Lawrence_craig
Pi4 not seeing HDDs attached to HUB
Mon Sep 16, 2019 7:06 am
Hi all,
Probably a quick solve problem but cannot find anything on this issue.
My Pi4 recognises my 2 x HDDs when attached directly to the device.
However when I then connect them to a powered Hub, they are not recognised by the Pi.
The hub is USB 2.0 and a specific one for the Pi (made by PiHut).
DMSG identifies the hub but not the HDDs.
Any thoughts?
Last edited by Lawrence_craig on Mon Sep 16, 2019 10:11 am, edited 1 time in total.
LTolledo
Re: Pi4 not seeing HDDs attached to HUB
Mon Sep 16, 2019 9:55 am
there are some USB3.0 hubs that dont work well with the RPi, you could have gotten the "unlucky" one.
could be a typo on your part
"...connect them to a powered HDD..."
should have been
"...connect them to a powered USB hub..."
are your HDDs self powered (12v) or bus powered?
Some people be like:
Lawrence_craig
Mon Sep 16, 2019 10:12 am
Thanks for the reply.
I have edited my original post.
The USB hub is 2.0 and is powered. It’s one made for the Pi (all worked ok on Pi3B).
Atari2020
Mon Sep 16, 2019 10:22 pm
Which ports are you using on the Pi 4 when you connect the HDDs? Have you used the drives on a Hub with a Pi 3?
Lawrence_craig
Tue Sep 17, 2019 7:45 am
I have tried both the 2.0 and 3.0 ports on the Pi (and no other devices attached). Yes, it worked on the Pi3 no problem.
Lawrence_craig
Tue Sep 17, 2019 10:18 am
Also, just to add, it's not just the HDDs that the Pi fails to see connected to the hub, it's also other things like a USB pen drive.
DMESG gives this:
[    1.123167] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[    1.123182] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.123194] usb 1-1: Product: USB2.0 Hub
[    1.124735] hub 1-1:1.0: USB hub found
[    1.124995] hub 1-1:1.0: 4 ports detected
So it is seeing the hub, just nothing attached to it.
jdb
Tue Sep 17, 2019 10:57 am
Is it just a problem with this particular hub?
Do you have a different USB2.0 hub to test (with the pendrive, since that's a less demanding device in comparison to a HDD).
Rockets are loud.
https://astro-pi.org
Lawrence_craig
Tue Sep 17, 2019 11:10 am
Strangely, I think it’s the USB Hub that has failed. I connected to another laptop and it isn’t recognising the usb devices either. Thanks for all the help anyway.
