I've had no end of issues setting it up compared to the R-Pi 3 (insert card, turn on, done), and I wonder if it's because I'm doing something wrong or because I got a dud unit. All suggestions welcome..
It started out innocently enough - it booted to the rainbow screen and just stayed there. Eventually, I figured out the HDMI cable has to be plugged into the left HDMI port..
With that hurdle out of the way, I finally ran through the normal install process, which eventually ended up on the desktop. It looked normal briefly, correct 1920x1080 resolution.. for a fraction of a second, before the display went black. I tried restarting several times, tried editing the settings in the troubleshooting menu, nothing worked. I eventually gave up and decided to move the unit and tidy the cables - and weirdly when I plugged it back in it worked again. But now the resolution was set much too low, so I went to Display Settings - but only 4 resolutions are shown, the highest of which is something like 1280x800 (not at the RPi right now). Also the screen was really dim now, not full brightness as before.
- I tried running rpi-update to see if newer firmware would help - nope.
- I installed all available updates through apt get update/upgrade
- The screen has normal brightness immediately after boot. It only goes dim once it reaches the desktop
- The TV functions normally using smart TV apps, or other sources such as my HTPC
- I'm using a Samsung 1080p TV if that matters
- I tried reinstalling a fresh copy of Raspbian - no difference
- boot, install & recovery screens all run at 640x480 - is that normal? Maybe seems like the hardware isn't even "seeing" the tv?
- I tried installing Manjaro ARM - it's even worse and only sees a single 640x480 resolution, and the screen remains dim.
- tvservice -n reports "no device present"
