DocSledge
RPI 4 SSH Error during headless installation
Fri Aug 23, 2019 4:28 pm
Hi there,
I hope, that I can get a solution of this little problem. I am working with the RPI for at least 4 years.
Yesterday I got my new Pi4. I created a new Raspbian Boot medium with the latest Buster Image. Also put a "ssh" file in the boot partition.
My Pi seems to boot and got an IP from my mikrotik router.
The Prob: I get an error: Connection refused and I am not able to access the Pi. Sadly I have no HDMI Cable due to the new Ports.
I never ever needed a cable, because all my Pi Projects and all my RPI3 worked that way of headless Installation.
After shutting down the Pi - the "ssh"-File has been deleted... Very strange because I thought that happens, after a SSH Connection has been succesfully established.
Does anybody has a Solutution?
Thank you in Advance.
Cheers,
Gerd
Andyroo
Re: RPI 4 SSH Error during headless installation
Fri Aug 23, 2019 6:19 pm
The ssh file is deleted at boot time as the ssh is set to run so the file not being there is good news :D
Can you run
ssh -v [email protected]<ip address>
and post the result here?
If you are running ptty then there is a way to set error logging to a file but I never use that program :roll:
fulmar
Fri Aug 23, 2019 7:13 pm
Are you able to ping to the rpi and out to your LAN? Probably not the problem, but had something similar, and my issue was bad Mikrotik configuration.
HawaiianPi
Fri Aug 23, 2019 7:25 pm
Sounds like you may not be using the correct IP address? Do you have other Pi computers on the same network with the default hostname?
Are you using a wired (Ethernet) or wireless connection?
Other than the 'ssh' file, were there any other changes to the card before booting?
FYI, headless boot with Raspbian Buster Lite works fine with my 4B2 and 4B4.
B.Goode
Fri Aug 23, 2019 8:43 pm
No, that's not quite true.
The relevant Raspberry Pi documentation says:
For headless setup, SSH can be enabled by placing a file named ssh, without any extension, onto the boot partition of the SD card from another computer. When the Pi boots, it looks for the ssh file. If it is found, SSH is enabled and the file is deleted.
Ref: https://www.raspberrypi.org/documentati ... /README.md
So the 'marker' file will be deleted when the SSH server (listener, or Daemon) is enabled. It doesn't depend on a subsequent connection being made to that server .
