I have a problem with my Pi 4 and my wireless keyboards, a Logitech 540 KB&M and the Canakit Oval micro KB&Pad, dropping and repeating characters when I use a TP Link 722 Wifi Adaptor. I have tried the Solaar Logitech driver and putting the dongles on a USB extension cable, using a 4 port hub and nothing helps.
I am wondering if there are any error log files or status report commands that would help me track down the problem. I am not a tech, but I have four decades of expirence so I understand the basics.
There are no problems with the same gear on the Pi 3, running Stretch. I have not tried upgrading the Pi 3 to Buster yet to see if it has the same problems.
Later Edit:
After looking into how to format an old SD and copy Noobs over and getting confused, I just put the orginal Noobs SD that I installed Buster from, and later copied to a 120gb SD, into my Pi 3 and booted it. It works perfect, with the software I had installed before I coppied it over, on the Pi 4.
AND... the KB&M and Wifi work perfectly as well. The issue is with the Pi 4 HARDWARE, not the OS or settings or the KBs and Wifi. There is something wrong with the USB on Pi 4, if the same software and perifierals on the Pi 3 work perfect.
I wonder what that means and how do I get that fixed?
