oicfar
External drive won't mount automatically after reboot
Thu Sep 19, 2019 8:37 pm
I mounted an external HD on one Raspi i my cluster.
sudo mkdir /clusterfs
sudo chown nobody.nogroup -R /clusterfs
sudo chmod 777 -R /clusterfs
In /etc/fstab I added
UUID=65077e7a-4bd6-47ea-8014-01e06655cc31 /clusterfs ext4 defaults 0 2
And
sudo mount -a
works.
Than I installed
sudo apt install nfs-kernel-server -y
and in /etc/exports I added
/clusterfs 192.168.178.0/24(rw,sync,no_root_squash,no_subtree_check)
And at least
sudo exportfs -a
On all the other nodes in the cluster I did
sudo apt install nfs-common -y
sudo chmod -R 777 /clusterfs
In /etc/fstab I added this
<master node ip>:/clusterfs    /clusterfs    nfs    defaults   0 0
And
sudo mount -a
is working.
But after reboot or restart is the external drive not mounted. I don't see anny errors in dmsg. And when I call
sudo mount -a
it works.
Why not automatically?
ejolson
Re: External drive won't mount automatically after reboot
Fri Sep 20, 2019 4:26 am
It may be a problem with how systemd runs the init services. Someone else may understand things enough to fix them properly, but not me. I would place something like
    sleep 5
    echo Mounting everything in fstab...
    mount -a
    echo ...done
in /etc/rc.local and then focus on more interesting problems. It is possible the NFS server will need restarting after you mount the filesystem, but I'm not sure.
oicfar
Fri Sep 20, 2019 7:36 pm
    sleep 5
    mount -a
    echo ...done
Thx. I will check the process. Cause is should work with the entry in the /etc/fstab.
oicfar
Sat Sep 21, 2019 9:52 am
    sleep 5
    mount -a
    echo ...done
I found this
Sep 20 01:19:44 pi-4-node-1 systemd[1]: clusterfs.mount: Mount process exited, code=exited, status=32/n/a
Sep 20 01:19:44 pi-4-node-1 systemd[1]: clusterfs.mount: Failed with result 'exit-code'.
Sep 20 01:19:44 pi-4-node-1 systemd[1]: Failed to mount /clusterfs.
Sep 20 01:19:44 pi-4-node-1 systemd[1]: Dependency failed for Remote File Systems.
Sep 20 01:19:44 pi-4-node-1 systemd[1]: remote-fs.target: Job remote-fs.target/start failed with result 'dependency'.
in syslog.
ejolson
Sat Sep 21, 2019 3:42 pm
    sleep 5
    mount -a
    echo ...done
I found this
in syslog.
That sure looks like systemd trouble to me. I find systemd so confusing that I switched to the Artix and the antiX distributions on my Intel compatible machines. While I haven't found a similarly suitable operating system for the Raspberry Pi, I'm enjoying 64-bit Gentoo Linux on one of my Pi computers.
Sorry I'm not more help. Maybe it would work better to include noauto as an option for /clusterfs in fstab and then change rc.local to read
    sleep 5
    echo Mounting /clusterfs from fstab...
    mount /clusterfs
    echo ...done
