dominic03
Raspberry Pi 3+ 55 degree idle
Sat Aug 10, 2019 5:17 pm
I left my Pi 3B+ to idle for about 15 minutes and when I came back it was at 55 degrees.
The only background tasks that might use CPU were pt-device-manager and LXPanel.
My Pi was booted to GUI.
The load averages were 0.19, 0.22, 2.32
Is 55 degrees normal for and idle temperature on the 3B+?
Raspberry Pi 4B running Raspbian Buster v3.1 (via PINN)
Kingston 32 GB C10 (U1) microSD
Sceptre E225W 22" 75hz 1080p monitor
Flash drive for backups and swap
-or-
pi-top 3 running Raspbian with drivers and pi-topHUB 2.0 / 16GB SanDisk C10 microSD
epoch1970
Re: Raspberry Pi 3+ 55 degree idle
Sat Aug 10, 2019 6:58 pm
For Pi 3B, not plus, in official case, I would say idle CPU temp is 20-30 deg. C over ambient temperature.
AFAIK 3B+ runs hotter.
Andyroo
Sat Aug 10, 2019 7:24 pm
Buster in a WD case (no fans or heatsink) with a 500Gb drive via USB next to it I'm getting 33 C - 40 C - It is cool here (evening time) and I do have a draft from the window being open but the case is basically a box with the only vents being out of the draft.
The box is not busy - Apache running but not serving any pages, MY/SQL running but no access and MQTT broker just sitting there.
Loading is 0.09 0.24 0.13
dominic03
Sat Aug 10, 2019 7:26 pm
33 degree idle with cooling, same conditions
-or-
Andyroo
Sat Aug 10, 2019 7:29 pm
I would think you will loose a little bit of air flow from the pi-top 3 case - from what I remember its a solid box (though do not like that green).
Maybe a spike in CPU not picked up the averages?
trejan
Sat Aug 10, 2019 7:34 pm
My 3B+ in a closed case with no heatsink or fan is idling around 53C.
Andyroo
Sat Aug 10, 2019 7:59 pm
Managed to get mine to 51C now with zero load (0.00 0.01 0.00) after 40 minutes with htop running over SSH.
I've fastened the lid on properly so I assume a draft was getting in - the magnetic catches on this box are not great
