bartender
Re: omxplayer won't render subtitles
Sun Jan 20, 2013 10:23 pm
Yes, I gave 128M to GPU since I've got 512M board now.
hehe2
Contact: ICQ
Mon Oct 07, 2013 3:23 pm
Well,
I got a BD-Rip (from the Serenity movie) and I can display it using openelec (XBMC) but it has some light freezes which last about one or two seconds every ten seconds. So basically I can't watch it. I could OC my RPi a bit more but I think it's quite at its maximum potential since it's the first RPi version (256).
I got another RPi (512) which I could OC a bit more and which is running Rasbpian. So I tried to read the same "BD-Rip" using omxplayer, in both cases using NFS mount from a high end Sinology NAS.
So I chose the biggest .m2ts file (by the way I don't have any idea what file is actually openned by openelec/XBMC), which seems to include everything like video stream, audio DTS_MA (I got an external hdmi receiver) and subtitles tracks.
When using oxmplayer -i "file.m2ts" I got some weird error messages : (full oxmplayer -i output at the end of the post)
[mpegts @ 0x2d1660] Stream #11: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Could not find codec parameters for stream 11 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
So I can open and play it using oxmplayer -o hdmi -p -aidx 1 -t 11 -r "file.m2ts" and it starts perfecly, no freeze at all and perfect video and sound fluidity BUT I got no subtitles...
I'm just struggling to get them working... That's so weird, how comes openelec/XBMC achieves to read/render them but omxplayer won't ?
I mean, I got a GPU with 128 split memory so basically, it should work... I might even try to reboot providing like 256 GPU split memory to check...
Anyway, I would really appreciate some feedback about this because I couldn't find much using google...
[dca @ 0x2f6250] Not a valid DCA frame
[dca @ 0x2f6ad0] Not a valid DCA frame
[mpegts @ 0x2d1660] Stream #12: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #13: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #14: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #15: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #16: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #17: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #18: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #19: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #20: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #21: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #22: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #23: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #24: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #25: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #26: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #27: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #28: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #29: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #30: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #31: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #32: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #33: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #34: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #35: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #36: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #37: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #38: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #39: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #40: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #41: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Stream #42: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0x2d1660] Could not find codec parameters for stream 12 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 13 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 14 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 15 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 16 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 17 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 18 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 19 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 20 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 21 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 22 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 23 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 24 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 25 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 26 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 27 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 28 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 29 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 30 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 31 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 32 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 33 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 34 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 35 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 36 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 37 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 38 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 39 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 40 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 41 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] Could not find codec parameters for stream 42 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0x2d1660] decoding for stream 43 failed
[mpegts @ 0x2d1660] Could not find codec parameters for stream 43 (Audio: dts ([162][0][0][0] / 0x00A2), 0 channels, fltp): unspecified sample rate
[mpegts @ 0x2d1660] decoding for stream 44 failed
[mpegts @ 0x2d1660] Could not find codec parameters for stream 44 (Audio: dts ([162][0][0][0] / 0x00A2), 0 channels, fltp): unspecified sample rate
[NULL @ 0x2e5110] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e5990] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e6210] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e6a90] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e7310] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e7b90] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e8410] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e8ce0] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e95e0] start time is not set in estimate_timings_from_pts
[NULL @ 0x2e9e60] start time is not set in estimate_timings_from_pts
[NULL @ 0x2ea740] start time is not set in estimate_timings_from_pts
[NULL @ 0x2eaf90] start time is not set in estimate_timings_from_pts
[NULL @ 0x2eb810] start time is not set in estimate_timings_from_pts
[NULL @ 0x2ec090] start time is not set in estimate_timings_from_pts
[NULL @ 0x2ec910] start time is not set in estimate_timings_from_pts
[NULL @ 0x2ed1d0] start time is not set in estimate_timings_from_pts
[NULL @ 0x2eda20] start time is not set in estimate_timings_from_pts
[NULL @ 0x2ee2a0] start time is not set in estimate_timings_from_pts
[NULL @ 0x2eeb40] start time is not set in estimate_timings_from_pts
[NULL @ 0x2ef3c0] start time is not set in estimate_timings_from_pts
[NULL @ 0x2efc40] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f04c0] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f0d40] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f1620] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f1e70] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f26f0] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f2fb0] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f3800] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f4080] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f4900] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f5180] start time is not set in estimate_timings_from_pts
[NULL @ 0x2f59d0] start time is not set in estimate_timings_from_pts
Input #0, mpegts, from '00333.m2ts':
Duration: 01:59:02.55, start: 11.650667, bitrate: 37885 kb/s
Program 1
Stream #0:0[0x1011]: Video: vc1 (Advanced) (VC-1 / 0x312D4356), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0:1[0x1100]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, 5.1(side), fltp, 1536 kb/s
Stream #0:2[0x1101]: Audio: dts (DTS) ([130][0][0][0] / 0x0082), 48000 Hz, 5.1(side), fltp, 768 kb/s
Stream #0:3[0x1102]: Audio: dts (DTS) ([130][0][0][0] / 0x0082), 48000 Hz, 5.1(side), fltp, 768 kb/s
Stream #0:4[0x1103]: Audio: dts (DTS) ([130][0][0][0] / 0x0082), 48000 Hz, 5.1(side), fltp, 768 kb/s
Stream #0:5[0x1104]: Audio: dts (DTS) ([130][0][0][0] / 0x0082), 48000 Hz, 5.1(side), fltp, 768 kb/s
Stream #0:6[0x1105]: Audio: dts (DTS) ([130][0][0][0] / 0x0082), 48000 Hz, 5.1(side), fltp, 768 kb/s
Stream #0:7[0x1106]: Audio: dts (DTS) ([130][0][0][0] / 0x0082), 48000 Hz, 5.1(side), fltp, 768 kb/s
Stream #0:8[0x1107]: Audio: dts (DTS) ([130][0][0][0] / 0x0082), 48000 Hz, 5.1(side), fltp, 768 kb/s
Stream #0:9[0x1108]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s
Stream #0:10[0x1109]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s
Stream #0:11[0x1200]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:12[0x1201]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:13[0x1202]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:14[0x1203]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:15[0x1204]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:16[0x1205]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:17[0x1206]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:18[0x1207]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:19[0x1208]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:20[0x1209]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:21[0x120a]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:22[0x120b]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:23[0x120c]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:24[0x120d]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:25[0x120e]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:26[0x120f]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:27[0x1210]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:28[0x1211]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:29[0x1212]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:30[0x1213]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:31[0x1214]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:32[0x1215]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:33[0x1216]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:34[0x1217]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:35[0x1218]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:36[0x1219]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:37[0x121a]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:38[0x121b]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:39[0x121c]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:40[0x121d]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:41[0x121e]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:42[0x121f]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:43[0x1a00]: Audio: dts ([162][0][0][0] / 0x00A2), 0 channels, fltp
Stream #0:44[0x1a01]: Audio: dts ([162][0][0][0] / 0x00A2), 0 channels, fltp
Stream #0:45[0x1b00]: Video: vc1 (Advanced) (VC-1 / 0x312D4356), yuv420p, 720x480 [SAR 10:11 DAR 15:11], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0:46[0x1b01]: Video: vc1 (Advanced) (VC-1 / 0x312D4356), yuv420p, 720x480 [SAR 40:33 DAR 20:11], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
have a nice day ;)
