stanwin00
Exit button on Raspberry PI
Thu Sep 19, 2019 9:47 am
Hi, I am trying to figure out how to wire a door exit button to my Pi Access system and I do know the code to utilise the GPIOs to activate the switch.
My questions are as follows:
1) Will it matter if my push exit button says 10A 250V? If no - does this mean I can use ANY type of button?
2) Will it be better if i Wire the push button to the NO part of the relay I already have attached to my pi? The relay controls the EM lock which is wired to NC of the relay and a 12 V power supply.
Appreciate any guidance here.
Thank you.
Burngate
Re: Exit button on Raspberry PI
Thu Sep 19, 2019 10:28 am
Not sure what you mean - a switch is an input device. It doesn't need "activating" - it just works
If "10A 250V" is written on the switch, it means "Don't use this switch to control more than 10A or more than 250V"
It doesn't say anything about what you could use instead.
Surely you don't want to connect the switch (an input device) to any part of the relay (an output device)
Draw a diagram of what you want to achieve, and post it here.
stanwin00
Thu Sep 19, 2019 6:14 pm
Thank you. That explains and answers my questions. I will just proceed to wire the switch to one of the gpios then :) cheers.
Imperf3kt
Thu Sep 19, 2019 11:12 pm
Note that 10A 250v sounds like an AC rating, it won't be the same for DC.
55:55:44:44:4C
52:4C:52:42:41
