svoss
Bluetooth inactive start does not start (Pi 2B)
Fri Aug 23, 2019 11:07 am
Hello, iam desperate...
Pi 2B, Jessie 8
Problem: systemctl status bluetooth shows "Active: inactive (dead)" , "sudo systemctl start bluetooth" does not start bluetooth
[email protected]:~/bluez-5.50 $ systemctl status bluetooth
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
     Docs: man:bluetoothd(8)
[email protected]:~/bluez-5.50 $ sudo systemctl stop bluetooth
[email protected]:~/bluez-5.50 $ sudo systemctl disable bluetooth
Removed symlink /etc/systemd/system/dbus-org.bluez.service.
Removed symlink /etc/systemd/system/bluetooth.target.wants/bluetooth.service.
   Loaded: loaded (/lib/systemd/system/bluetooth.service; disabled)
[email protected]:~/bluez-5.50 $ sudo systemctl start bluetooth
[email protected]:~/bluez-5.50 $ sudo systemctl enable bluetooth
Created symlink from /etc/systemd/system/dbus-org.bluez.service to /lib/systemd/system/bluetooth.servic                e.
Created symlink from /etc/systemd/system/bluetooth.target.wants/bluetooth.service to /lib/systemd/syste                m/bluetooth.service.
what happend so far:
1. i had trouble pairing LE devicies.
2. i deviced to: sudo apt-get --purge remove bluez
3. then tried this manual: https://learn.adafruit.com/install-blue ... stallation, see below
i did:
cd ~
wget https://mirrors.edge.kernel.org/pub/linux/bluetooth//bluez-5.50.tar.xz
tar xvf bluez-5.37.tar.xz
Q1: is ~ the right place for bluez in pi 2b?
Q2 am i missing an agent, package or else? what and where to check?
Q3: How to decide which bluez version is needed for 2B?
Q4: the path changed to https://mirrors.edge.kernel.org/pub/linux/bluetooth/ appently, correct? so i did
tar xvf bluez-5.50.tar.xz
cd bluez...
sudo apt-get update
sudo apt-get install -y libusb-dev libdbus-1-dev libglib2.0-dev libudev-dev libical-dev libreadline-dev
./configure
make
sudo make install
PLEASE help me out... to set up bluetooth new correct, to use Bluetooth, hcitool, agent, and all again
Thanks so far_
Douglas6
Re: Bluetooth inactive start does not start (Pi 2B)
Fri Aug 23, 2019 1:54 pm
Probably the best idea is to install BlueZ from the repositories:
sudo apt install bluez
That will get you BlueZ 5.50 under Buster, 4.47 under Stretch.
Fri Aug 23, 2019 2:13 pm
Pi 2B, Jessie 8
i did:
cd ~
cd bluez...
sudo apt-get update
./configure
make
sudo make install
Thanks so far_
The Raspberry Pi 2B ( both variants ) does not have on-board Bluetooth !
Raspbian Jessie is end of life you should be running the supported Buster..
Retired disgracefully.....
