Failed to start Backend server for 1-wire control
Posted: Sat Sep 14, 2019 8:03 pm
by micksulley
I have just done a fresh install of Buster and updated. I ran raspi-config and enabled 1-wire and i2c.
I have installed owserver ow-shell
At first it worked, I could see devices with owdir, but it has stopped working, owdir returns nothing
I have run "sudo systemctl enable owserver.service"
but I see -
[email protected]:~ $ sudo systemctl status owserver.service
● owserver.service - Backend server for 1-wire control
   Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled)
   Active: failed (Result: protocol) since Fri 2019-09-13 21:47:16 BST; 48s ago
     Docs: man:owserver(1)
 Main PID: 493 (code=exited, status=0/SUCCESS)
Sep 13 21:47:16 pi-solar-old systemd[1]: owserver.service: Service RestartSec=100ms expired, scheduling
Sep 13 21:47:16 pi-solar-old systemd[1]: owserver.service: Scheduled restart job, restart counter is at
Sep 13 21:47:16 pi-solar-old systemd[1]: Stopped Backend server for 1-wire control.
Sep 13 21:47:16 pi-solar-old systemd[1]: owserver.service: Start request repeated too quickly.
Sep 13 21:47:16 pi-solar-old systemd[1]: owserver.service: Failed with result 'protocol'.
Sep 13 21:47:16 pi-solar-old systemd[1]: Failed to start Backend server for 1-wire control.
I have edited /boot/config.txt the only active lines are
dtparam=i2c_arm=on
dtparam=audio=on
[pi4]
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
dtoverlay=w1-gpio
dtparam=i2c1=on
Restarting owserver gives me
[email protected]:~ $ sudo systemctl restart owserver
Job for owserver.service failed because the service did not take the steps required by its unit configuration.
See "systemctl status owserver.service" and "journalctl -xe" for details.
I have no idea what to do next, can anyone help please?
Mick
Re: Failed to start Backend server for 1-wire control
Posted: Sat Sep 14, 2019 9:08 pm
by d_older
Hi Mick,
I did this a couple of nights ago on a ZeroW with Buster and got the same/very similar results (for a DS9490 USB controller).
After going through the "systemctl enable / start / stop/ disable" options I couldn't find anything obviously wrong.
I also couldn't find any solutions by searching.
However after leaving it enabled through probably about 5 or 6 boot it now starts reliably - no real idea why - my only suspicion is that its initialisation is based on init.d and it seems to take a couple of boot cycles to get the "automagic" conversion right.
Hope this helps,
Dave
Posted: Sat Sep 14, 2019 10:40 pm
by micksulley
Thanks for the reply Dave, at least it is not just me:)
I have just rebooted a couple of times, made no difference. I also tried reinstalling owserver and it shows an error -
[email protected]:~ $ sudo apt-get reinstall owserver
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  rpi.gpio-common
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/30.8 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 38870 files and directories currently installed.)
Preparing to unpack .../owserver_3.2p3+dfsg1-2_armhf.deb ...
Unpacking owserver (3.2p3+dfsg1-2) over (3.2p3+dfsg1-2) ...
Setting up owserver (3.2p3+dfsg1-2) ...
invoke-rc.d: initscript owserver, action "restart" failed.
   Active: activating (auto-restart) (Result: protocol) since Sat 2019-09-14 23:26:25 BST; 61ms ago
  Process: 601 ExecStart=/usr/bin/owserver -c /etc/owfs.conf (code=exited, status=0/SUCCESS)
 Main PID: 601 (code=exited, status=0/SUCCESS)
dpkg: error processing package owserver (--configure):
 installed owserver package post-installation script subprocess returned error exit status 1
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for systemd (241-7~deb10u1+rpi1) ...
 owserver
E: Sub-process /usr/bin/dpkg returned an error code (1)
I have removed owserver and then installed again, this time it installed without the error message, but status still shows backend server not started and owdir does not work.
Any other ideas?
Re: Failed to start Backend server for 1-wire control - Fixed
Posted: Sun Sep 15, 2019 6:13 pm
by micksulley
OK I think I have fixed it. Looks like my /etc/owfs.conf file was screwed up. I was expecting it to have the default file with the fake server, but that wasn't there. I deleted that and created a new one and it is working again.
Posted: Fri Nov 29, 2019 7:55 pm
by nattila
Hi Mick,
Could you please describe detailed how did you created a new conf file? It would help me a lot.
thanks
Posted: Mon Dec 02, 2019 9:56 am
by micksulley
Sorry I had missed this post.
I am running with a Sheepwalk adapter. A basic config file (/etc/owfs.conf) is
! server: server = localhost:4304
server: device=/dev/i2c-1 # for modern Pi's, very early ones use i2c-0
You can also test with a fake adapter with
server: fake=10.053C8A010800,10.2AFE89010800,10.90F889010800
where the id's can be anything and it reports random value reads.
There is a good startup guide on the Sheepwalk site
https://www.sheepwalkelectronics.co.uk/ ... ftware.php
Best of luck!
