lucap
[SOLVED] Raspberry Pi 4: access point and VPN router
Sun Aug 18, 2019 4:08 pm
I installed on my brand new Raspberry Pi 4 the latest Raspbian distribution:
Raspbian Buster with desktop
Image with desktop based on Debian Buster
Version:July 2019
Release date:2019-07-10
I followed a couple of tutorial to create an access point using wlan0, the first one was the official one:
https://www.raspberrypi.org/documentati ... s-point.md
I had no success, though, because the ssid was not appearing on other devices. Then i decided to use this other tutorial (which is very similar) on a new installation:
https://thepi.io/how-to-use-your-raspbe ... ess-point/
when i finished i was able to see and use the raspberry as an access point, problem is that I was not able to use the browser anymore because of (i guess) DNS problem that i was not able to fix. In the end I decide to play around with the configuration and I finally got it working removing the br0 bridge.
sudo ip link set br0 down
sudo brctl delbr br0
this works until next reboot, in fact, the interfaces comes back thanks to what is written in /etc/network/interfaces.
This is not an orthodox approach but whenever i give that two commands chrome starts to work ok and the connection to the access point are good, Can someone point in the right direction to understand what is wrong with my configuration?
EDIT:
I just noticed that in the official guide it is said that denyinterfaces line should always be before the first interface specification, something that is not true in the tutorial I followed, now I put the denyinterfaces alone in the file and everything works fine but I think that I just got a bridged connection without DHCP, in fact, connecting to the raspberry it looks like that you are directly connected to the home router, should wlan0 have an IP or not when bridged? I'm confused now
epoch1970
Re: Raspberry Pi 4 and access point
Sun Aug 18, 2019 10:20 pm
The official How-to AP documentation currently has some issues.
The other document you link is a bad copy paste job of the original. The mor*n who posted that page mixes routed and bridged setups like there’s no tomorrow.
Bridge member interfaces (eg wlan0) never have an IP address.
Bridge interfaces (e.g. br0) usually have an IP address.
lucap
Mon Aug 19, 2019 10:59 am
good to hear that, I was getting crazy to try to make it run. Can you point me to some good guide (even not raspberry related) to create an access point (even without DHCP)?
Ernst
Mon Aug 19, 2019 11:09 am
I suggest you read this thread: https://www.raspberrypi.org/forums/view ... &p=1510898
The road to insanity is paved with static ip addresses
lucap
Mon Aug 19, 2019 1:09 pm
First thing that comes to my eyes is:
Do not mix the first and second part of this guide, the configurations are not compatible.
I'm happy to see that I'm not the only one that mixed the two things together at the begging, into the guide it is never explicated that the second part is not compatible with the first, In this case two guides would be better than one.
epoch1970
Mon Aug 19, 2019 1:16 pm
Yeah. I guess someone should bite the bullet, clone the doc, revise it and make a PR. The few last commits weren’t all spotless.
Somehow I manage not to find the time or to be away from my Pis when I could...
lucap
Mon Aug 19, 2019 6:41 pm
[SOLUTION]
If anybody will come across my question here is how i enable the access point and rerouted the traffic through a VPN:
Combining the following two tutorials:
https://pimylifeup.com/raspberry-pi-wir ... ess-point/
https://pimylifeup.com/raspberry-pi-vpn-access-point/
on a freshly installed system:
Linux version 4.19.66-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 12:02:08 BST 2019
   Static hostname: raspberrypi
         Icon name: computer
        Machine ID: fad04d81fb654fddadb2811b382c0ef1
           Boot ID: 51fd9bf42f534cedb976e4017734f5a7
  Operating System: Raspbian GNU/Linux 10 (buster)
            Kernel: Linux 4.19.66-v7l+
      Architecture: arm
I finally got my raspberry to work as VPN router
blachanc
Thu Dec 26, 2019 7:26 pm
I am just stopping by to say "thank you"
The two tutorials worked for me.
Ben
PS: Even my new VPN provider was telling me that this was not possible to do AP & VPN on the RPI.
[SOLUTION]
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
oscarg
Re: [SOLVED] Raspberry Pi 4: access point and VPN router
Wed Jan 22, 2020 7:51 pm
FWIW, I managed to (almost) get an access point working on my Pi Zero W following the official documentation at https://github.com/raspberrypi/document ... -routed.md . Actually, that is a recent version of the docs not officially released yet. As in this post, the problem was that there was no internet access, either from the client or logged into the pi. On the pi, ping 8.8.8.8 worked, but ping google.com did not, suggesting a DNS issue.
The solution, following instructions posted elsewhere, was to add in /etc/dhcpcd.conf:
  static routers=192.168.4.1
  static domain_name_servers=1.1.1.1
I also routed the AP through my VPN by installing openvpn and the provider´s (PIA) files as others have described, and substituting tun0 for eth0 in the firewall rule step of "Enable routing and IP masquerading":
sudo iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE
It also works executing this command afterwards, followed by
sudo netfilter-persistent save
