erg
rpigpio Rpi 3B+ 64 bit pigpiod not starting "[solved]"
Fri Aug 09, 2019 1:43 pm
I'm running Gentoo 64 bit on Rpi 3B+,
trying to get pigpio working. I installed pigpio successfully through system package manager with python support (3.6 and 2.7 as fallback) with this patch for 64 bit kernel https://github.com/joan2937/pigpio/issues/266
following joan2937 (https://github.com/joan2937/pigpio/issues/49) tips:
 cat /etc/network/interfaces
auto wlan0
auto eth0
auto lo
iface lo inet loopback
but deamon fails to start:
/etc/init.d/pigpiod start
 * Starting pigpiod ...
/usr/bin/pigpiod: error while loading shared libraries: libpigpio.so: cannot open shared object file: No such file or directory
 * start-stop-daemon: failed to start `/usr/bin/pigpiod'
 * Failed to start pigpiod        [ !! ]
 * ERROR: pigpiod failed to start
in python interpreter:
python
Python 3.6.9 (default, Aug  6 2019, 18:42:28)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import pigpio
>>> pi = pigpio.pi()
Can't connect to pigpio at localhost(8888)
Did you start the pigpio daemon? E.g. sudo pigpiod
Did you specify the correct Pi host/port in the environment
variables PIGPIO_ADDR/PIGPIO_PORT?
E.g. export PIGPIO_ADDR=soft, export PIGPIO_PORT=8888
pigpio.pi() function? E.g. pigpio.pi('soft', 8888)
joan
Re: rpigpio Rpi 3B+ 64 bit pigpiod not starting
Fri Aug 09, 2019 3:22 pm
A 64-bit patch is incorporated in versions 69 and greater (thanks to plugwash). I don't have a 64-bit system but at least one person says it runs okay on the Pi4B with 64-bit.
https://github.com/joan2937/pigpio/issu ... -519066779
erg
Tue Aug 13, 2019 7:37 am
Thanks for a prompt reply. Waiting on Gentoo update of pigpio package then to test it.
erg
Tue Aug 13, 2019 11:28 am
I have now pigpio installed, daemon starts without complaining, python module also.
But:
python
>>> import pigpio
>>> pi = pigpio.pi()
Do you have permission to access the pigpio daemon?
Perhaps it was started with sudo pigpiod -nlocalhost
remains.
erg
Wed Aug 14, 2019 2:25 pm
Sorted with the new, post v70 patch
