a day. Then, when I turn it back on, the pi's time is hilariously off. Is there any way to force the pi to sync to the correct time?
Re: Raspberry Pi 3B+ Unable to sync to correct time
Posted: Thu Oct 03, 2019 4:57 pm
by Crowbot
Usually the Pi will sync up when it's online. Are you online? Also, I'd want to know why the Pi crashes so reliably.
Posted: Thu Oct 03, 2019 5:00 pm
by DirkS
What do you mean by this exactly? Normally you set a timezone relative to UTC.
How exactly did you change the timezone?
What is the difference the time the Pi shows and what you expect it to be?
What is the output of
timedatectl
Posted: Thu Oct 03, 2019 8:39 pm
by Nathan.Rivard
Yes, the unit is online and in system-config I set the time in the same timezone as Chicago time
timedatectl:
Local time: Thu 2019-10-03 06:34:24 CDT
           Universal time: Thu 2019-10-03 11:34:24 UTC
                 RTC time: n/a
                Time zone: America/Chicago (CDT, -0500)
System clock synchronized: no
              NTP service: inactive
          RTC in local TZ: no
I would like to add that the actual time and date are 10/3/2019 at 3:39 PM
Posted: Thu Oct 03, 2019 8:54 pm
by Andyroo
Does your Pi have internet connection correctly set up?
What happens if you
ping 8.8.8.8
ping google.com
Posted: Mon Oct 07, 2019 4:03 pm
by Nathan.Rivard
What happens if you
ping 8.8.8.8
ping google.com
When I do that I get
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
102 packets transmitted, 0 received, 100% packet loss, time 124ms
The google doesn't really do much for a while
Posted: Mon Oct 07, 2019 8:13 pm
by knute
It looks like a DNS problem. The output from timedatectl shows not synced. No return from the google.com ping. All symptoms of DNS not working correctly.
You might post the last 15 or so lines of /etc/dhcpcd.conf if you are using a static IP.
If you are using dhcp then: cat /var/run/dnsmasq/resolv.conf.
Or maybe you aren't on line at all?
Posted: Mon Oct 07, 2019 8:28 pm
by lpsw
If a ping to 8.8.8.8 fails, it's clear there is no functional connection to the internet.
Posted: Tue Oct 08, 2019 2:38 pm
by Nathan.Rivard
lpsw wrote:[/code]ime=1570480122 user_id=152029]
I am able to connect to google/anything on the web browser as well as transfer files to a remote computer on the VNC Server. The last 15 lines of the /etc/dhcpcd.conf are
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
# Example static IP configuration:
#interface eth0
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
Posted: Tue Oct 08, 2019 4:02 pm
by pcmanbob
What happens if you try running this from command line ?
sudo date -s "$(wget -qSO- --max-redirect=0 google.com 2>&1 | grep Date: | cut -d' ' -f5-8)Z"
does it set the correct time and date for you ?
and does the pi then keep the correct time and date ?
Posted: Tue Oct 08, 2019 4:45 pm
by Nathan.Rivard
Well that worked perfectly thank you so much
Posted: Tue Oct 08, 2019 8:00 pm
by Nathan.Rivard
I was wrong, it worked until the pi crashed while running a python program for a few hours. It is now 20 min behind
Posted: Tue Oct 08, 2019 9:17 pm
by pcmanbob
So your pi is still not syncing it's time with internet time.
So is this a new build on the SD card or a long running version of the OS ?
And which OS are you running ?
Posted: Tue Oct 08, 2019 9:51 pm
by lpsw
Can you successfully ping to 8.8.8.8?
Posted: Tue Oct 08, 2019 9:56 pm
by pcmanbob
Seeing the OP was able to set the time with the command I suggested which used Google to get the current time I would think the pi has a working internet connection.
OP has also stated that web can be browsed via chrome successfully.
Posted: Wed Oct 09, 2019 12:28 am
by lpsw
There was also this
Posted: Wed Oct 09, 2019 11:16 am
by pcmanbob
There was also this
Yes the information provided by the OP is very confusing , says the ping 8.8.8.8 does not work yet he can surf the web and the command to set the time using information from google.com works.
Both answers cant be true !!
Posted: Wed Oct 09, 2019 6:12 pm
by DougieLawson
They may not be mutually exclusive if there's a firewall blocking ICMP/IP.
If the same firewall blocks UDP/IP that could also explain why time synchronisation doesn't work.
The OP needs to ask the folks that own the network.
htpdate may be an answer as it pulls the time from Google's home page or from Wikipedia.
