nik545
ovpn run problem
Tue Sep 17, 2019 11:18 am
ovpn run problem
EditDelete postReport this postQuote
Wed Sep 11, 2019 2:04 pm
hi, guys)
got problem running openvpn client on my RPZ.
the problem is ovpn wont start on boot...
or without sudo prefix if i run it from terminal.
my guess (im almost sure ) ovpn cant create tun interface for the connection
ERROR: Cannot ioctl TUNSETIFF tun: Operation not permitted (errno=1)
if i run
sudo openvpn ./client1.ovpn
or
sudo openvpn --config client1.ovpn
got 100% working connection
any guess how to fix it
thanks for your replies))
graysky
Re: ovpn run problem
Tue Sep 17, 2019 11:31 am
You have provided really nothing to go on beyond your experience. People need logs and output to diagnose. Distro and network setup would be helpful as well.
nik545
Tue Sep 17, 2019 11:47 am
network is dhcp wifi, or 3g modem i tried both
output of openvpn --verb 9 --config client1.ovpn
pi@raspberrypi:/boot/ovpn $ openvpn --verb 9 --config client1.ovpn
Tue Sep 17 12:43:25 2019 us=718551 WARNING: file 'client.key' is group or others accessible
Tue Sep 17 12:43:25 2019 us=720166 WARNING: file 'auth.cfg' is group or others accessible
Tue Sep 17 12:43:25 2019 us=720988 Current Parameter Settings:
Tue Sep 17 12:43:25 2019 us=721730   config = 'client1.ovpn'
Tue Sep 17 12:43:25 2019 us=722438   mode = 0
Tue Sep 17 12:43:25 2019 us=724154   persist_config = DISABLED
Tue Sep 17 12:43:25 2019 us=727415   persist_mode = 1
Tue Sep 17 12:43:25 2019 us=729723   show_ciphers = DISABLED
Tue Sep 17 12:43:25 2019 us=731487   show_digests = DISABLED
Tue Sep 17 12:43:25 2019 us=731679   show_engines = DISABLED
Tue Sep 17 12:43:25 2019 us=731804   genkey = DISABLED
Tue Sep 17 12:43:25 2019 us=731928   key_pass_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=732047   show_tls_ciphers = DISABLED
Tue Sep 17 12:43:25 2019 us=732166   connect_retry_max = 0
Tue Sep 17 12:43:25 2019 us=732284 Connection profiles [0]:
Tue Sep 17 12:43:25 2019 us=732403   proto = tcp-client
Tue Sep 17 12:43:25 2019 us=732522   local = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=732638   local_port = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=732755   remote = '195.211.173.40'
Tue Sep 17 12:43:25 2019 us=732871   remote_port = '1194'
Tue Sep 17 12:43:25 2019 us=732987   remote_float = DISABLED
Tue Sep 17 12:43:25 2019 us=733104   bind_defined = DISABLED
Tue Sep 17 12:43:25 2019 us=733218   bind_local = DISABLED
Tue Sep 17 12:43:25 2019 us=733335   bind_ipv6_only = DISABLED
Tue Sep 17 12:43:25 2019 us=733452   connect_retry_seconds = 5
Tue Sep 17 12:43:25 2019 us=733570   connect_timeout = 120
Tue Sep 17 12:43:25 2019 us=733687   socks_proxy_server = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=737433   socks_proxy_port = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=739500   tun_mtu = 1500
Tue Sep 17 12:43:25 2019 us=742444   tun_mtu_defined = ENABLED
Tue Sep 17 12:43:25 2019 us=743937   link_mtu = 1500
Tue Sep 17 12:43:25 2019 us=744127   link_mtu_defined = DISABLED
Tue Sep 17 12:43:25 2019 us=744254   tun_mtu_extra = 0
Tue Sep 17 12:43:25 2019 us=746631   tun_mtu_extra_defined = DISABLED
Tue Sep 17 12:43:25 2019 us=747574   mtu_discover_type = -1
Tue Sep 17 12:43:25 2019 us=747742   fragment = 0
Tue Sep 17 12:43:25 2019 us=747868   mssfix = 1450
Tue Sep 17 12:43:25 2019 us=747993   explicit_exit_notification = 0
Tue Sep 17 12:43:25 2019 us=748113 Connection profiles END
Tue Sep 17 12:43:25 2019 us=748232   remote_random = DISABLED
Tue Sep 17 12:43:25 2019 us=748453   ipchange = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=748580   dev = 'tun'
Tue Sep 17 12:43:25 2019 us=748699   dev_type = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=748816   dev_node = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=748934   lladdr = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=749051   topology = 1
Tue Sep 17 12:43:25 2019 us=749167   ifconfig_local = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=749285   ifconfig_remote_netmask = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=749403   ifconfig_noexec = DISABLED
Tue Sep 17 12:43:25 2019 us=749518   ifconfig_nowarn = DISABLED
Tue Sep 17 12:43:25 2019 us=749634   ifconfig_ipv6_local = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=749752   ifconfig_ipv6_netbits = 0
Tue Sep 17 12:43:25 2019 us=749869   ifconfig_ipv6_remote = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=749986   shaper = 0
Tue Sep 17 12:43:25 2019 us=750101   mtu_test = 0
Tue Sep 17 12:43:25 2019 us=750216   mlock = DISABLED
Tue Sep 17 12:43:25 2019 us=750332   keepalive_ping = 10
Tue Sep 17 12:43:25 2019 us=750450   keepalive_timeout = 120
Tue Sep 17 12:43:25 2019 us=750567   inactivity_timeout = 0
Tue Sep 17 12:43:25 2019 us=750684   ping_send_timeout = 10
Tue Sep 17 12:43:25 2019 us=750801   ping_rec_timeout = 120
Tue Sep 17 12:43:25 2019 us=750916   ping_rec_timeout_action = 2
Tue Sep 17 12:43:25 2019 us=751032   ping_timer_remote = DISABLED
Tue Sep 17 12:43:25 2019 us=751150   remap_sigusr1 = 0
Tue Sep 17 12:43:25 2019 us=751265   persist_tun = DISABLED
Tue Sep 17 12:43:25 2019 us=751382   persist_local_ip = DISABLED
Tue Sep 17 12:43:25 2019 us=751501   persist_remote_ip = DISABLED
Tue Sep 17 12:43:25 2019 us=751619   persist_key = ENABLED
Tue Sep 17 12:43:25 2019 us=751734   passtos = DISABLED
Tue Sep 17 12:43:25 2019 us=751852   resolve_retry_seconds = 1000000000
Tue Sep 17 12:43:25 2019 us=751970   resolve_in_advance = DISABLED
Tue Sep 17 12:43:25 2019 us=752086   username = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=752204   groupname = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=752323   chroot_dir = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=752442   cd_dir = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=752562   writepid = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=752681   up_script = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=752801   down_script = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=752919   down_pre = DISABLED
Tue Sep 17 12:43:25 2019 us=753033   up_restart = DISABLED
Tue Sep 17 12:43:25 2019 us=753152   up_delay = DISABLED
Tue Sep 17 12:43:25 2019 us=753267   daemon = DISABLED
Tue Sep 17 12:43:25 2019 us=753384   inetd = 0
Tue Sep 17 12:43:25 2019 us=753501   log = DISABLED
Tue Sep 17 12:43:25 2019 us=753621   suppress_timestamps = DISABLED
Tue Sep 17 12:43:25 2019 us=753741   machine_readable_output = DISABLED
Tue Sep 17 12:43:25 2019 us=753859   nice = 0
Tue Sep 17 12:43:25 2019 us=753980   verbosity = 5
Tue Sep 17 12:43:25 2019 us=754100   mute = 0
Tue Sep 17 12:43:25 2019 us=754219   gremlin = 0
Tue Sep 17 12:43:25 2019 us=754337   status_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=754457   status_file_version = 1
Tue Sep 17 12:43:25 2019 us=754580   status_file_update_freq = 60
Tue Sep 17 12:43:25 2019 us=754698   occ = ENABLED
Tue Sep 17 12:43:25 2019 us=754819   rcvbuf = 0
Tue Sep 17 12:43:25 2019 us=754937   sndbuf = 0
Tue Sep 17 12:43:25 2019 us=755056   mark = 0
Tue Sep 17 12:43:25 2019 us=755174   sockflags = 0
Tue Sep 17 12:43:25 2019 us=755291   fast_io = DISABLED
Tue Sep 17 12:43:25 2019 us=755410   comp.alg = 0
Tue Sep 17 12:43:25 2019 us=755530   comp.flags = 0
Tue Sep 17 12:43:25 2019 us=755651   route_script = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=755774   route_default_gateway = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=755898   route_default_metric = 0
Tue Sep 17 12:43:25 2019 us=756015   route_noexec = DISABLED
Tue Sep 17 12:43:25 2019 us=756135   route_delay = 0
Tue Sep 17 12:43:25 2019 us=756256   route_delay_window = 30
Tue Sep 17 12:43:25 2019 us=756376   route_delay_defined = DISABLED
Tue Sep 17 12:43:25 2019 us=756498   route_nopull = DISABLED
Tue Sep 17 12:43:25 2019 us=756620   route_gateway_via_dhcp = DISABLED
Tue Sep 17 12:43:25 2019 us=756743   allow_pull_fqdn = DISABLED
Tue Sep 17 12:43:25 2019 us=756865   management_addr = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=756988   management_port = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=757109   management_user_pass = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=757234   management_log_history_cache = 250
Tue Sep 17 12:43:25 2019 us=757356   management_echo_buffer_size = 100
Tue Sep 17 12:43:25 2019 us=757481   management_write_peer_info_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=757604   management_client_user = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=757727   management_client_group = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=757852   management_flags = 0
Tue Sep 17 12:43:25 2019 us=757974   shared_secret_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=758095   key_direction = not set
Tue Sep 17 12:43:25 2019 us=758216   ciphername = 'AES-256-CBC'
Tue Sep 17 12:43:25 2019 us=761815   ncp_enabled = ENABLED
Tue Sep 17 12:43:25 2019 us=764250   ncp_ciphers = 'AES-256-GCM:AES-128-GCM'
Tue Sep 17 12:43:25 2019 us=766228   authname = 'SHA1'
Tue Sep 17 12:43:25 2019 us=769242   prng_hash = 'SHA1'
Tue Sep 17 12:43:25 2019 us=769467   prng_nonce_secret_len = 16
Tue Sep 17 12:43:25 2019 us=769604   keysize = 0
Tue Sep 17 12:43:25 2019 us=769727   engine = DISABLED
Tue Sep 17 12:43:25 2019 us=772792   replay = ENABLED
Tue Sep 17 12:43:25 2019 us=773016   mute_replay_warnings = DISABLED
Tue Sep 17 12:43:25 2019 us=773151   replay_window = 64
Tue Sep 17 12:43:25 2019 us=773276   replay_time = 15
Tue Sep 17 12:43:25 2019 us=775787   packet_id_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=776658   use_iv = ENABLED
Tue Sep 17 12:43:25 2019 us=776848   test_crypto = DISABLED
Tue Sep 17 12:43:25 2019 us=776977   tls_server = DISABLED
Tue Sep 17 12:43:25 2019 us=777100   tls_client = ENABLED
Tue Sep 17 12:43:25 2019 us=777223   key_method = 2
Tue Sep 17 12:43:25 2019 us=777345   ca_file = 'ca.crt'
Tue Sep 17 12:43:25 2019 us=777465   ca_path = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=777586   dh_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=777706   cert_file = 'client.crt'
Tue Sep 17 12:43:25 2019 us=777828   extra_certs_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=777952   priv_key_file = 'client.key'
Tue Sep 17 12:43:25 2019 us=778074   pkcs12_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=778198   cipher_list = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=782004   cipher_list_tls13 = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=783228   tls_cert_profile = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=783399   tls_verify = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=783522   tls_export_cert = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=783644   verify_x509_type = 0
Tue Sep 17 12:43:25 2019 us=783760   verify_x509_name = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=783880   crl_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=784000   ns_cert_type = 0
Tue Sep 17 12:43:25 2019 us=784121   remote_cert_ku[i] = 65535
Tue Sep 17 12:43:25 2019 us=784239   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=784356   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=784474   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=784591   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=784708   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=784826   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=784945   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=785065   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=785184   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=785304   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=785420   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=785537   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=785658   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=785779   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=785901   remote_cert_ku[i] = 0
Tue Sep 17 12:43:25 2019 us=786025   remote_cert_eku = 'TLS Web Server Authentication'
Tue Sep 17 12:43:25 2019 us=786147   ssl_flags = 0
Tue Sep 17 12:43:25 2019 us=786267   tls_timeout = 2
Tue Sep 17 12:43:25 2019 us=786388   renegotiate_bytes = -1
Tue Sep 17 12:43:25 2019 us=786506   renegotiate_packets = 0
Tue Sep 17 12:43:25 2019 us=786626   renegotiate_seconds = 3600
Tue Sep 17 12:43:25 2019 us=786750   handshake_window = 60
Tue Sep 17 12:43:25 2019 us=786871   transition_window = 3600
Tue Sep 17 12:43:25 2019 us=786991   single_session = DISABLED
Tue Sep 17 12:43:25 2019 us=787112   push_peer_info = DISABLED
Tue Sep 17 12:43:25 2019 us=787237   tls_exit = DISABLED
Tue Sep 17 12:43:25 2019 us=787364   tls_auth_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=787490   tls_crypt_file = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=787620   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=787751   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=787877   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=788001   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=788123   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=789337   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=790926   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=793443   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=796171   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=798780   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=800166   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=800354   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=800482   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=800606   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=800731   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=800855   pkcs11_protected_authentication = DISABLED
Tue Sep 17 12:43:25 2019 us=800981   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=801103   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=802584   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=805188   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=806606   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=806799   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=806930   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=811143   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=811385   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=811521   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=811647   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=811772   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=811895   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=812021   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=812145   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=812267   pkcs11_private_mode = 00000000
Tue Sep 17 12:43:25 2019 us=812389   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=812511   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=812632   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=812753   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=812872   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=812994   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=813115   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=813238   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=813359   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=813481   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=813599   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=813718   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=813840   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=813961   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=814081   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=814203   pkcs11_cert_private = DISABLED
Tue Sep 17 12:43:25 2019 us=814325   pkcs11_pin_cache_period = -1
Tue Sep 17 12:43:25 2019 us=814446   pkcs11_id = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=814567   pkcs11_id_management = DISABLED
Tue Sep 17 12:43:25 2019 us=814700   server_network = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=814871   server_netmask = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=815094   server_network_ipv6 = ::
Tue Sep 17 12:43:25 2019 us=815230   server_netbits_ipv6 = 0
Tue Sep 17 12:43:25 2019 us=815367   server_bridge_ip = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=815543   server_bridge_netmask = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=815689   server_bridge_pool_start = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=815826   server_bridge_pool_end = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=815951   ifconfig_pool_defined = DISABLED
Tue Sep 17 12:43:25 2019 us=816080   ifconfig_pool_start = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=816211   ifconfig_pool_end = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=816343   ifconfig_pool_netmask = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=816465   ifconfig_pool_persist_filename = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=816589   ifconfig_pool_persist_refresh_freq = 600
Tue Sep 17 12:43:25 2019 us=816712   ifconfig_ipv6_pool_defined = DISABLED
Tue Sep 17 12:43:25 2019 us=816840   ifconfig_ipv6_pool_base = ::
Tue Sep 17 12:43:25 2019 us=816960   ifconfig_ipv6_pool_netbits = 0
Tue Sep 17 12:43:25 2019 us=817081   n_bcast_buf = 256
Tue Sep 17 12:43:25 2019 us=817198   tcp_queue_limit = 64
Tue Sep 17 12:43:25 2019 us=817317   real_hash_size = 256
Tue Sep 17 12:43:25 2019 us=817437   virtual_hash_size = 256
Tue Sep 17 12:43:25 2019 us=817560   client_connect_script = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=817683   learn_address_script = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=817803   client_disconnect_script = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=817924   client_config_dir = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=818042   ccd_exclusive = DISABLED
Tue Sep 17 12:43:25 2019 us=818159   tmp_dir = '/tmp'
Tue Sep 17 12:43:25 2019 us=819522   push_ifconfig_defined = DISABLED
Tue Sep 17 12:43:25 2019 us=821117   push_ifconfig_local = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=823461   push_ifconfig_remote_netmask = 0.0.0.0
Tue Sep 17 12:43:25 2019 us=824913   push_ifconfig_ipv6_defined = DISABLED
Tue Sep 17 12:43:25 2019 us=826411   push_ifconfig_ipv6_local = ::/0
Tue Sep 17 12:43:25 2019 us=827898   push_ifconfig_ipv6_remote = ::
Tue Sep 17 12:43:25 2019 us=829428   enable_c2c = DISABLED
Tue Sep 17 12:43:25 2019 us=829717   duplicate_cn = DISABLED
Tue Sep 17 12:43:25 2019 us=830605   cf_max = 0
Tue Sep 17 12:43:25 2019 us=831483   cf_per = 0
Tue Sep 17 12:43:25 2019 us=831751   max_clients = 1024
Tue Sep 17 12:43:25 2019 us=832593   max_routes_per_client = 256
Tue Sep 17 12:43:25 2019 us=833774   auth_user_pass_verify_script = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=834060   auth_user_pass_verify_script_via_file = DISABLED
Tue Sep 17 12:43:25 2019 us=834920   auth_token_generate = DISABLED
Tue Sep 17 12:43:25 2019 us=835185   auth_token_lifetime = 0
Tue Sep 17 12:43:25 2019 us=836100   port_share_host = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=836728   port_share_port = '[UNDEF]'
Tue Sep 17 12:43:25 2019 us=837263   client = ENABLED
Tue Sep 17 12:43:25 2019 us=837515   pull = ENABLED
Tue Sep 17 12:43:25 2019 us=838028   auth_user_pass_file = 'auth.cfg'
Tue Sep 17 12:43:25 2019 us=838683 OpenVPN 2.4.7 arm-unknown-linux-gnueabihf [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Feb 20 2019
Tue Sep 17 12:43:25 2019 us=839288 library versions: OpenSSL 1.1.1c  28 May 2019, LZO 2.10
Tue Sep 17 12:43:25 2019 us=858211 Control Channel MTU parms [ L:1623 D:1210 EF:40 EB:0 ET:0 EL:3 ]
Tue Sep 17 12:43:25 2019 us=860078 Data Channel MTU parms [ L:1623 D:1450 EF:123 EB:406 ET:0 EL:3 ]
Tue Sep 17 12:43:25 2019 us=861786 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1559,tun-mtu 1500,proto TCPv4_CLIENT,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client'
Tue Sep 17 12:43:25 2019 us=863026 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1559,tun-mtu 1500,proto TCPv4_SERVER,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-server'
Tue Sep 17 12:43:25 2019 us=863914 TCP/UDP: Preserving recently used remote address: [AF_INET]195.211.173.40:1194
Tue Sep 17 12:43:25 2019 us=864766 Socket Buffers: R=[87380->87380] S=[16384->16384]
Tue Sep 17 12:43:25 2019 us=865547 Attempting to establish TCP connection with [AF_INET]195.211.173.40:1194 [nonblock]
Tue Sep 17 12:43:26 2019 us=866875 TCP connection established with [AF_INET]195.211.173.40:1194
Tue Sep 17 12:43:26 2019 us=867177 TCP_CLIENT link local: (not bound)
Tue Sep 17 12:43:26 2019 us=867380 TCP_CLIENT link remote: [AF_INET]195.211.173.40:1194
WRTue Sep 17 12:43:26 2019 us=871346 TLS: Initial packet from [AF_INET]195.211.173.40:1194, sid=039d0e00 a6e6eb7a
WRTue Sep 17 12:43:26 2019 us=880075 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
WRRWRTue Sep 17 12:43:27 2019 us=514680 VERIFY OK: depth=1, C=US, ST=CA, L=SanFrancisco, O=OpenVPN, OU=changeme, CN=changeme, name=changeme, emailAddress=mail@host.domain
Tue Sep 17 12:43:27 2019 us=520961 VERIFY KU OK
Tue Sep 17 12:43:27 2019 us=523695 Validating certificate extended key usage
Tue Sep 17 12:43:27 2019 us=526951 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Tue Sep 17 12:43:27 2019 us=530391 VERIFY EKU OK
Tue Sep 17 12:43:27 2019 us=532291 VERIFY OK: depth=0, C=US, ST=CA, L=SanFrancisco, O=OpenVPN, OU=changeme, CN=sfasgadgdhadhad, name=changeme, emailAddress=mail@host.domain
WRWWWRRRRWRRWTue Sep 17 12:43:28 2019 us=599697 Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 1024 bit RSA
Tue Sep 17 12:43:28 2019 us=601842 [sfasgadgdhadhad] Peer Connection Initiated with [AF_INET]195.211.173.40:1194
Tue Sep 17 12:43:29 2019 us=703703 SENT CONTROL [sfasgadgdhadhad]: 'PUSH_REQUEST' (status=1)
WRTue Sep 17 12:43:34 2019 us=818381 SENT CONTROL [sfasgadgdhadhad]: 'PUSH_REQUEST' (status=1)
WRTue Sep 17 12:43:39 2019 us=931266 SENT CONTROL [sfasgadgdhadhad]: 'PUSH_REQUEST' (status=1)
WRRTue Sep 17 12:43:40 2019 us=44605 PUSH: Received control message: 'PUSH_REPLY,ping 20,ping-restart 60,topology subnet,route-gateway 192.168.88.1,ifconfig 192.168.88.19 255.255.255.0'
Tue Sep 17 12:43:40 2019 us=46611 OPTIONS IMPORT: timers and/or timeouts modified
Tue Sep 17 12:43:40 2019 us=48425 OPTIONS IMPORT: --ifconfig/up options modified
Tue Sep 17 12:43:40 2019 us=48675 OPTIONS IMPORT: route-related options modified
Tue Sep 17 12:43:40 2019 us=48979 Data Channel MTU parms [ L:1559 D:1450 EF:59 EB:406 ET:0 EL:3 ]
Tue Sep 17 12:43:40 2019 us=50335 Outgoing Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Tue Sep 17 12:43:40 2019 us=50635 Outgoing Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Sep 17 12:43:40 2019 us=50875 Incoming Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Tue Sep 17 12:43:40 2019 us=51145 Incoming Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue Sep 17 12:43:40 2019 us=112195 ERROR: Cannot ioctl TUNSETIFF tun: Operation not permitted (errno=1)
Tue Sep 17 12:43:40 2019 us=112487 Exiting due to fatal error
