ReefBum
Pi 4 Headless?
Wed Aug 21, 2019 10:50 pm
Received new Pi4 4gb today.
Raspbian Buster Lite downloaded today and installed on 32gb SD (Pi 4 running headless)
I can reach it via SSH just fine from laptop but none of my USB drives I have tried will mount
I have been using a Pi3 B+ for a year of so as a headless little personal mail server which has been working ok but has some memory issues sometimes with only 1gb. With the Pi4 now having 4gb memory I decided to upgrade
However I'm having issues with the USB drive mounting at boot. The same drives mount fine on boot with the Pi3. Is there something I'm missing with the new Pi4 to run headless?
Regards
epoch1970
Re: Pi 4 Headless?
Thu Aug 22, 2019 8:10 pm
Which PSU do you use?
jerrm
Re: Pi 4 Headless?
Thu Aug 22, 2019 8:34 pm
Are these USB thumb drives or SATA drives with adapters.
If drives with adapters, try the quirks setting in the sticky https://www.raspberrypi.org/forums/view ... 8&t=245931 (it's not just for speed). Pretty much any adapter was OK with USB2 on older Pis. USB3 on the Pi4 can be much pickier.
ReefBum
Re: Pi 4 Headless?
Fri Aug 23, 2019 6:55 pm
PSU is raspberry official
drive is sata ssd with adapter
the same drive/adapter is working 100% on pi 3b+ buster
If I plug in hdmi monitor, it works 100% but headless it fails.
HawaiianPi
Re: Pi 4 Headless?
Fri Aug 23, 2019 7:11 pm
What is the filesystem on the drive (how is it formatted)?
Which USB-SATA adapter?
That makes no sense to me. :? One has nothing to do with the other (AFAIK).
Re: Pi 4 Headless?
Fri Aug 23, 2019 7:15 pm
Run
sudo apt update
sudo apt dist-upgrade -y
sudo reboot
That should get you the latest (beyond 2019-07-10) stable 4.19.66-v7l+ kernel and the latest stable bootcode/firmware
I recall seeing a bug somewhere on here about not booting without HDMI.
This is a doctor free zone.
pfletch101
Re: Pi 4 Headless?
Fri Aug 23, 2019 8:43 pm
See Andyroo's answer when I asked the same question (https://www.raspberrypi.org/forums/view ... 7#p1506293). The added requirement for headless setup in Buster is that the default screen size has to be set for (at least) VNC to work. Both OS versions will autodetect most HDMI monitors and display a sensible screen size. In Stretch, VNC will default to a very low resolution screen if the screen size hasn't been specified, but Buster requires that one be explicitly set if there is no physical monitor plugged in.
HawaiianPi
Re: Pi 4 Headless?
Fri Aug 23, 2019 9:27 pm
OP is running Lite, so no VNC.
... but Buster requires that one be explicitly set if there is no physical monitor plugged in.
I just tried Raspbian Buster Lite 2019-07-10 on my 4B4, completely headless (nothing but power connected). Seems to be working fine for me.
  • Pi 4B 4GB in Flirc case.
  • Raspbian Buster Lite (2019-07-10-raspbian-buster-lite.zip)
  • SamSung EVO+ 32GB micro SD card (image written to card with Etcher).
  • Official Pi3 2.5A PSU with USB-C adapter.
  • Added "ssh" and "wpa_supplicant.conf" files to card.
Does that bug have anything to do with USB drives (the OP had a USB drive connected, I did not)?
Re: Pi 4 Headless?
Fri Aug 23, 2019 9:33 pm
I don't remember what I saw, it could be a figment of my warped imagination. At the moment (until the household finance director heads off on her three month trip to Australia) I'm not allowed to buy a RPi4, so I've not been paying total attention to the RPi4 threads.
HawaiianPi
Re: Pi 4 Headless?
Fri Aug 23, 2019 9:56 pm
Just tried it with a USB drive connected and mounted in /etc/fstab. Still works. ¯\_(ツ)_/¯
Same as previous post, but with a USB 3.0 card reader connected, with a 32GB FAT32 formatted card inside.
Connecting from, Win10 laptop using WSL for SSH.
~$ ssh [email protected]
[email protected]'s password:
Linux raspberrypi 4.19.57-v7l+ #1244 SMP Thu Jul 4 18:48:07 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Aug 23 22:24:29 2019 from 192.168.2.10
[email protected]:~ $ ls /mnt/sda1
'System Volume Information'
[email protected]:~ $ uname -a
Linux raspberrypi 4.19.57-v7l+ #1244 SMP Thu Jul 4 18:48:07 BST 2019 armv7l GNU/Linux
[email protected]:~ $ cat /etc/fstab
proc /proc proc defaults 0 0
PARTUUID=84b22cec-01 /boot vfat defaults 0 2
PARTUUID=84b22cec-02 / ext4 defaults,noatime 0 1
/dev/sda1 /mnt/sda1 vfat defaults 0 0
OP indicated the issue was mounting a USB drive at boot (not failure to boot), but I still don't understand how connecting an HDMI monitor could affect mounting (and I can't replicate the problem).
ReefBum
Re: Pi 4 Headless?
Sat Aug 24, 2019 4:17 am
thanks for the help
I don't know if I fat fingered something or not my old eyes are wore out sometimes
but starting with a fresh install and running dist-upgrade seems to have solved it
regards
