davef
Cron stops on swapping HDMI or keyboard
Mon Sep 23, 2019 8:38 am
I run a cron job every minute. As I have two Model 3B+ and only one HDMI monitor I have noticed that when I swap the monitor and/or USB keyboard between units that the Pi running Jessie sometimes stops running. Maybe, 1 in 10 swap-overs.
sudo service --status-all
shows a [+] against cron but it just doesn't run until I reboot.
Sound familiar?
Thanks,
Dave
RaTTuS
Contact: Twitter YouTube
Re: Cron stops on swapping HDMI or keyboard
Mon Sep 23, 2019 9:15 am
no what does
sudo status cron
say
also does
sudo dmesg
say anything useful
or even
sudo cat /var/log/syslog
Covfefe
davef
Tue Sep 24, 2019 12:48 am
Thank you for the suggestions ... will have to wait until the weekend as the devices are at a remote location.
I recall looking into syslog and still see that cron apparently runs every minute, but the bash script that cron calls does not get executed. Perhaps should mention that cron is a one line BUT uses a call to /usr/bin/flock to stop possible multiple instances of the bash script that runs every minute.
Everything runs fine until I show up on site and start playing with the system. As well as swapping hardware, as mentioned, there are many
sudo service cron stop
and
sudo service cron start
calls during code modification.
Tue Sep 24, 2019 6:12 pm
You may want to replace cron with systemd-cron.
davef
Wed Sep 25, 2019 12:50 am
As I have never heard of systemd-cron Google led me to this HowTo:
https://www.putorius.net/using-systemd-timers.html
What I couldn't determine was why using systemd-timers might be better in my situation. Is it more robust? Also, I would need to work out how to stop multiple instances of this timer running.
Just read that one of the benefits is that only one instance can run at a time.
I will investigate further.
Tnx,
Dave
davef
Fri Sep 27, 2019 7:13 am
RaTTus,
I am guessing you mean
sudo service cron status
With the system running normally this is what I get:
● cron.service - Regular background program processing daemon
   Loaded: loaded (/lib/systemd/system/cron.service; enabled)
   Active: active (running) since Sun 2019-09-22 15:18:27 NZST; 5 days ago
     Docs: man:cron(8)
 Main PID: 1244 (cron)
   CGroup: /system.slice/cron.service
           ├─ 1244 /usr/sbin/cron -f
           ├─32436 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant_sbms.conf
           └─32537 dhclient -v -pf /run/dhclient.wlan0.pid -lf /var/lib/dhcp/dhclient.wlan0.leases wlan0
Sep 27 18:54:01 raspberrypi sudo[29699]: root : TTY=unknown ; PWD=/root ; USER=root ; COMMAND=/home/./run_system.sh
Sep 27 18:54:01 raspberrypi sudo[29699]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 27 18:54:05 raspberrypi sudo[29699]: pam_unix(sudo:session): session closed for user root
Sep 27 18:54:05 raspberrypi CRON[29692]: pam_unix(cron:session): session closed for user root
Sep 27 18:55:01 raspberrypi CRON[29744]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 27 18:55:01 raspberrypi CRON[29748]: (root) CMD (/usr/bin/flock -w 0 /home/run_system.sh -c "sudo /home/./run_system.sh" > /dev/null 2>&1)
Sep 27 18:55:01 raspberrypi sudo[29751]: root : TTY=unknown ; PWD=/root ; USER=root ; COMMAND=/home/./run_system.sh
Sep 27 18:55:01 raspberrypi sudo[29751]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 27 18:55:05 raspberrypi sudo[29751]: pam_unix(sudo:session): session closed for user root
Sep 27 18:55:05 raspberrypi CRON[29744]: pam_unix(cron:session): session closed for user root
I will try to get it to fault and post the result.
