Roken
motion(eye) losing cameras
Tue Sep 10, 2019 8:16 pm
I know I had this first time around, and have no idea how I fixed it (previously Stretch, now Buster).
I have a 3B+ with two HP webcams attached, and motioneye installed. The boot is a little unusual, since the 3B+ boots from an NFS drive attached to a 4B. Booting is fine, and the OS runs well. There are two other 3B+ and one 3B booting from the same NFS drive. No problems. (Each serves a different purpose).
The problematic system has a VPN and motioneye installed. The problem is motioneye will just lose the cameras after a while. The cameras are still visible to the OS, as can be seen:
[email protected]:~ $ lsusb
Bus 001 Device 088: ID 03f0:e207 HP, Inc
Bus 001 Device 087: ID 03f0:e207 HP, Inc
Bus 001 Device 006: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
The top two entries are the cameras. They also work to start, but then seem to get bored and just shut down. I can manually reconfigure the cameras in motioneye to get them back for a while, before they die again.
What is going on.
NB. I've ruled out power. I get the same with a single camera on a known good power supply (POE 5V 2.5A),
