wayne.mac
Pi 4 speedtest.net much slower than iperf3 over GigE port
Wed Sep 11, 2019 8:46 am
I am busy with fast internet tests (over 5G 3GPP) and want to use the Pi4 over remote connection to run throughput test remotely. Unfortunately I have hit a problem that the https://www.speedtest.net/ throughput results are significantly lower that those obtained using iperf3.
[*]- 400Mbps or more using iperf3
[*]- <100Mbps using https://www.speedtest.net/
[*]- 700-945Mbps using iperf direct cable connection
Any help to solve this issue will be greatly appreciated.
Re: Pi 4 speedtest.net much slower than iperf3 over GigE port
Wed Sep 11, 2019 12:33 pm
I am busy with fast internet tests (over 5G) and want to use the Pi4 over remote connection to run throughput test remotely. Unfortunately I have hit a problem that the https://www.speedtest.net/ throughput results are significantly lower that those obtained using iperf3.
Try speedtest-cli the command line version, it is in the repositories ?
This forum has many posts stating Speedtest web page gives inconsistent results....
RPi 4B 4GB (SSD Boot)..
wayne.mac
Wed Sep 11, 2019 3:56 pm
Yes, sure the results are inconsistent.....But not lower than a factor of 4x compared to a USB boot Linux PC....consistently.
B.Goode
Wed Sep 11, 2019 5:15 pm
Are you comparing like-with-like here?
Is the remote site being used for the iperf3 test the same one as used by speedtest?
Does 5G denote a WiFi technology, or a 'cellphone' technology?
For most domestic users (things might be different for business or institutional networks) I would expect that 'external' Internet throughput would be lower than the non-routed throughput of an 'internal' device-to-device connection.
My limited understanding of 5G mobile networks is that they are not always faster: speed can be traded for reach and reliability.
wayne.mac
Thu Sep 12, 2019 6:08 pm
Below is the result from iperf3 command and a snapshot of the speedtest result.
Result: Iperf3 receives at 354 Mbps vs 61 Mbps on speedtest.net.
[ ID] Interval           Transfer     Bitrate         Jitter    Lost/Total Datagrams
[  5]   0.00-120.00 sec  16.8 GBytes  1.20 Gbits/sec  0.000 ms  0/13270505 (0%)  sender
[SUM]  0.0-120.0 sec  802670 datagrams received out-of-order
[  5]   0.00-120.00 sec  4.93 GBytes   353 Mbits/sec  0.023 ms  9346325/13270505 (70%)  receiver
