ATRedline
espeak doesnt work
Wed Aug 21, 2019 4:13 pm
I need espeak for my project. I made fresh installation of oficial raspbian, install updates, and next i made next steps:
sudo apt-get install espeak python-espeak python-pyaudio
pip install pyttsx3
and then, if i run following code on python:
import pyttsx3
engine = pyttsx3.init()
voices = engine.getProperty('voices')
engine.say('Hello!')
engine.runAndWait()
i've get multiple errors:
then i tried to use espeak in terminal, and for:
 espeak "Hello world"
i've get the same errors as in the python.
And when i tried that way:
'espeak "Hello World"  2>/dev/null
There is no errors, but it dont work too - just silense (i tried force 3.5 output and HDMI output - still silence, but sound in web browser works fine)
What i did wrong? How can i fix espeak?
hippy
Re: espeak doesnt work
Wed Aug 21, 2019 10:26 pm
This seems to all come down to something wrong with ALSA which espeak uses and possibly your pyttsx3. It was broken in Stretch, and remains broken in Buster.
I experience the same 'doesn't work' as you with -
The only ways I have managed to get espeak working reliably for me is with -
espeak "Hello World" --stdout | aplay
espeak "Hello World" --stdout > file.wav
aplay file.wav
But, using the first, it has now started to sometimes drop the start of what is being spoken.
There are plenty of reports of problems but I am not sure what is being done about those, who would be expected to fix it.
Rolling back the kernel to an earlier version seems to be the only fix verified by others. I don't particularly want to do that myself so cannot confirm if it fixes things or not.
hippy
Wed Aug 21, 2019 10:39 pm
import pyttsx3
engine.runAndWait()
If you are simply after getting your Python code to speak you could forego the above and just use -
import os
os.popen( 'espeak "Hello!" --stdout | aplay 2>/dev/null' )
import os
def Say(text):
  os.popen( 'espeak "'+text+'" --stdout | aplay 2>/dev/null' )
Say("Hello")
Works for me on a Pi 3B (non-plus) running Buster.
ATRedline
Wed Aug 21, 2019 10:44 pm
Hi! Thanks for your answer. I saw other threads with that issue too late. In this thread i finded half of solution:
https://www.raspberrypi.org/forums/view ... 6&t=241814
With "PA_ALSA_PLUGHW=1" in environment variables "espeak "Hello" " works, but with noises and still with errors. Also i finded solution how to run espeak with --stdoutput.
I spent half of day to make it works, listened to it, and now i dissapointed in it - voice is too ugly. I already finded RHVoise, and it very good solution for my purposes.
So, thread can be closed... I'm sorry i hurried with it
ATRedline
Wed Aug 21, 2019 10:47 pm
Thatnks man, already did this:
def espeak(text):
    lang = ''
    rl = re.compile((r'^[а-яё].+$'), re.I)
    if rl.search(text): lang = '-vru '
    command = 'espeak '+lang+'"'+text+'" --stdout |aplay'
    print(command)
    os.system(command)
def rhvoice(text):
    temp = '80'
    tembr = '80'
    command = 'echo "' + text + '" | RHVoice-test  -t ' + tembr + ' -r ' + temp + ' -v 150 -p aleksandr+alan'
    os.system(command)
espeak sounds ugly(
hippy
Thu Aug 22, 2019 4:25 pm
espeak sounds ugly(
It's definitely an acquired taste. I like picoTTS on Android but found the packaged version for Pi wasn't that great. Espeak is therefore what I have stuck with but I am always willing to give other things a try, hoping I will one day find something I like.
Do you have instructions for getting RHVoice working on a Pi ? I tried to build it, and portaudio, but I think I am missing something somewhere -
sudo apt-get install scons
cd ~
git clone  https://git.assembla.com/portaudio.git
cd portaudio
./configure
make clean
make
sudo make install
sudo ldconfig
cd~
git clone https://github.com/Olga-Yakovleva/RHVoice.git
cd RHVoice
scons
sudo scons install
sudo ldconfig
echo "Hello World" | RHVoice-test
That all worked fine but "RHVoice-test: command not found", possibly because it can't find portaudio or aother dependency ...
pi@Pi3B:~/RHVoice $ sudo scons install
scons: Reading SConscript files ...
Mkdir("build/linux")
Checking whether the C compiler works... (cached) yes
Checking whether the C++ compiler works... (cached) yes
Checking for pkg-config... (cached) yes
Checking for libpulse-simple... (cached) no
Checking for ao... (cached) no
Checking for portaudio-2.0... (cached) no
scons: done reading SConscript files.
scons: Building targets ...
scons: `install' is up to date.
scons: done building targets.
pi@Pi3B:~/RHVoice $
ATRedline
Thu Aug 22, 2019 8:30 pm
Espeak is not that bad in English, but i need Russian syntesizer - with Russian voise espeak is terrible. And also i love espeak for its speed. RHVoise is slower than Espeak. RHVoise is slower than Espeak, but faster than gTTS. gTTS, by the way, not bad, but it needs connection, and it doesnt have selection of voises and parameters, unlike RHVoice
I made next steps:
sudo apt-get install scons g++ pkg-config git libpulse-dev speech-dispatcher
cd RHVoice
scons
sudo scons install (sudo scons --clean install for remove)
sudo ldconfig
sudo cp -a /usr/local/bin/sd_rhvoice /usr/lib/speech-dispatcher-modules
sudo nano /etc/speech-dispatcher/modules/rhvoice.conf:
_______________________________________________________
RHVoiceDataPath "/usr/local/share/RHVoice"
RHVoiceConfigPath "/usr/local/etc/RHVoice/"
RHVoicePunctuationMode
#RHVoicePunctuationList "@+_"
RHVoiceDefaultVoice "Aleksandr"
RHVoiceDefaultVariant "Pseudo-English"
Debug
sudo nano /etc/speech-dispatcher/speechd.conf:
in the end:
#AddModule "rhvoice" "sd_rhvoice" "rhvoice.conf"
RHVoise-test is work, RHVoise-client: "command not found", so, i using by that way:
echo «Hello World!» | RHVoice-test  -t 50 -r 70 -v 150 -p alan
english voices:  alan, clb
speech rate: -r = 50--200
speech pitch: -t = 50--200
speech volume: -v = 100 ->
default = 100.
and also, symbols like ' is not accepted.
hippy
Thu Aug 22, 2019 10:40 pm
Thanks for details. Turned out I needed a reboot to gel libpulse-dev to be seen when building RHVoice. After that libpulse-simple and portaudio-2.0 appear as "(cached) yes" with scons.
It seems to be working though all those ALSA errors are appearing. With 2>/dev/null they can be hidden and it does actually speak.
It is certainly less robotic than espeak. I'll update my own speech programs and see how I get on with RHVoice.
ATRedline
Thu Aug 22, 2019 11:36 pm
Are you getting ALSA errors under RHVoice? I'm not
hippy
Mon Aug 26, 2019 3:04 pm
It produces audio output but churns out a lot of errors -
pi@Pi3B:~ $ echo "Hello" | RHVoice-test  -t 50 -r 70 -v 150 -p alan
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 934
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5036:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM bluealsa
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib conf.c:5014:(snd_config_expand) Unknown parameters {AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2  CARD 0}
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2  CARD 0}
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
default Engine is default
pi@Pi3B:~ $
Worse, I have lost audio routing as per the following link, apparently I need to uninstall PulseAudio -
https://www.raspberrypi.org/forums/view ... hp?t=24943
And that seems to have broken the RHVoice installation, and won't recompile because scons now throws errors. Decided to start-over from scratch and built that with portaudio, no pulseaudio.
That's now worse than earlier, more errors and no audio output -
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
Expression 'paInvalidSampleRate' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2048
Expression 'PaAlsaStreamComponent_InitialConfigure( &self->playback, outParams, self->primeBuffers, hwParamsPlayback, &realSr )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2722
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
pi@Pi3B:~ $
But an improvement with using espeak "Hello World" with no --stdout. Lots of errors as per above, but it's now speaking , though losing the start; "orld".
At least espeak "Hello World" --stdout | aplay still works so I'll stick with using that for now.
The bottom-line take home remains; ALSA is a badly broken mess, and has been for some time.
amcdonley
Mon Sep 23, 2019 1:27 am
After updating my Raspbian Stretch:
Linux Carl 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
espeak stopped working completely for me.
I got it to speak again by adding the following to my /home/pi/.bashrc
PA_ALSA_PLUGHW=1
export PA_ALSA_PLUGHW
(and rescanning it - `source .bashrc` )
but there is distortion at all volume levels for some reason.
devliya
Sun Mar 15, 2020 6:37 pm
pi@Pi3B:~ $
viewtopic.php?t=24943
pi@Pi3B:~ $
Any Solution for this so much errors ? if you have solution so please help me please. because i got same errors so please help.
devliya
Sun Mar 15, 2020 6:45 pm
pip install pyttsx3
import pyttsx3
engine.runAndWait()
can you say that how you can install pyttsx3 ? please help
governorbaloyi
Sun May 24, 2020 10:05 pm
On Raspberry Pi 4, Try the following
apt install pulseaudio
