ppbulnes
Cant acces available wifi networks
Wed Oct 02, 2019 4:00 am
Rpi 3B
Wired coneection works w/out problem, but:
In Raspbian:
I cannot access the networks that show as available. Enter the password and there was not even a dialog box showing whether the connection was successful or not.
In Libreelec:
Same, cannot accees neither, bur librelec shows the following message: Network error: Inpu/output error
didnt find this as a solved issue, please help.
Thanks,
pp
Re: Cant acces available wifi networks
Wed Oct 02, 2019 8:58 am
What's in /etc/wpa_supplicant/wpa_supplicant.conf (redact the password and post it here).
Is the wireless AP running with WEP security?
Is the wireless AP running with a hidden SSID?
ppbulnes
Thu Oct 03, 2019 12:21 am
In the file:
ctrl_interface=DIR=/var/run/wpa_suplicant GROUP=netdev
update_config=1
country=PE
network={
ssid="Arris-2dF5" <---------- yes, thats my network
psk="a1234567" <---------- yes, thats the pswd
key_mgmt=WPA-PSK
How i check the rest? I didnt make any changes to my router or even to my phone. the Rpi just stopped connecting and after trying some stuff in this forums, i just installed a fresh image of raspbian and libreelec (both in separated SDs).
Thanks for your patient.
pp
Thu Oct 03, 2019 7:04 am
You'll get some info from a wpa_cli status command.
You'll get more from iwlist wlan0 scan from iw dev and sudo iw dev wlan0 scan.
You'll also get some info from http://192.168.0.1 or http://192.168.0.254 or http://192.168.1.1 or http://192.168.1.254 (one of those is likely to be your router's configuration page).
ppbulnes
Thu Oct 03, 2019 8:07 pm
Tnaks for the help, Dougie,
Ill left here what i foundm since i really dont know what im looking for:
From wpa_cli status
Selected interface 'p2p-dev-wlan0'
wpa_state=DISCONNECTED
p2p_device_address=a6:8f:fb:fc:25:f4
uuid=5eea0b99-7f34-5952-8e84-427917e74201
From iwlist wlan0 scan
Cell 04 - Address: 8C:61:A3:AD:51:E3
Channel:6
Frequency:2.437 GHz (Channel 6)
Quality=57/70 Signal level=-53 dBm
Encryption key:on
ESSID:"ARRIS-2D5F"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
18 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=0000000000000000
Extra: Last beacon: 3190ms ago
IE: Unknown: 000A41525249532D32443546
IE: Unknown: 010882848B961224486C
IE: Unknown: 030106
IE: Unknown: 050400010000
IE: Unknown: 0706444620010B14
IE: Unknown: 2A0100
IE: Unknown: 32048C98B060
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
IE: Unknown: DD310050F204104A000110104400010210470010BC329E001DD811B286018C61A3AD51E3103C0001011049000600372A000120
IE: Unknown: 0B05030000127A
IE: Unknown: 2D1A2D0017FFFFFF0000000000000000000000000000001804871100
IE: Unknown: 3D1606000400000000000000000000000000000000000000
IE: Unknown: BF0CB179C233EAFF9204EAFF9204
IE: Unknown: C005000000EAFF
IE: Unknown: 7F080100080000000000
IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
IE: Unknown: DD07000C430B000000
IE: Unknown: DD21000CE708000000BF0CB101C0332AFF92042AFF9204C0050000002AFFC303010202
From iw dev
phy#0
Unnamed/non-netdev interface
wdev 0x2
addr a6:8f:fb:fc:25:f4
type P2P-device
txpower 31.00 dBm
Interface wlan0
ifindex 3
wdev 0x1
addr b8:27:eb:8a:6b:5d
type managed
channel 1 (2412 MHz), width: 20 MHz, center1: 2412 MHz
txpower 31.00 dBm
From sudo iw dev wlan0 scan.
BSS 8c:61:a3:ad:51:e3(on wlan0)
last seen: 809.440s [boottime]
TSF: 0 usec (0d, 00:00:00)
freq: 2437
beacon interval: 100 TUs
capability: ESS Privacy ShortPreamble ShortSlotTime (0x0431)
signal: -58.00 dBm
last seen: 0 ms ago
SSID: ARRIS-2D5F
Supported rates: 1.0* 2.0* 5.5* 11.0* 9.0 18.0 36.0 54.0
DS Parameter set: channel 6
TIM: DTIM Count 0 DTIM Period 1 Bitmap Control 0x0 Bitmap[0] 0x0
Country: DF Environment: Indoor/Outdoor
Channels [1 - 11] @ 20 dBm
ERP: <no flags>
Extended supported rates: 6.0* 12.0* 24.0* 48.0
RSN: * Version: 1
* Group cipher: CCMP
* Pairwise ciphers: CCMP
* Authentication suites: PSK
* Capabilities: 1-PTKSA-RC 1-GTKSA-RC (0x0000)
WPS: * Version: 1.0
* Wi-Fi Protected Setup State: 2 (Configured)
* UUID: bc329e00-1dd8-11b2-8601-8c61a3ad51e3
* RF Bands: 0x1
* Unknown TLV (0x1049, 6 bytes): 00 37 2a 00 01 20
BSS Load:
* station count: 4
* channel utilisation: 0/255
* available admission capacity: 31250 [*32us]
HT capabilities:
Capabilities: 0x2d
RX LDPC
HT20
SM Power Save disabled
RX HT20 SGI
No RX STBC
Max AMSDU length: 3839 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 4 usec (0x05)
HT RX MCS rate indexes supported: 0-23
HT TX MCS rate indexes are undefined
HT operation:
* primary channel: 6
* secondary channel offset: no secondary
* STA channel width: 20 MHz
* RIFS: 0
* HT protection: no
* non-GF present: 1
* OBSS non-GF present: 0
* dual beacon: 0
* dual CTS protection: 0
* STBC beacon: 0
* L-SIG TXOP Prot: 0
* PCO active: 0
* PCO phase: 0
VHT capabilities:
VHT Capabilities (0x33c279b1):
Max MPDU length: 7991
Supported Channel Width: neither 160 nor 80+80
RX LDPC
short GI (80 MHz)
TX STBC
SU Beamformer
SU Beamformee
+HTC-VHT
RX antenna pattern consistency
TX antenna pattern consistency
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: MCS 0-9
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
VHT RX highest supported: 1170 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: MCS 0-9
VHT TX highest supported: 1170 Mbps
VHT operation:
* channel width: 0 (20 or 40 MHz)
* center freq segment 1: 0
* center freq segment 2: 0
* VHT basic MCS set: 0xffea
Extended capabilities: HT Information Exchange Supported, BSS Transition
WMM: * Parameter version 1
* BE: CW 15-1023, AIFSN 3
* BK: CW 15-1023, AIFSN 7
* VI: CW 7-15, AIFSN 2, TXOP 3008 usec
* VO: CW 3-7, AIFSN 2, TXOP 1504 usec
Tnx in advance for the help.
Thu Oct 03, 2019 9:02 pm
update_config=1
country=PE
network={
               key_mgmt=WPA-PSK
                    Channel:6
                    Encryption key:on
                    ESSID:"ARRIS-2D5F"
Spot the difference!
ssid="Arris-2dF5" is not equal to ESSID:"ARRIS-2D5F"
Change it to
update_config=1
country=PE
network={
                ssid="ARRIS-2D5F"                  <---------- yes, thats my network
               key_mgmt=WPA-PSK
The same is true for your password, beware that "a1234567" is not equal to "A1234567".
ppbulnes
Thu Oct 03, 2019 9:06 pm
How i change it?
Thu Oct 03, 2019 9:09 pm
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
ppbulnes
Thu Oct 03, 2019 9:23 pm
update_config=1
country=PE
network={
ssid="ARRIS-2D5F"
psk="a1234567"
key_mgmt=WPA-PSK
Done, but nothing happeneed.
Thu Oct 03, 2019 9:53 pm
Have you tried rebooting your Wireless Access point?
Have you tried connecting your Raspberry to some other network?
You could try "COUNTRY=US" or "COUNTRY=UK" to see if there's a bug in Wpa_Supplicant for Peru.
There's also the ICON on the Raspbian Desktop which should pop-up a connection menu.
Last option is grab a new SDCard, grab a copy of Raspbian Buster 2019-09-26 and see if that works.
ppbulnes
Thu Oct 03, 2019 10:06 pm
Have you tried rebooting your Wireless Access point?:
Yes.
Have you tried connecting your Raspberry to some other network?:
Yes, my ipohne, my neighbour's, and is te same: i can see the network, but cant coonect. Actually, the previous reports, shows also the other available networks.
i'm tring this with 2 sd cards: 1 with raspbian and 1 with libreelec, and i have the same problem. I think is not the OS, not my network, and not the SD
Thu Oct 03, 2019 10:18 pm
You may need to conclude that your hardware is broken.
ppbulnes
Fri Oct 04, 2019 12:40 am
any chance to blame the firmware or some hw update?
Fri Oct 04, 2019 1:12 am
Not if it fails with a fresh download of Raspbian Buster 2019-09-26 (or NOOBS 3.2.1).
ppbulnes
Fri Oct 04, 2019 2:56 am
Thanks very much for your help, Dougie.
I´m goin to call it.
Time for a Rpi4 maybe?
