hippy
Re: Pi4 solid red and green led
Sun Dec 08, 2019 2:17 pm
James007 wrote:
Sun Dec 08, 2019 11:14 am
Any other advice ?
Do as gormanpe did; burn the SD Cards on a PC which has a micro-SD Card slot. That seems to have been the only solution for resolving the issue so far identified. YMMV.
kissste
Wed Dec 11, 2019 3:36 am
The same issue here - Pi4 solid red and green led and won't boot. CPU is not even warm.
My Pi4 was working ok, then one day, stopped.
I have tried a new sd card, reflashed the old one.
no difference what so ever.
whether SD card is there or not
solid green and solid red and no CPU is cold. no flashes, nothing
renice123
Wed Dec 11, 2019 9:33 am
It seems to me that if we want to find out what happens when the "green LED of death" appears, then we need to provide more technical information.
For example, the following questions immediately arise.
1. Which memory card was used (and even on which card reader the image is recorded).
2. Which case was used (closed, open, metal, plastic, and so on.
3. What kind of power supply. Whether there was a voltage drop or frequent malfunctions in the electrical home network.
4. Whether the temperature of Raspberry was controlled (for example, I have constant temperature control turned on and when I reach 60 degrees, Raspberry is turned off).
5. Are any devices connected to the GPIO
6. Where is Raspberry physically located and can it be that the microcomputer is exposed to humid air or is in a stuffy shoe box =)
7. In what mode was the computer used? Constantly worked or often turned on and off.
What programs were most often used (server or web browsing through Chromium and so on)
Have any changes been made to config.txt
Indicate the firmware version and whether EEPROM was tried to flash (before or after the "green death LED").
8. How the computer behaves after the appearance of the "green death LED". How much current does Raspberry consume in this case (measure the current with an ammeter). Can check some signals on the board with an oscilloscope? What happens if you lower the voltage from the power supply to Raspberry (for example, to 4.8 Volts or lower, to 4.5 Volts. Will the red light disappear?).
9. Perhaps it makes sense to post photographs of Raspberry and setup, the environment in which the microcomputer worked. That is, indicate the brand of keyboard, mouse, connected devices.
I noticed that because of the low cost of Raspberries, the microcomputer is often used with cheap low-quality devices (the latest example is the hdmi cable or wi-fi keyboard of a Chinese cheap manufacturer).
It seems to me wrong: the cheapness of the microcomputer is a kind of masterpiece of the engineering team and marketing policy, and this does not imply the purchase of cheap related equipment that can cause problems.
Therefore, would like to receive as much information as possible about the microcomputer with the "green death LED" in order to avoid a possible problem in the future.
The argument of "statistical insignificance" of breakdowns does not seem very relevant, since it is known that sometimes the manufacturer accidentally releases batches of devices with some kind of problem. In our country this is called a “defective party” and is very common.
That is, would like to clarify from which supplier Raspberries with a "green LED of death" were purchased. And what time.
PS Apparently, there are several problems with the "green death LED." Perhaps one of them is a special algorithm for working with a memory card in the fourth version of Raspberry (apparently related to the memory card controller and frequency). The second problem is most likely related to programmable PMIC and the presence of EEPROM - I noticed that users of Raspberry try to rewrite EEPROM with some hasty regularity. This potentially dangerous operation is for some reason popular.
Well, so far, the development engineers have not said their version, so we have to wait for an official decision.
barryxprt
Thu Dec 12, 2019 12:31 am
Hello all,
Appreciate all of your insights on this problem; I just want to add my own experience so that hopefully we can get more attention to this issue:
We develop white label automation tools using the RPi platform and have been using Pi 3 B's without issues for some time (with the odd SD card corruption).
We've ordered 3x Pi 4 (4GB) and all 3 have succumbed to this issue (solid green/red LED w/ nothing connected).
2 of the Pi 4's were DOA with this issue (feint, solid green LED & solid bright red LED) and the 3rd (recently procured from a different supplier) was working for some time and then suddenly exhibited the "nothing connected, solid red & bright green LED, no boot" condition.
I've tried the EEPROM recovery image on several SD cards to no avail.
All 3 PI's were powered from an official P2719 Raspberry Pi AC/USB-C adapter.
What's most frustrating is that for a hobbyist/hacker product, there aren't more options to serial debug this thing. I know there's the option to enable UART debug, but if it doesn't boot you can't enable that feature.
Our experience so far with this platform has seriously shaken our confidence in the OEM QC processes.
Additionally, I have noted a bit of variation to the quality of the solder joints around the USB-2 mount points between the 3 Pi 4's we have (pictures attached). I would really appreciate some acknowledgement or feedback on this issue. I gather it's not affecting most end-users, but for us it's been 3 out of 3, so the perception is that it's a faulty product.
I'll be watching this thread in the hopes of a breakthrough... fingers crossed.
renice123
Thu Dec 12, 2019 9:46 am
There are several branches devoted to the problem of the "green LED of death." Here is a link to another thread
https://www.raspberrypi.org/forums/view ... 8#p1560438
If Raspberries had dead on arrival, then it looks like problems with soldering components or static electricity. I was surprised that the fourth version of Raspberry went on sale in our country without an antistatic package.
It was very strange, I'm used to all complex electronic devices coming in antistatic bags.
Did you receive your computer in a protective package or did they just lie in a box without packaging?
rpdom
Thu Dec 12, 2019 9:52 am
It didn't.
The piece of cardboard with the pictures on is anti-static and a lot more environmentally friendly than a plastic bag.
Unreadable squiggle
renice123
Thu Dec 12, 2019 10:12 am
Perhaps a piece of cardboard is much more environmentally friendly than antistatic packaging, but before I got all my devices in antistatic plastic packaging. But I was horrified that now they began to put only a piece of cardboard in a box - my new Raspberry dangled in this box during transportation.
Perhaps the fiery speeches of Greta Tunberg forced manufacturers to use only cardboard =)
PS I remember the times when used lead solder. When environmentalists forced all manufacturers to abandon lead solder (yes, it is harmful), many electronic devices began to fail. Badly soldered parts fell off. Alas, this is so. I believe that we should fight for the environment, but we should not splash out along with dirty water from the basin of the child =)
rpdom
Thu Dec 12, 2019 10:22 am
I still use leaded solder, but I am not a manufacturer.
I have had equipment that used leaded solder where the joints were poor and failed on a regular basis. I kept having to take it apart and remake the joints. The manufacturers had done a very poor job in the build.
Unreadable squiggle
hippy
Thu Dec 12, 2019 10:33 am
A couple of posters have stated having a feint green LED rather than bright green LED. That's interesting because the LED is wired across 3V3 and 0V switched by a FET controlled by the ACT_CLK line.
The most likely reasons for that LED to be feint rather than fully on is 3V3 isn't 3v3, the 3V3 is switching levels, or the ACT_CLK is switching, creating a PWM-like dimming of the LED.
One possibility where the LED is feint could be that the PMIC is starting up and then shutting down, repeatedly pulsing the 3V3 line. If you have a scope you could perhaps take a look at the 3V3 rail. A multi-meter would probably show some voltage but not full 3V3 if it is power-cycling 3V3.
emma1997
Thu Dec 12, 2019 5:03 pm
Hi, renice123. I see now you are probably from another country and smart and not just too young or other problems. Maybe we can blame bad google translate. It's not required but showing approximately where we are from in the avatar can help avoid misinterpretations.
Let's not "Throw out the baby with the bath water" lol
James007
Thu Dec 26, 2019 2:19 pm
SanDisk Ultra 32GB A1
Metal case
Original power supply
Cooler running non stop.
No devices were connected to GPIO. Only the cooler was connected to 5V.
Office space 25C
Headless with no X. K8S was running but without any pods.
Stock EEPROM, no changes in config.txt were made.
No idea.
Only the ETH was connected, not WiFi or keyboard, mouse was used.
I am adding this info just for reference.
James007
Thu Dec 26, 2019 2:26 pm
Indeed I can confirm the PWM-like behavior of the GREEN LED. Is not lighting at full capacity.
Red and Green LED
hippy
Thu Dec 26, 2019 3:08 pm
Do you have a multi-meter you could use to carefully measure the 3V3 with respect to 0V ?
The safest way to do that is with 'DuPont' female jump wires to the GPIO header pins and measuring at the other ends, taking care to not let them short together.
James007
Thu Dec 26, 2019 3:43 pm
Indeed there are no 3V3 only 1.83V.
I am afraid not to be the same issue with the broken line for the resistor like here:
https://www.raspberrypi.org/forums/view ... n#p1555512
renice123
Thu Dec 26, 2019 7:33 pm
As far as I know, Raspberry 4 uses MaxLinear's MxL7704, this is a more advanced version of PMIC than the previous one.
It would be interesting if the owners of the dead microcomputers could give Raspberry for repair (for example, in the service center where they repair cell phones or laptops) and ask to replace PMIC. However, perhaps the PMIC for Raspberry is different from the “regular” MxL7704.
https://datasheetspdf.com/datasheet/MxL7704.html
jasonsaffle13
Sat Jan 25, 2020 11:32 am
I just fixed this issue by swapping out my micro HDMI adapter two of the three I have cause this issue.
bcatalin
Sun Jan 26, 2020 2:38 pm
I have this issue without HDMI connected. I suspect that in you case is a different issue.
JEP1960
Sat May 02, 2020 8:57 am
Hi All - I've encountered the same problem, frustratingly. I have 2 RPI-4's 4GBs ... both have the same type SAMSUNG 64Gb SD card (formatted to FAT32 before installing NOOBS) , and both originally worked great out of the box.
Problem started randomly after shutting down, and attempting to restart.
I notice that actually, when I power on act the wall, the green ACT light does flash once, quickly, then goes out momentarily, then comes on constant. There is nothing on my screens, no sign of life from ethernet cable. I'm not sure, but I think it may be slightly dim, relatively to its full brightness.
The problem appeared to be intermittent at first. My RPI-4_number_1 (of my two) had the problem, but after several tries, suddenly, randomly booted up fine. I've left it running, headless, ever since, and it appears fine. However, I'm not going to dare shutting it down and rebooting.
My RPI-4_number_2 worked fine out of the box, then got the green light problem on switch-on, but despite many attempted restarts, has not come to life. I returned this Pi to PiHut (where I got it), they sent me one back... However - I get the same constant green light with the Pi too. Same symptoms, same quick ACT light flash, then constant.
I've reformated an SD card, reinstalled the operating system, tried again on this new PI-4 - no luck.
I have a double header setup, 2 screens, ethernet connection, USB mouse and keyboard. I have the same issue with constant ACT light, no bootup whatever combination of connections I try... none, all, or some. I have an official RPI-4 power supply for each.
I've formatted the 64Gb SD cards to FAT32 using Minitool partition wizard - seemed to work great.
I'm at a loss as to what to try next... has anyone observed the same please... and any thoughts on how to help?
Thanks very much... appreciated.
John
hippy
Sat May 02, 2020 6:08 pm
While possibly related this seems to be a different issue to the usual 'Green Light of Death' reports where the green LED does not flicker, just comes on, dim or full, and stays that way.
hardtimez2517
Thu Jun 04, 2020 8:47 pm
I have this issue. Had my raspberry pi 4 up and running fine. I went to move and route the wires differently and when I turned it on, nothing, just solid green and red lights but both lit equally bright. Disconnected everything but the power cable and same issue. No signal. Tried different hdmi adapters and ports. The strange thing is I have the Flikr remote usb plug. It was hot yet the power cord was unplugged for a few days...? It’s in a Flikr case and didn’t check inside but there’s obviously a burned electronic smell seemingly coming from the power/hdmi 0 area. Either way, it’s going back. I’m not dealing with non well made electronics given all the other complaints on this issue of this happening. I use the legit Pi power supply and on/off switch on the Pi also. No third party.
Judge
Fri Jun 05, 2020 9:00 am
(I copy/asted my thread here, since I didn't see this thread before I made my own...)
My new Pi4B is not booting anymore.
I have read sticky of booting problems viewtopic.php?f=28&t=58151
I have original powersource
I have 16Gt SD card, FAT32
I have tried to install through NOOBS, Imager, Rufus+2020-05-27-raspios-buster-full-armhf.zip and everything I could find from net...
I have tried to install bootloader / recovery (with Imager and manually)
Leds (red+green) are solid straight away when I install a power socket.
Above, you can see the sitution right now.
Before that, in a beatiful tuesday morning this week I got my Pi4B from DHL. I downloaded Imager and used that to format / install raspberry my 64Gt Sandisk SDXC. Everything went well and I connected my USB mouse + keyboard + RJ45 + official HDMI cable to Pi. Then power socket on and I could see Pi booting. Lot's of thing happening in screen, couple of strange "flashes" (display on/off) and I got the login screen.
Didn't know the password, so I tried something like "root" "admin" etc. Then suddenly, everything shut down.I googled login credentials and tried again
Power on, and booing starts. After few seconds, everyting shuts down. Second attempt, same thing.
Then googling, -> 64Gt card is not OK for Raspberry. But possible... I formatted 64Gt card to FAT32, tried to install several possibilities of Raspberry Pi OS (NOOBS, manual installation etc.) . I removed my USB mouse/keyboard and RJ45 etc trying what ever I could find for the soluton from this forum / webpages found with google. Result was, I got 4 flashes for Green light in booting ( start*.elf not found).
Then I purchased 16Gt SD card, and started to do "everything" again. No luck, and end result was solig green+red led when inserting powersocket.
After that, I tried to install "recovery" with Imager and manually. Nothing happened.
When I took SD card out, lights are solid straight away (same thing when SD card is in).
So, my fellow Pier's... do I have a Brick...?
hippy
Fri Jun 05, 2020 3:49 pm
Possibly, possibly not. I actually managed to get myself a 'red plus green LED always on, no HDMI' situation a few days ago but I was hacking about with files within a 'pieeprom-YYYY-MM-DD.bin' image and updating the Boot Eeprom with that so, whilst a notable outcome, it wasn't entirely an earth shattering surprise.
That was resolved, with normality restored and no harm done, by flashing the Boot Eeprom using the Boot Eprom Recovery Image.
So that proves it is entirely possible to have 'red plus green LED always on' and the Pi 4B not bricked. But it doesn't prove that all such occurrences of that can be resolved.
The best way to proceed is calmly and methodically, doing things in a manner which best guarantees success, eliminates issues which could cause things to go wrong.
I would suggest finding an 8GB, 16GB or 32GB card. Then download the latest Raspberry Pi OS image. Burn that to the card using Balena Etcher, possibly pi-imager. Check you can boot that on any working Pi which you have.
Then download and burn the Boot Eeprom Recovery Image to that card with Balena Etcher, possibly pi-imager. Boot that on your Pi 4B and let it re-flash the Boot Eeprom. Leave that a minute, power off then back on again just for good luck, check it is continually flashing its green LED and has put up a green HDMI screen.
Then burn the latest Raspberry Pi OS image to the card using Balena Etcher, possibly pi-imager. Boot that and see what it does. Hopefully it will boot. If it does not, check if it boots on any other Pi you have.
If it boots you can then move on to using your 64GB card.
I gave up using NOOBS when I started using 64GB cards. I now use Raspberry Pi OS images and Balena Etcher because that is a 'put the card in, select the image, click "flash" and job done'. Pi-imager should be just as good, work as well, but I haven't used it.
