Cannot write SD
Posted: Thu Dec 06, 2012 4:06 pm
by discomark10
Hi guys, this is my first PI. I'm gagging to use it (after waiting 4 months). But I seem to be having some problems getting the iso to write. (images for the cards ect below)
1st problem.
I have a Micro SD in an adapter, it seems to write fine ( either Debian or Raspbian ) but when I go to boot it flashes 4 ligts (I think, its rather fast possibly 3 lights).
2nd problem.
As the 1st method didnt work I brought an SD card which didnt work on the lil laptop which has the SD card reader built in, So I ended up buying a reader.
The new SD in the reader reads fine, but when I go to write to it, it either fails and acts as if the sd was removed (windows hardware removed sound and error 2 on win32 disk imager, Or it seems to write, but only takes 5 secconds (to fast for an almost 2gb file).
Oh and the lil write prtect button is in the right place ;)
HELP!!
Many thanks Mark
Re: Cannot write SD
Posted: Thu Dec 06, 2012 4:46 pm
by discomark10
Oh and the micro SD in the adapter in the new reader also does the same thing (fails with error 2 ect..)
Re: Cannot write SD
Posted: Thu Dec 06, 2012 4:55 pm
by Dweeber
I only use MicroSDHC cards in all of my RPi in SDCard adapters... Writing via USB (When it is in a USB Thumb drive) is much better supported than using a regular SDCard in a lot of computers.
If you have one, you should try a different SDCard adapter for your MicroSD card. They are sometimes loose... and it is possible that their might be something wrong with it.
Re: Cannot write SD
Posted: Thu Dec 06, 2012 5:02 pm
by discomark10
Dweeber wrote:I only use MicroSDHC cards in all of my RPi in SDCard adapters... Writing via USB (When it is in a USB Thumb drive) is much better supported than using a regular SDCard in a lot of computers.
The reader was lose, but I've since sorted it. seems to start to write.. just like the normal SD but the errors.
