trantuong
PI 4 show no signal with monitor
Wed Sep 18, 2019 3:00 am
Hello everyone!
I'm fresher with PI and I have problem with PI4.
my PI4 shows no signal when I connect to my monitor (LG 29wk600). However, it runs perfectly on HDMI LCD ( 7 Inch ). I connect PI4 with my monitor by using a micro HDMI cable. How can I fix the problem? I hope to give your support. Thanks
* The information of monitor :
29” 21:9 WFHD (2560 x 1080) IPS Display
EsoreDre
Re: PI 4 show no signal with monitor
Wed Sep 18, 2019 6:26 am
I think you should consider your power supply.May the Power isn't enough to power the Pi.Second,you should confirm the power supply which is used for the monitor.
Politeness is cultivation,solitary is personality
