CjScout
Contact: YouTube
Noobs Installation not work
Fri Aug 23, 2019 11:41 am
Hello everyone,
I recently broke the WiFi on my pi 3 b+, so decided to format the sd card and reinstall the os. I used the inbuilt chrome os formatting option to format it. I then downloaded the zip file, expanded it and pasted the files to the sd card and put it in my pi. It went straight to telling me to hold shift for recovery mode. Then it told me it couldn’t find the drive with noobs files. Then it went to a weird command line unlike the one in the normal os. Can anyone please explain what I did wrong and how to fix this?
Thanks,
CjScout
1 Pi 3 B+ and 1 Pi 4 2gb.
Skill in Python, Java, and C++.
procount
Re: Noobs Installation not work
Tue Aug 27, 2019 8:55 am
You formatted your SD card incorrectly as one single drive.
You need to make sure it is formatted with an MBR so that it can have multiple partitions.
CjScout
Contact: YouTube
Wed Aug 28, 2019 7:50 pm
So wait, what is the need for partitions? I’m not installing a image yet, I’m just putting on noobs. I thought of that and erased it using The built-in windows system. Does that have the same affect of not putting in MBR?
B.Goode
Wed Aug 28, 2019 8:38 pm
The NOOBS Installer has its own scheme for creating partitions on the installation medium. https://github.com/raspberrypi/noobs/wi ... -explained
You don't need to know or understand the details of this. The first thing a newly created NOOBS Installer does when first booted in an RPi is to prepare the microSD card or other media for this partitioning.
But to do so it requires a microSD card that has been formatted in the first instance as a single FAT partion.
If at first boot your card immediately went to 'hold shift for recovery' it suggests to me that this initial preparatory formatting was not in fact carried out successfully. Maybe your microSD card has spontaneously (and probably irrevocably) entered a Read-only state?
CjScout
Contact: YouTube
Wed Aug 28, 2019 9:23 pm
So I can’t get it out of that mode?
CjScout
Contact: YouTube
Also, would formatting the card using the SD associations program work?
rpiMike
Wed Aug 28, 2019 9:25 pm
If your just after Raspbian why not just flash a Raspbian image to sd card with Etcher. It’s much simpler.
Imperf3kt
Wed Aug 28, 2019 9:38 pm
Alternatively, PINN is an upgraded version of NOOBS
55:55:44:44:4C
52:4C:52:42:41
CjScout
Contact: YouTube
Wed Aug 28, 2019 9:56 pm
I wanted noobs because I do a lot of testing on my pi, and it has the recovery mode. Also, where could I get PINN?
davidcoton
Wed Aug 28, 2019 10:02 pm
Here (note links from each PiNN version header)
procount
Wed Aug 28, 2019 10:09 pm
For further info on this issue see https://github.com/raspberrypi/noobs/issues/498
CjScout
Contact: YouTube
Wed Aug 28, 2019 10:13 pm
After looking at PINN I am going to give it a go. I will update soon on if it works. Or doesn’t
procount
Wed Aug 28, 2019 10:19 pm
Whether you use NOOBS or PINN, the SD card must be formatted correctly first. If you struggle to do this, there is an Etcher image of PINN that you can flash using balena etcher just like most other images. This will avoid any formatting difficulties.
