timg236
Re: VLI firmware v2.0 - powersaving features enabled
Thu Oct 24, 2019 9:59 am
soundcheck wrote:
Thu Oct 24, 2019 7:18 am
Hi.
Great news about the combined eeprom/VL package.
Just tested it.
#rpi-eeprom-update
Bootloader EEPROM is up to date
BOOTLOADER
CURRENT: Tue Sep 10 10:41:50 UTC 2019 (1568112110)
LATEST: Tue Sep 10 10:41:50 UTC 2019 (1568112110)
VL805
CURRENT: 000137ab
LATEST: 000137ab
Comment:
It still says
"Bootloader EEPROM is up to date" ??
How about
"EEPROMs up to date"
or adding
"VL805 EEPROM is up to date"
or simply
EEPROMs
BOOTLOADER  up-to-date
VL805  up-to-date
 CURRENT: 000137ab
 LATEST: 000137ab
That'll make maintenance checks a bit easier and looks consistent.
For automated checks I'd recommend using the machine interface (-j -m eeprom-status.json). LibreElec uses this to display the EEPROM status in the UI.
Will look at the status message.
soundcheck
Thu Oct 24, 2019 11:42 am
While you're at it.
Not sure if this is the right place.
Some more comments. Call it pedantics.
* I think the script (rpi-eeprom-update) needs to get a bit more hardened.
You don't check if "all" the userland tools (vcmailbox etc) are actually available.
* Since now you combine all eeprom firmware you might consider to change your paths and terminology accordingly:
To e.g. /lib/firmware/raspberrypi/eeprom >>> instead of "../bootloader"
* And then I was asking myself why "critical" and "beta" firmware ?? critical sounds critical. :D
Why not using a pretty much industry standard: "stable" vs. "beta"?
That was pretty much it.
Now, at this early state, it's the time to touch above. Later on you and all the integrators will have to carry that bag. ;)
Anyhow. Great work. Highly appreciated.
____________________________________________________________________________________
RPi 4 B - RPI Kernel 64 - Raspbian 32 | Arch Linux ARM 64
timg236
Thu Oct 24, 2019 12:24 pm
While you're at it.
Thanks for the feedback, I'll add a check for vcmailbox, btw USE_FLASHROM is really just for reference. It's not possible to guarantee that the SPI pins are available (HATs) and that analog audio has not in use (EEPROM CS muxed with analog audio). So basically, use at your own risk.
I think it's too late to rename the sub-directories now, in future the VL805 bin may be rolled into the bootloader image allowing me to revert all the script complexity required to handle two different EEPROMs :)
Critical updates include major fixes for hardware compatibility, power management and security and would be rolled out automatically to all users/boards who haven't opted out of firmware updates because it's not realistic to expect everyone to know whether or not to apply an update or even what an EEPROM or bootloader is.
I think 'stable' will probably get used when advanced-boot modes (e.g. network boot) are out of beta. Eventually stable would get promoted to critical to reduce the number of versions for support but that has to be balanced with the 'if it ain't broke don't fix it' rule.
soundcheck
Thu Oct 24, 2019 12:36 pm
Thx a lot for the feedback.
robinkoehler
Sat Nov 02, 2019 7:23 am
Thank you kindly for making this available!
I have noticed some strange issues after updating.
Raspberry Pi 4, 4gb
External USB3 Hub (backpowering the Pi)
GIMX board plugged into PS4 (apparently also backpowering the Pi)
TV LED backlight driven by Hyperion / GPIO pins 19 for DI and 23 for CK
I can now finally sudo reboot without having to unplug the USB3 hub, yay! The new firmware however messes with the LEDs at the back of my TV (ambilight DIY clone). It seems that the new firmware "pulses" through different power saving states, and every time it does (1-3 seconds?), the LEDs become dimmer as well.
1) How would the new firmware impact the SPI voltage?
2) Is there a version of the firmware that still offers the benefits of the Pi not hanging during reboot, however disables the power saving features altogether?
Here is my lsusb output, showing the connected devices:
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 0bc2:231a Seagate RSS LLC Expansion Portable
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 004: ID 1b71:3002 Fushicai USBTV007 Video Grabber [EasyCAP]
Bus 001 Device 007: ID 054c:05c4 Sony Corp. DualShock 4 [CUH-ZCT1x]
Bus 001 Device 005: ID 0bc2:2300 Seagate RSS LLC Expansion Portable
Bus 001 Device 003: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Thank you in advance,
Robin
iEvgeny
Sat Nov 02, 2019 1:31 pm
Hi all!
After update to the last firmware i have a problem with bandwidth of USB webcams.
I use two USB webcams:
  1. First cam - stream h264 1280x720, 30 fps, ≈4000 kb/s
  2. Second cam - rawvideo 640x480, 30 fps, 147456 kb/s
If connect any one camera to the Raspberry Pi 4, everything will behaves as expected. But if connect both cams, ffmpeg can't capture any stream.
There are no reports of power problems in the log...
The following command fixes it:
sudo setpci -s 01:00.0 0xD4.B=0x41
Is it a firmware bug or a specific behavior for power saving?
trejan
Sat Nov 02, 2019 2:21 pm
You sure you're using the latest firmware? What version of the firmware are you using? There were severe throughput issues on the old versions but 000137ab should be okay. There is a slight performance penalty but not as bad as the early test version.
iEvgeny
Sat Nov 02, 2019 7:06 pm
Absolutely.
[email protected]:~ $ sudo rpi-eeprom-update
BOOTLOADER: up-to-date
CURRENT: Tue 10 Sep 10:41:50 UTC 2019 (1568112110)
 LATEST: Tue 10 Sep 10:41:50 UTC 2019 (1568112110)
VL805: up-to-date
CURRENT: 000137ab
 LATEST: 000137ab
Also, the rollback to the firmware v00013701 fixes this problem.
I think the problem is connecting multiple cameras. If I lower the bandwidth requirements for the second camera by half, the devices will still not be able to work simultaneously.
jdb
Sat Nov 02, 2019 7:41 pm
Wierd. I would expect performance degradation (in the off-chance we've not explored some set of wakeup latency/servicing interval required by the cams) and not a complete failure.
Can you capture an xhci debug trace?
sudo -s
cd /sys/kernel/debug/tracing
echo 1 > events/xhci-hcd/enable
[Plug device(s) in]
[Run the command that doesn't work as expected]
[Disconnect device]
cat trace > /home/pi/some-sensible-filename.txt
The trace is going to be large, so it may be better to upload somewhere like a github gist.
To clear a previous trace (events will still be enabled):
# echo > /sys/kernel/debug/tracing/trace
Also, you may want to do this without any other USB devices attached. Keyboards and mice will generate dozens of events per second which is tedious to sift through.
Rockets are loud.
https://astro-pi.org
jdoscher
Sat Nov 02, 2019 9:14 pm
The setpci command worked for me, and I had a similar issue with two 4K webcams getting throttled from USB3 to USB2. Directly connected, no hub, etc. My thread is here:
https://www.raspberrypi.org/forums/view ... 0#p1560660
iEvgeny
Sun Nov 03, 2019 10:45 am
I don't think this is a complete failure. With reduced bandwidth requirements, I can sometimes capture individual frames. I believe that this is a strong degradation.
I have prepared two traces for you:
  1. Only what you asked for
  2. Additionally called the setpci ...0x41 command before the end of the debug
jdb
Mon Nov 04, 2019 9:50 am
Which model of webcam(s) do the traces correspond to?
Edit: the second trace only has a single active endpoint transferring data. Are both cameras being used/working?
Edit2: github truncated the trace. The raw download is complete.
Rockets are loud.
jdb
Mon Nov 04, 2019 11:46 am
In the case where it goes wrong, there are multiple successful transfers from both cameras and then it seems to fall apart:
    <idle>-0     [000] d.h.   308.914257: xhci_handle_event: EVENT: TRB 000000001edc4890 status 'Short Packet' len 3060 slot 3 ep 3 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914261: xhci_handle_event: EVENT: TRB 000000001edc7100 status 'Short Packet' len 1588 slot 2 ep 5 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914265: xhci_handle_event: EVENT: TRB 000000001edc48a0 status 'Short Packet' len 3060 slot 3 ep 3 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914268: xhci_handle_event: EVENT: TRB 000000001edc7110 status 'Short Packet' len 1588 slot 2 ep 5 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914272: xhci_handle_event: EVENT: TRB 000000001edc48b0 status 'Short Packet' len 1532 slot 3 ep 3 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914276: xhci_handle_event: EVENT: TRB 000000001edc7120 status 'Short Packet' len 1588 slot 2 ep 5 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914280: xhci_handle_event: EVENT: TRB 000000001edc48c0 status 'Short Packet' len 652 slot 3 ep 3 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914283: xhci_handle_event: EVENT: TRB 000000001edc7130 status 'Short Packet' len 1588 slot 2 ep 5 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914287: xhci_handle_event: EVENT: TRB 000000001edc48d0 status 'Short Packet' len 596 slot 3 ep 3 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914291: xhci_handle_event: EVENT: TRB 0000000000000000 status 'Missed Service Error' len 0 slot 2 ep 5 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914293: xhci_handle_event: EVENT: TRB 000000001edc48e0 status 'Short Packet' len 1004 slot 3 ep 3 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914296: xhci_handle_event: EVENT: TRB 000000001edc7150 status 'Short Packet' len 1588 slot 2 ep 5 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914309: xhci_handle_event: EVENT: TRB 000000001edc48f0 status 'Short Packet' len 4 slot 3 ep 3 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914313: xhci_handle_event: EVENT: TRB 000000001edc7160 status 'Short Packet' len 1588 slot 2 ep 5 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914316: xhci_handle_event: EVENT: TRB 000000001edc4900 status 'USB Transaction Error' len 3072 slot 3 ep 3 type 'Transfer Event' flags e:c
          <idle>-0     [000] d.h.   308.914320: xhci_handle_event: EVENT: TRB 000000001edc7170 status 'USB Transaction Error' len 1600 slot 2 ep 5 type 'Transfer Event' flags e:c
Note the truncated packet lengths and then a "missed service error", followed by a dribble of more completed packets. After the first "USB transaction error" message appears, there are no further successful transfers from either endpoint.
In the broken state (i.e. after you've had a failure transferring data from both cameras), what's the state of the PCIe link? Please post the output of sudo lspci -vvv.
Rockets are loud.
iEvgeny
Mon Nov 04, 2019 4:17 pm
  1. First Cam (AliExpress No Name)
  2. Second Cam (AliExpress No Name)
Unfortunately, the camera microcontroller does not have markings: https://imgur.com/lJNM3UA
Command output stdout+stderr
jdb
Tue Nov 05, 2019 10:56 am
Troubleshooting noname USB webcams isn't going to be possible - unless there's a generic issue with the transport protocol in question.
That's not the output of the lspci command. It does however confirm that both cameras are UVC compliant devices so it should be reproducible with two other ones.
Rockets are loud.
iEvgeny
Tue Nov 05, 2019 11:04 am
Sorry...
$ sudo lspci -vvv
00:00.0 PCI bridge: Broadcom Limited Device 2711 (rev 10) (prog-if 00 [Normal decode])
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 53
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 00000000-00000fff
        Memory behind bridge: f8000000-f80fffff
        Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [48] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [ac] Express (v2) Root Port (Slot-), MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0
                        ExtTag- RBE+
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                        ClockPM+ Surprise- LLActRep- BwNot+ ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt+
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
                RootCap: CRSVisible+
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via WAKE# ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
        Capabilities: [180 v1] Vendor Specific Information: ID=0000 Rev=0 Len=028 <?>
        Capabilities: [240 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=8us PortTPowerOnTime=10us
                L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
                           T_CommonMode=1us LTR1.2_Threshold=0ns
                L1SubCtl2: T_PwrOn=10us
        Kernel driver in use: pcieport
01:00.0 USB controller: VIA Technologies, Inc. VL805 USB 3.0 Host Controller (rev 01) (prog-if 30 [XHCI])
        Subsystem: VIA Technologies, Inc. VL805 USB 3.0 Host Controller
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 54
        Region 0: Memory at 600000000 (64-bit, non-prefetchable) [size=4K]
        Capabilities: [80] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot-,D3cold+)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [90] MSI: Enable+ Count=1/4 Maskable- 64bit+
                Address: 0000000ffffffffc  Data: 6540
        Capabilities: [c4] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <16us
                        ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR-, OBFF Not Supported
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis+
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
        Kernel driver in use: xhci_hcd
wcndave
Tue Nov 05, 2019 11:34 am
I have not seen any posts saying what I am about to say, so I hope I've just done something wrong.... but I can't see what.
I have installed the "ab" version, exactly as per instructions:
Pi4-LibreELEC:~ # ./vl805
VL805 FW version: 000137ab
The pi is now idling at 7 degrees hotter...
I have two USB devices plugged in, a keyboard, and a FLIRC.
Device is running LibreElec/Kodi, however idle, CPU is 90% idle.
With heatsink only, my temps increased from 64 to 71
with fan running at 50% PWM, temp increased from 49 to 58
Reverted to older version, idle temp now back to 64.
PhilE
Tue Nov 05, 2019 11:39 am
It should go without saying, but that's not the expected behaviour. The flashing process includes a verification phase, but you can explicitly verify the EEPROM contents with "./vl805 -v vl805_fw_0137ab.bin" (which will need a "sudo" if you aren't already running as root).
wcndave
Tue Nov 05, 2019 1:17 pm
PhilE wrote: It should go without saying, but that's not the expected behaviour. The flashing process includes a verification phase, but you can explicitly verify the EEPROM contents with "./vl805 -v vl805_fw_0137ab.bin" (which will need a "sudo" if you aren't already running as root).
Yes, quite. I ran the verification, and get an all clear response:
VL805 EEPROM data verified
PhilE
Tue Nov 05, 2019 1:18 pm
<insert expression of bafflement>
jdb
Tue Nov 05, 2019 1:21 pm
Does the same temperature rise happen with no USB devices plugged in?
Rockets are loud.
iEvgeny
Tue Nov 05, 2019 2:02 pm
Unfortunately, I do not have other information, but I still do not think that this is a problem with the cameras. These models were used by me on various devices without any problems. Including on Raspberry Pi 4 before updating the firmware...
A little later I will try to reproduce the problem with Logitech cameras.
wcndave
Tue Nov 05, 2019 7:12 pm
Right, I tried it again, and a different (and better) result I think.
I was doing stress and cooling testing, when I came upon this update. I had an idle heatsink only temp of 64.
I did the FW update, and it jumped to 71 right there and then.
I did the reboot, which was fine, and it stayed at 71
I then installed the old FW, and it stayed at 71
I rebooted, and it went to 64 again....
However, whilst I was getting ready to test some python fan control stuff, and letting the temp settle at idle, it jumped to 71.
After doing all the fan testing, it idled back to about 68.
Now after FW update second time, I had the often mentioned problem of the reboot freezing, and after hard reboot it has in fact come back a few degrees cooler.
I have run the same services each time, and when I then rebooted again, it was yet another few degrees cooler.
Ambient temperature is static, so I don't know what's going on really....
However, given that I don't have the problem anymore, and that no one else reported it, I think we can put it down to "Eddie's in the space time continuum"....
BTW: is it correct that the Pi4 idles about 20 deg hotter than 3B+ ?
65 seems quite hot for an idle CPU.
5ft24dave
Tue Nov 05, 2019 8:04 pm
You said your idle temp increased when you added a heatsink. Some of those cheap heatsinks use regular double sided tape which is a good insulator for heat and they cause issues. You need to get either a good thermal adhesive pad, or thermal compound and a way to anchor the heatsink, otherwise these tests aren't really going to show anything close to normal
5ft24dave
Tue Nov 05, 2019 8:07 pm
Not correct
My 3B+ with no heatsink in a 28 deg C room idles about 32 degrees. Pi4B next to it, again no heatsink, idles about 38 degrees
