Hi all,
I am wondering if anyone has seen similar. I have just started experimenting with the RPi4 and one thing I would like to do is replace my current ownCloud "sever" which is a RPi3B+. I did a test install over the weekend and saw some strange behaviour which I think is attributed to the USB spin down of the drive.
First the RPi would drop of the network. Seemingly reboot needed to fix the interface having issues.
If I switched to the console directly and tried to login, the USB keyboard would lag terribly (to the point of being unusable). Again, a reboot would fix the issue.
After a few rounds of this, I decided to unplug the HDD and see what happens.
First thing is the lag on the USB keyboard instantly disappeared and I could bring the network back up.
I haven't yet tested this to the point of being definitively sure, but has anyone else seen such issues? Anyone know a cure?
Setup is:
RPi4, 4GB
Sandisk 32Gb (minimum class 10 but I have tried with higher speed card also with the same issues)
Official RPi foundation power supply for the RPi4
WD Elements USB3 drive
