mw0sec
Using printer on windows machine.
Fri Aug 09, 2019 6:36 pm
I have a printer which is sadly not supported with any of the cups stuff, nor is there a linux driver for it. Given that my windows machine DOES have it's suitable driver, I was wondering if there is a sneaky way to share the windows printer such that it uses its own driver to do the actual printing?
Re: Using printer on windows machine.
Fri Aug 09, 2019 6:59 pm
Google Cloud Print ???
https://www.google.com/cloudprint
mw0sec
Fri Aug 09, 2019 8:48 pm
Yes, Google print is worth a look. Seems a bit of a sledge hammer/nut relationship, but probably less of a pain than sharing the file to print, given that the kit lives in different locations! Thanks for the suggestion.
bls
Contact: Twitter
Fri Aug 09, 2019 9:57 pm
Worth asking...are you sure that there's no driver for it? Sometimes the Linux drivers aren't in a distro, but can be found on the net. Probably more true if it's a large printer manufacturer (HP, Epson, etc). Or maybe there's a supported driver for a printer that's "similar enough"?
Pi tools:
RPi SD Card Image Manager: https://github.com/gitbls/sdm
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
Easy VPN installer/manager: https://github.com/gitbls/pistrong
DNS/DHCP manager:https://github.com/gitbls/ndm
mw0sec
Sat Aug 10, 2019 9:46 am
No, I've done an exhausting search and these seems to be nothing available for this O.S. For the odd occasion where necessary I can of course just copy the file and then print, but being a bit of a perfectionist it would be nice to do the job properly!
Sat Aug 10, 2019 10:01 am
Is the Printer Manufacturer / Model top secret ?
mw0sec
Sat Aug 10, 2019 1:16 pm
No secret! It is a Dell 1320C colour laser jobbie. I did not bother to mention that, as some time ago I did post a request for knowledge of any drivers suitable for it using the mighty Raspberry. I did find one which works for another linux variant which I use on a PC (dual boot), but zilch that will work with the RP.
Sat Aug 10, 2019 1:42 pm
It appears to be a "rebadged" Fuji Xerox DocuPrint C525A
mw0sec
Sat Aug 10, 2019 1:44 pm
Agreed - but sadly that does not help.
bls
Contact: Twitter
Sat Aug 10, 2019 2:11 pm
I'm confused. Searching for "Fuji Xerox DocuPrint C525A Linux driver yields http://onlinesupport.fujixerox.com/proc ... rettyPhoto
Did you try this driver or find a reason that it wouldn't work?
Pi tools:
Sat Aug 10, 2019 2:20 pm
The available Linux Drivers are compiled for x86 CPU Architecture........
bls
Contact: Twitter
Sat Aug 10, 2019 2:30 pm
Doh! I outed myself as a non-CUPS user on Raspbian :lol:
Pi tools:
bls
Contact: Twitter
Sat Aug 10, 2019 3:51 pm
On a whim I downloaded the above-mentioned Fuji driver. Don't know if you looked at it, but it provides source! Of course, that may still not get you a working driver for your printer, but you never know...
Pi tools:
grim1964
Sat Aug 10, 2019 8:03 pm
I too have been trying to get this printer working using the Fuji driver. CUPS can see the printer on the network, so at least that's a good start!
Problem is that the driver is an rpm package for i386 architecture.
I gather that I need to use the alien command to convert this to a debian installation file, but I am having trouble doing this on a Raspberry Pi 4 (also I have zero experience of the process!).
I have run "sudo alien -g -d -v Fufi_Xerox-DocuPrint_C525_A_AP-1.0-1.i386.rpm --scripts" successfully (I added the --scripts parameter because running without it gave the message that scripts in the package had been skipped and suggested including it to convert them as well)
My understanding is that I then need to edit the debian/control file in the resulting directory to add the target architecture to the Architecture line (I ran "sudo nano debian/control" from within the directory and changed "Architecture: i386" to "Architecture: i386, armhf". Is this correct?).
I gather the next step is to run "sudo debian/rules binary", but this gives me error messages saying that the libraries "libcups.so.2" and "libc.so.6" cannot be found.
Searching for "libc.so.6" reveals that the file is present in /usr/lib with a shortcut in /lib/arm-linux-gnueabihf (I don't know how to verify the shortcut points to the correct place). When I search for "libcups.so.2" I find two copies, in the same two directories, but both these appear to be the genuine file rather than one being a shortcut. I can't remember if both copies were originally there, or if I made one of them in an attempt to get things working.
Any help getting this working would be appreciated.
Thanks.
mw0sec
Mon Aug 12, 2019 8:41 am
I take my hat off, in that you have gone farther with this exercise than I have! I will follow the thread with interest.
mw0sec
Tue Aug 13, 2019 9:06 am
Adding a 'VNC' printer does this job - well most of the time. It does seem a bit variable though, for example on occasions I can print from Leaf, but not from Libre Office. Sadly there seems to be little documentation on how this works, but when it does work, the results are perfect.
