Just a question? Reformatting an HD
Does anyone know of any way I can convert my old 1 TB HDD which is formatted in Linux back to ntfs or anything windows 10 will read?
Make the most of your family and friends , your children grow up too quickly and you don't notice yourself ageing, friends dissapearing, moving on. You make plans for your future, but they can all be smashed in an instant, live life and enjoy.
Re: Just a question?
Assuming that you don't need the data on it
1) erase the disk (puts it in a state windows will be happy with)
sudo dd if=/dev/zero of=/dev/sd?? bs=4M (replace sd?? with the device node for the hard disk you are wanting to reformat)
2) boot windows
- windows will see a blank disk and allow you to format it
/Andy
2) boot windows
/Andy
Thanks, I've tried putting into my pc (win 10) but that doesn't see it.
doubleudee1 wrote: ↑Mon Sep 23, 2019 2:06 pmDoes anyone know of any way I can convert my old 1 TB HDD which is formatted in Linux back to ntfs or anything windows 10 will read?
gparted is in the Raspbian repositories:
https://gparted.org/
This might be exactly right as I don't have win10
but...
1. Right-click on This PC (it’s probably on your desktop, but you can access it from the File Manager, as well).
2. Click on Manage and Management window will show up.
3. Go to Disk Management.
You should be able to see all your connected HD's in there , just make sure you select the correct one , and then delete the partition, this should leave you with an empty dive ( note all data will be lost ) , then you can create a new partition and format it as you wish.
WARNING.
All data on the selected drive will be lost, don't do this if you want to keep the data.
Selecting the wrong drive could destroy you windows install, So take care on drive selection.
but...
WARNING.
- RaTTuS
- Contact: Twitter YouTube
then it means there is something wrong with the PC end - is it enabled in the BIOS ?doubleudee1 wrote: ↑Mon Sep 23, 2019 2:30 pmThanks, I've tried putting into my pc (win 10) but that doesn't see it.
what does windows see via computer management
is it powered ?
how is it connected
Covfefe
Covfefe
I have tried removing one of my existing HDD inside my pc and then putting this one in it's place.RaTTuS wrote: ↑Mon Sep 23, 2019 2:56 pmthen it means there is something wrong with the PC end - is it enabled in the BIOS ?doubleudee1 wrote: ↑Mon Sep 23, 2019 2:30 pmThanks, I've tried putting into my pc (win 10) but that doesn't see it.
is it powered ?
how is it connected
On rebooting, windows sees the other two drives, but not this one??
Usually that works as I can reformat drives that way, so I am assuming something has happened inside the drive irself, looks like a bin job to me.
Thanks for all input anyway.
WD
Re: Just a question? Reformatting an HD
Do you have a spare PC that the drive will physically connect to that also has a DVD drive . if so you could try boot & nuke and see if that will detect and erase the HD, just have the drive you want to wipe in the PC and set it to boot from the DVD.
I would not advise trying this in your main pc unless you really know what you are doing as you could wipe all your HD's by accident very easily, unless they are all disconnected.
https://sourceforge.net/projects/dban/
This may be an old version but all we want is to try and wipe the drive.
I usually plug a "suspect drive" into an RPi (3B, 3B+) and see if it can be detected.
if not then I'll try to initialize it
if cannot initialize then I conclude its dead
if can initialize, proceed to initialization then use gparted to format the drive
if gparted cannot format the drive I conclude its dead.
for the "dead drives" concluded above, again I go back to W10 and do HDD check, if can be detected, using Seagate Tools (diskwizard?)
if detection and/or all test fails.... I have a new "plaything"
Some people be like:
Yup, i't deadLTolledo wrote: ↑Wed Sep 25, 2019 8:13 amI usually plug a "suspect drive" into an RPi (3B, 3B+) and see if it can be detected.
if detection and/or all test fails.... I have a new "plaything"![]()
