beshur
Pi not getting IPv4 address, though I can connect via ssh
Sun Sep 15, 2019 2:51 pm
Hello.
I'm bulding a project with Pi Musicbox on 3B+.
Everything worked fine for 3 months until last night, when it mysteriously stopped getting an IPv4 address from my router.
Sometimes it still connects, but the router does not even display it in the list of clients, but I'm able to connect via ssh using hostname (musicbox.local).
How do I troubleshoot it?
I have an arduino on usb, and a button and a rotary encoder over GPIO.
Andyroo
Re: Pi not getting IPv4 address, though I can connect via ssh
Sun Sep 15, 2019 3:02 pm
Once you are on the Pi can you issue
ifconfig
in the terminal - this will show you the IP details.
My guess is the router needs the classic IT solution (off and on again).
beshur
Sun Sep 15, 2019 3:40 pm
ifconfig
Thanks for suggestion.
However, I tried `ifconfig` and there I see no IPv4 address, only IPv6.
Tried on/off as well.
Andyroo
Sun Sep 15, 2019 4:02 pm
You could have IPv4 disabled or the DHCP server is not giving out addresses...
May be worth checking the contents of /etc/dhcpcd.conf
What version of the OS are you running?
beshur
Sun Sep 15, 2019 4:05 pm
Nevermind, resolved for now, by installing a fresh slate of raspbian on another SD card.
Andyroo
Sun Sep 15, 2019 4:22 pm
Bit of a sledgehammer trick that one :lol:
Then again, its not a real job without using a hammer...
Glad you're going - shout if stuck again.
