tredeuce
Web server not working externally
Sun Aug 18, 2019 10:05 pm
Hi folks,
I have set up my Pi with a LAMP configuration, and on top of it I have installed wordpress. The website works great locally but I am having issues getting it to appear externally. I have forwarded port 80 and using port checking tools everything appears to be okay. I am using no-ip to run a ddns service. When I go to the url that has been set up with no-ip, nothing shows up. After reading the walkthroughs on a number of steps it looks like this part should be easy so I feel like I am missing something simple. Are there any other tools to help me pinpoint the issue, or any other suggestions?
I am not very experienced on the networking side of things, so forgive me ignorance.I appreciate any guidance you give.
topguy
Re: Web server not working externally
Mon Aug 19, 2019 8:04 am
Doublecheck yout external IP and ddns..
Use "nslookup" on the pi to see what ip the dns return.
pi@pione:~$ nslookup
> www.raspberrypi.org
Server:         127.0.1.1
Address:        127.0.1.1#53
Non-authoritative answer:
Address: 104.22.1.43
Address: 104.22.0.43
Have you set a static IP on your Pi ? if not double check that against port-forwarding settings in router.
When you say " nothing shows up" does it show an error in the end or is it literally a blank page ?
neilgl
Mon Aug 19, 2019 9:11 am
Did you install Wordpress using the (new) domain name or using the pi's ip address?
klricks
Mon Aug 19, 2019 12:35 pm
Hi folks,
Have you actually tried to connect from a external network such as a phone using data (not WIFI)?
Many routers do not allow external connections when initiated from within their own local network.
