maxbelyx21
Raspberry Pi Zero W - Wifi issues
Mon Aug 05, 2019 7:57 pm
Hello!
First of all, I re-read a ton of information on this issue and haven’t found a single solution anywhere, I hope someone from the official forum can help me, I really hope.
Problem: I have a Raspberry Pi Zero W version 1.1 and a Kingston 8Gb SD card. The image of the operating system is the "Buster" from the official site - the light version.
To record SD card I am using latest version of Etcher under Mac OS Mojave. After that I am adding two files: "ssh" and "wpa_supplicant.conf".
First problem - UART CLI is not working. To solve this problem I am editing the file config.txt in boot section of SD card. Changes consist of adding a line
enable_uart=1
. After that i can connect to RPi via UART (screen /dev/cu.SLAB_USBtoUART 115200) in terminal and login.
After that I stumble upon the biggest problem: I run the raspi-config, select the second item "Network options" and than "N2 WiFi" and after that I see "No wireless interface found".
If I enter
ifconfig -a
I only see:
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
For:
cat /proc/cpuinfo
[email protected]:~$ cat /proc/cpuinfo
processor       : 0
model name      : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS        : 697.95
Features        : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2835
Revision        : 9000c1
Serial          : 0000000042fbdfbf
I am sure that wifi work was before, and I absolutely do not understand what could be the problem. I tried all the operating systems that were before, anyway, wifi did not work anywhere.
Thanks in advance for any help,
Respectfully,
Max
Stulander
Re: Raspberry Pi Zero W - Wifi issues
Tue Aug 27, 2019 2:33 pm
I am getting the same problem on a Raspberry Pi Zero W 1.1. Raspbian Buster Lite version July 2019.
I think the latest Raspbian has broken wifi. Same results as above.
PhatFil
Tue Aug 27, 2019 3:35 pm
Unless you NEED buster for something? Perhaps look at using Stretch for now as thats tried and tested,
Give it a few weeks till the usual distro upgrade path is tested and recommended before shifting to Buster,
Buster is only NECESSARY if running on a Pi4..
With regular Pi4 centric fixes going on atm the backward compatibility required for a Pi-0 may experience a few hicups, its an understandable consequence of a broad project scope and focus on the current h/w where more issues are occuring ..
Wait until the 'sands settle' and you can upgrade to buster with an apt-get command and a lil wait rather than performing a fresh install of everything.
After all you may find further Buster issues with s/w systems you want to use too,
Stulander
Wed Aug 28, 2019 9:52 am
I just tried the last two recent releases of stretch lite and I get the same issue.
2019-04-08 and 2018-11-13
The board is flashed correctly, no additional hardware etc. It is definitely a pi zero w 1.1.
No wlan0 interface. I'll try the full release of stretch now.
Yep same issue. raspbian-2019-04-09 full, ifconfig -a shows no wlan interface.
journalctl output:
-- Logs begin at Mon 2019-04-08 11:30:48 BST, end at Mon 2019-04-08 11:52:58 BST. --
Apr 08 11:30:48 raspberrypi kernel: Booting Linux on physical CPU 0x0
Apr 08 11:30:48 raspberrypi kernel: Linux version 4.14.98+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1200 Tue Feb 12 20:11:02 GMT 2019
Apr 08 11:30:48 raspberrypi kernel: CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Apr 08 11:30:48 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Apr 08 11:30:48 raspberrypi kernel: OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
Apr 08 11:30:48 raspberrypi kernel: Memory policy: Data cache writeback
Apr 08 11:30:48 raspberrypi kernel: cma: Reserved 8 MiB at 0x1b400000
Apr 08 11:30:48 raspberrypi kernel: On node 0 totalpages: 114688
Apr 08 11:30:48 raspberrypi kernel: free_area_init_node: node 0, pgdat c09caaf0, node_mem_map db010000
Apr 08 11:30:48 raspberrypi kernel:   Normal zone: 1008 pages used for memmap
Apr 08 11:30:48 raspberrypi kernel:   Normal zone: 0 pages reserved
Apr 08 11:30:48 raspberrypi kernel:   Normal zone: 114688 pages, LIFO batch:31
Apr 08 11:30:48 raspberrypi kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Apr 08 11:30:48 raspberrypi kernel: pcpu-alloc: [0] 0
Apr 08 11:30:48 raspberrypi kernel: Built 1 zonelists, mobility grouping on.  Total pages: 113680
Apr 08 11:30:48 raspberrypi kernel: Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1200 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:B2:C9:75 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=e6314e18-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
Apr 08 11:30:48 raspberrypi kernel: PID hash table entries: 2048 (order: 1, 8192 bytes)
Apr 08 11:30:48 raspberrypi kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Apr 08 11:30:48 raspberrypi kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Apr 08 11:30:48 raspberrypi kernel: Memory: 435204K/458752K available (6451K kernel code, 589K rwdata, 1992K rodata, 440K init, 673K bss, 15356K reserved, 8192K cma-reserved)
Apr 08 11:30:48 raspberrypi kernel: Virtual kernel memory layout:
                                        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                        vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
                                        lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
                                        modules : 0xbf000000 - 0xc0000000   (  16 MB)
                                          .text : 0xc0008000 - 0xc0655050   (6453 kB)
                                          .init : 0xc08d4000 - 0xc0942000   ( 440 kB)
                                          .data : 0xc0942000 - 0xc09d54f8   ( 590 kB)
                                           .bss : 0xc09dadf0 - 0xc0a8338c   ( 674 kB)
Apr 08 11:30:48 raspberrypi kernel: SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Apr 08 11:30:48 raspberrypi kernel: ftrace: allocating 24128 entries in 71 pages
Apr 08 11:30:48 raspberrypi kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Apr 08 11:30:48 raspberrypi kernel: sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Apr 08 11:30:48 raspberrypi kernel: clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Apr 08 11:30:48 raspberrypi kernel: bcm2835: system timer (irq = 27)
Apr 08 11:30:48 raspberrypi kernel: Console: colour dummy device 80x30
Apr 08 11:30:48 raspberrypi kernel: console [tty1] enabled
Apr 08 11:30:48 raspberrypi kernel: Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Apr 08 11:30:48 raspberrypi kernel: pid_max: default: 32768 minimum: 301
Apr 08 11:30:48 raspberrypi kernel: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Apr 08 11:30:48 raspberrypi kernel: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Apr 08 11:30:48 raspberrypi kernel: Disabling memory control group subsystem
Apr 08 11:30:48 raspberrypi kernel: CPU: Testing write buffer coherency: ok
Apr 08 11:30:48 raspberrypi kernel: Setting up static identity map for 0x8200 - 0x8238
Apr 08 11:30:48 raspberrypi kernel: devtmpfs: initialized
Apr 08 11:30:48 raspberrypi kernel: random: get_random_u32 called from bucket_table_alloc+0x88/0x1c4 with crng_init=0
Apr 08 11:30:48 raspberrypi kernel: VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Apr 08 11:30:48 raspberrypi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Apr 08 11:30:48 raspberrypi kernel: futex hash table entries: 256 (order: -1, 3072 bytes)
Apr 08 11:30:48 raspberrypi kernel: pinctrl core: initialized pinctrl subsystem
Apr 08 11:30:48 raspberrypi kernel: NET: Registered protocol family 16
Apr 08 11:30:48 raspberrypi kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
Apr 08 11:30:48 raspberrypi kernel: hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Apr 08 11:30:48 raspberrypi kernel: hw-breakpoint: maximum watchpoint size is 4 bytes.
Apr 08 11:30:48 raspberrypi kernel: Serial: AMBA PL011 UART driver
Apr 08 11:30:48 raspberrypi kernel: bcm2835-mbox 2000b880.mailbox: mailbox enabled
Apr 08 11:30:48 raspberrypi kernel: uart-pl011 20201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
Apr 08 11:30:48 raspberrypi kernel: bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Apr 08 11:30:48 raspberrypi kernel: SCSI subsystem initialized
Apr 08 11:30:48 raspberrypi kernel: usbcore: registered new interface driver usbfs
Apr 08 11:30:48 raspberrypi kernel: usbcore: registered new interface driver hub
Apr 08 11:30:48 raspberrypi kernel: usbcore: registered new device driver usb
Apr 08 11:30:48 raspberrypi kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2019-03-27 15:45
Apr 08 11:30:48 raspberrypi kernel: clocksource: Switched to clocksource timer
Apr 08 11:30:48 raspberrypi kernel: VFS: Disk quotas dquot_6.6.0
Apr 08 11:30:48 raspberrypi kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Apr 08 11:30:48 raspberrypi kernel: FS-Cache: Loaded
Apr 08 11:30:48 raspberrypi kernel: CacheFiles: Loaded
Apr 08 11:30:48 raspberrypi kernel: NET: Registered protocol family 2
Apr 08 11:30:48 raspberrypi kernel: TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Apr 08 11:30:48 raspberrypi kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Apr 08 11:30:48 raspberrypi kernel: TCP: Hash tables configured (established 4096 bind 4096)
Apr 08 11:30:48 raspberrypi kernel: UDP hash table entries: 256 (order: 0, 4096 bytes)
Apr 08 11:30:48 raspberrypi kernel: UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Apr 08 11:30:48 raspberrypi kernel: RPC: Registered named UNIX socket transport module.
Apr 08 11:30:48 raspberrypi kernel: RPC: Registered udp transport module.
Apr 08 11:30:48 raspberrypi kernel: RPC: Registered tcp transport module.
Apr 08 11:30:48 raspberrypi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Apr 08 11:30:48 raspberrypi kernel: hw perfevents: no irqs for PMU, sampling events not supported
Apr 08 11:30:48 raspberrypi kernel: hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Apr 08 11:30:48 raspberrypi kernel: workingset: timestamp_bits=14 max_order=17 bucket_order=3
Apr 08 11:30:48 raspberrypi kernel: FS-Cache: Netfs 'nfs' registered for caching
Apr 08 11:30:48 raspberrypi kernel: NFS: Registering the id_resolver key type
Apr 08 11:30:48 raspberrypi kernel: Key type id_resolver registered
Apr 08 11:30:48 raspberrypi kernel: Key type id_legacy registered
Apr 08 11:30:48 raspberrypi kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Apr 08 11:30:48 raspberrypi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Apr 08 11:30:48 raspberrypi kernel: io scheduler noop registered
Apr 08 11:30:48 raspberrypi kernel: io scheduler deadline registered (default)
Apr 08 11:30:48 raspberrypi kernel: io scheduler cfq registered
Apr 08 11:30:48 raspberrypi kernel: io scheduler mq-deadline registered
Apr 08 11:30:48 raspberrypi kernel: io scheduler kyber registered
Apr 08 11:30:48 raspberrypi kernel: BCM2708FB: allocated DMA memory 5b500000
Apr 08 11:30:48 raspberrypi kernel: BCM2708FB: allocated DMA channel 0 @ dc80d000
Apr 08 11:30:48 raspberrypi kernel: Console: switching to colour frame buffer device 240x75
Apr 08 11:30:48 raspberrypi kernel: bcm2835-rng 20104000.rng: hwrng registered
Apr 08 11:30:48 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Apr 08 11:30:48 raspberrypi kernel: vc-sm: Videocore shared memory driver
Apr 08 11:30:48 raspberrypi kernel: gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Apr 08 11:30:48 raspberrypi kernel: brd: module loaded
Apr 08 11:30:48 raspberrypi kernel: loop: module loaded
Apr 08 11:30:48 raspberrypi kernel: Loading iSCSI transport class v2.0-870.
Apr 08 11:30:48 raspberrypi kernel: usbcore: registered new interface driver smsc95xx
Apr 08 11:30:48 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Apr 08 11:30:48 raspberrypi kernel: dwc_otg 20980000.usb: base=0xf0980000
Apr 08 11:30:48 raspberrypi kernel: Core Release: 2.80a
Apr 08 11:30:48 raspberrypi kernel: Setting default values for core params
Apr 08 11:30:48 raspberrypi kernel: Finished setting default values for core params
Apr 08 11:30:48 raspberrypi kernel: Using Buffer DMA mode
Apr 08 11:30:48 raspberrypi kernel: Periodic Transfer Interrupt Enhancement - disabled
Apr 08 11:30:48 raspberrypi kernel: Multiprocessor Interrupt Enhancement - disabled
Apr 08 11:30:48 raspberrypi kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
Apr 08 11:30:48 raspberrypi kernel: Dedicated Tx FIFOs mode
Apr 08 11:30:48 raspberrypi kernel: WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Apr 08 11:30:48 raspberrypi kernel: FIQ FSM acceleration enabled for :
                                    Non-periodic Split Transactions
                                    Periodic Split Transactions
                                    High-Speed Isochronous Endpoints
                                    Interrupt/Control Split Transaction hack enabled
Apr 08 11:30:48 raspberrypi kernel: dwc_otg: Microframe scheduler enabled
Apr 08 11:30:48 raspberrypi kernel: WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04a00d0
Apr 08 11:30:48 raspberrypi kernel: WARN::hcd_init_fiq:460: FIQ ASM at 0xc04a03ac length 36
Apr 08 11:30:48 raspberrypi kernel: WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
Apr 08 11:30:48 raspberrypi kernel: dwc_otg 20980000.usb: DWC OTG Controller
Apr 08 11:30:48 raspberrypi kernel: dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Apr 08 11:30:48 raspberrypi kernel: dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Apr 08 11:30:48 raspberrypi kernel: Init: Port Power? op_state=1
Apr 08 11:30:48 raspberrypi kernel: Init: Power Port (0)
Apr 08 11:30:48 raspberrypi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Apr 08 11:30:48 raspberrypi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Apr 08 11:30:48 raspberrypi kernel: usb usb1: Product: DWC OTG Controller
Apr 08 11:30:49 raspberrypi kernel: usb usb1: Manufacturer: Linux 4.14.98+ dwc_otg_hcd
Apr 08 11:30:49 raspberrypi kernel: usb usb1: SerialNumber: 20980000.usb
Apr 08 11:30:49 raspberrypi kernel: hub 1-0:1.0: USB hub found
Apr 08 11:30:49 raspberrypi kernel: hub 1-0:1.0: 1 port detected
Apr 08 11:30:49 raspberrypi kernel: dwc_otg: FIQ enabled
Apr 08 11:30:49 raspberrypi kernel: dwc_otg: NAK holdoff enabled
Apr 08 11:30:49 raspberrypi kernel: dwc_otg: FIQ split-transaction FSM enabled
Apr 08 11:30:49 raspberrypi kernel: Module dwc_common_port init
Apr 08 11:30:49 raspberrypi kernel: usbcore: registered new interface driver usb-storage
Apr 08 11:30:49 raspberrypi kernel: mousedev: PS/2 mouse device common for all mice
Apr 08 11:30:49 raspberrypi kernel: IR NEC protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: IR RC5(x/sz) protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: IR RC6 protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: IR JVC protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: IR Sony protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: IR SANYO protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: IR Sharp protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: IR MCE Keyboard/mouse protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: IR XMP protocol handler initialized
Apr 08 11:30:49 raspberrypi kernel: bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Apr 08 11:30:49 raspberrypi kernel: bcm2835-cpufreq: min=700000 max=1000000
Apr 08 11:30:49 raspberrypi kernel: sdhci: Secure Digital Host Controller Interface driver
Apr 08 11:30:49 raspberrypi kernel: sdhci: Copyright(c) Pierre Ossman
Apr 08 11:30:49 raspberrypi kernel: mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Apr 08 11:30:49 raspberrypi kernel: sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
Apr 08 11:30:49 raspberrypi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Apr 08 11:30:49 raspberrypi kernel: ledtrig-cpu: registered to indicate activity on CPUs
Apr 08 11:30:49 raspberrypi kernel: hidraw: raw HID events driver (C) Jiri Kosina
Apr 08 11:30:49 raspberrypi kernel: usbcore: registered new interface driver usbhid
Apr 08 11:30:49 raspberrypi kernel: usbhid: USB HID core driver
Apr 08 11:30:49 raspberrypi kernel: vchiq: vchiq_init_state: slot_zero = db580000, is_master = 0
Apr 08 11:30:49 raspberrypi kernel: [vc_sm_connected_init]: start
Apr 08 11:30:49 raspberrypi kernel: [vc_sm_connected_init]: end - returning 0
Apr 08 11:30:49 raspberrypi kernel: Initializing XFRM netlink socket
Apr 08 11:30:49 raspberrypi kernel: NET: Registered protocol family 17
Apr 08 11:30:49 raspberrypi kernel: Key type dns_resolver registered
Apr 08 11:30:49 raspberrypi kernel: registered taskstats version 1
Apr 08 11:30:49 raspberrypi kernel: uart-pl011 20201000.serial: cts_event_workaround enabled
Apr 08 11:30:49 raspberrypi kernel: 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Apr 08 11:30:49 raspberrypi kernel: mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Apr 08 11:30:49 raspberrypi kernel: mmc-bcm2835 20300000.mmc: DMA channel allocated
Apr 08 11:30:49 raspberrypi kernel: sdhost: log_buf @ db513000 (5b513000)
Apr 08 11:30:49 raspberrypi kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Apr 08 11:30:49 raspberrypi kernel: of_cfs_init
Apr 08 11:30:49 raspberrypi kernel: of_cfs_init: OK
Apr 08 11:30:49 raspberrypi kernel: Waiting for root device PARTUUID=e6314e18-02...
Apr 08 11:30:49 raspberrypi kernel: Indeed it is in host mode hprt0 = 00041901
Apr 08 11:30:49 raspberrypi kernel: random: fast init done
Apr 08 11:30:49 raspberrypi kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Apr 08 11:30:49 raspberrypi kernel: mmc0: new high speed SDHC card at address aaaa
Apr 08 11:30:49 raspberrypi kernel: mmcblk0: mmc0:aaaa ACLCD 29.7 GiB
Apr 08 11:30:49 raspberrypi kernel:  mmcblk0: p1 p2
Apr 08 11:30:49 raspberrypi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Apr 08 11:30:49 raspberrypi kernel: VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Apr 08 11:30:49 raspberrypi kernel: devtmpfs: mounted
Apr 08 11:30:49 raspberrypi kernel: Freeing unused kernel memory: 440K
Apr 08 11:30:49 raspberrypi kernel: This architecture does not have kernel memory protection.
Apr 08 11:30:49 raspberrypi kernel: usb 1-1: new low-speed USB device number 2 using dwc_otg
Apr 08 11:30:49 raspberrypi kernel: usb 1-1: New USB device found, idVendor=03f0, idProduct=304a
Apr 08 11:30:49 raspberrypi kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 08 11:30:49 raspberrypi kernel: usb 1-1: Product: HP Business Slim Keyboard
Apr 08 11:30:49 raspberrypi kernel: usb 1-1: Manufacturer: Chicony
Apr 08 11:30:49 raspberrypi kernel: input: Chicony HP Business Slim Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:03F0:304A.0001/input/input0
Apr 08 11:30:49 raspberrypi kernel: hid-generic 0003:03F0:304A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Business Slim Keyboard] on usb-20980000.usb-1/input0
Apr 08 11:30:49 raspberrypi kernel: input: Chicony HP Business Slim Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.1/0003:03F0:304A.0002/input/input1
Apr 08 11:30:49 raspberrypi kernel: hid-generic 0003:03F0:304A.0002: input,hiddev96,hidraw1: USB HID v1.10 Device [Chicony HP Business Slim Keyboard] on usb-20980000.usb-1/input1
Apr 08 11:30:49 raspberrypi systemd[1]: System time before build time, advancing clock.
Apr 08 11:30:49 raspberrypi kernel: NET: Registered protocol family 10
Apr 08 11:30:49 raspberrypi kernel: Segment Routing with IPv6
Apr 08 11:30:49 raspberrypi kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Apr 08 11:30:49 raspberrypi kernel: random: systemd: uninitialized urandom read (16 bytes read)
Apr 08 11:30:49 raspberrypi systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
Apr 08 11:30:49 raspberrypi systemd[1]: Detected architecture arm.
Apr 08 11:30:49 raspberrypi systemd[1]: Set hostname to <raspberrypi>.
Apr 08 11:30:49 raspberrypi systemd[1]: Initializing machine ID from random generator.
Apr 08 11:30:49 raspberrypi systemd[1]: Installed transient /etc/machine-id file.
Apr 08 11:30:49 raspberrypi systemd[1]: Created slice User and Session Slice.
Apr 08 11:30:49 raspberrypi systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Apr 08 11:30:49 raspberrypi systemd[1]: Listening on udev Kernel Socket.
Apr 08 11:30:49 raspberrypi systemd[1]: Listening on Syslog Socket.
Apr 08 11:30:49 raspberrypi systemd[1]: Created slice System Slice.
Apr 08 11:30:49 raspberrypi kernel: i2c /dev entries driver
Apr 08 11:30:49 raspberrypi systemd-journald[78]: Journal started
Apr 08 11:30:49 raspberrypi systemd-journald[78]: Runtime journal (/run/log/journal/423526d90c9f47209546fe6d2c0710d2) is 2.7M, max 21.6M, 18.9M free.
Apr 08 11:30:49 raspberrypi systemd-modules-load[75]: Inserted module 'i2c_dev'
Apr 08 11:30:49 raspberrypi fake-hwclock[67]: Mon  8 Apr 10:30:48 UTC 2019
Apr 08 11:30:49 raspberrypi systemd-fsck[91]: e2fsck 1.43.4 (31-Jan-2017)
Apr 08 11:30:49 raspberrypi systemd-fsck[91]: Superblock last write time is in the future.
Apr 08 11:30:49 raspberrypi systemd-fsck[91]:         (by less than a day, probably due to the hardware clock being incorrectly set)
Apr 08 11:30:49 raspberrypi systemd-fsck[91]: rootfs: clean, 92569/209664 files, 679210/837632 blocks
Apr 08 11:30:50 raspberrypi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Apr 08 11:30:50 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Apr 08 11:30:50 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Apr 08 11:30:50 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Apr 08 11:30:50 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Apr 08 11:30:50 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Apr 08 11:30:50 raspberrypi systemd[1]: Started Load/Save Random Seed.
Apr 08 11:30:50 raspberrypi systemd-journald[78]: Runtime journal (/run/log/journal/423526d90c9f47209546fe6d2c0710d2) is 2.7M, max 21.6M, 18.9M free.
Apr 08 11:30:50 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Apr 08 11:30:51 raspberrypi systemd[1]: Started Set the console keyboard layout.
Apr 08 11:30:51 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Apr 08 11:30:52 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Apr 08 11:30:52 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Apr 08 11:30:52 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Apr 08 11:30:52 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Apr 08 11:30:52 raspberrypi systemd[1]: Reached target Paths.
Apr 08 11:30:52 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Apr 08 11:30:53 raspberrypi systemd[1]: Found device /dev/serial1.
Apr 08 11:30:54 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/e6314e18-01.
Apr 08 11:30:54 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/e6314e18-01...
Apr 08 11:30:54 raspberrypi kernel: snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Apr 08 11:30:54 raspberrypi kernel: bcm2835_alsa bcm2835_alsa: card created with 8 channels
Apr 08 11:30:54 raspberrypi mtp-probe[144]: checking bus 1, device 2: "/sys/devices/platform/soc/20980000.usb/usb1/1-1"
Apr 08 11:30:54 raspberrypi mtp-probe[144]: bus: 1, device: 2 was not an MTP device
Apr 08 11:30:54 raspberrypi systemd-fsck[145]: fsck.fat 4.1 (2017-01-24)
Apr 08 11:30:54 raspberrypi systemd-fsck[145]: /dev/mmcblk0p1: 186 files, 44073/86467 clusters
Apr 08 11:30:54 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/e6314e18-01.
Apr 08 11:30:55 raspberrypi systemd[1]: Mounting /boot...
Apr 08 11:30:55 raspberrypi systemd[1]: Mounted /boot.
Apr 08 11:30:55 raspberrypi systemd[1]: Reached target Local File Systems.
Apr 08 11:30:55 raspberrypi systemd[1]: Starting Commit a transient machine-id on disk...
Apr 08 11:30:55 raspberrypi systemd[1]: Starting Set console font and keymap...
Apr 08 11:30:55 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Apr 08 11:30:55 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Apr 08 11:30:55 raspberrypi systemd[1]: Starting Raise network interfaces...
Apr 08 11:30:55 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Apr 08 11:30:55 raspberrypi systemd[1]: Started Commit a transient machine-id on disk.
Apr 08 11:30:55 raspberrypi systemd[1]: Started Set console font and keymap.
Apr 08 11:30:55 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Apr 08 11:30:56 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Apr 08 11:30:56 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Apr 08 11:30:56 raspberrypi systemd[1]: Starting Network Time Synchronization...
Apr 08 11:30:56 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Apr 08 11:30:56 raspberrypi systemd[1]: Reached target NFS client services.
Apr 08 11:30:56 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Apr 08 11:30:56 raspberrypi systemd[1]: Reached target Remote File Systems.
Apr 08 11:30:57 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Apr 08 11:30:57 raspberrypi systemd[1]: Started Network Time Synchronization.
Apr 08 11:30:57 raspberrypi systemd[1]: Reached target System Time Synchronized.
Apr 08 11:30:57 raspberrypi systemd[1]: Reached target System Initialization.
Apr 08 11:30:57 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Apr 08 11:30:57 raspberrypi systemd[1]: apt-daily.timer: Adding 7h 57min 42.445981s random time.
Apr 08 11:30:57 raspberrypi systemd[1]: Started Daily apt download activities.
Apr 08 11:30:57 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 48min 37.166097s random time.
Apr 08 11:30:57 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Apr 08 11:30:57 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Apr 08 11:30:57 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Apr 08 11:30:57 raspberrypi systemd[1]: Reached target Sockets.
Apr 08 11:30:57 raspberrypi systemd[1]: Reached target Basic System.
Apr 08 11:30:57 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Apr 08 11:30:57 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Apr 08 11:30:57 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Apr 08 11:30:57 raspberrypi systemd[1]: Starting Copy user wpa_supplicant.conf...
Apr 08 11:30:57 raspberrypi thd[208]: Found socket passed from systemd
Apr 08 11:30:58 raspberrypi systemd[1]: Starting LSB: Resize the root filesystem to fill partition...
Apr 08 11:30:58 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Apr 08 11:30:58 raspberrypi systemd[1]: Starting System Logging Service...
Apr 08 11:30:58 raspberrypi systemd[1]: Starting Check for v3d driver...
Apr 08 11:30:58 raspberrypi systemd[1]: Starting Login Service...
Apr 08 11:30:58 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Apr 08 11:30:58 raspberrypi avahi-daemon[217]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Apr 08 11:30:58 raspberrypi avahi-daemon[217]: Successfully dropped root privileges.
Apr 08 11:30:58 raspberrypi avahi-daemon[217]: avahi-daemon 0.6.32 starting up.
Apr 08 11:30:58 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Apr 08 11:30:58 raspberrypi liblogging-stdlog[221]:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="221" x-info="http://www.rsyslog.com"] start
Apr 08 11:30:59 raspberrypi kernel: uart-pl011 20201000.serial: no DMA platform data
Apr 08 11:30:59 raspberrypi avahi-daemon[217]: Successfully called chroot().
Apr 08 11:30:59 raspberrypi avahi-daemon[217]: Successfully dropped remaining capabilities.
Apr 08 11:30:59 raspberrypi avahi-daemon[217]: No service file found in /etc/avahi/services.
Apr 08 11:30:59 raspberrypi avahi-daemon[217]: Network interface enumeration completed.
Apr 08 11:30:59 raspberrypi avahi-daemon[217]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 702996553.
Apr 08 11:30:59 raspberrypi dbus[227]: [system] Successfully activated service 'org.freedesktop.systemd1'
Apr 08 11:30:59 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Apr 08 11:30:59 raspberrypi systemd[1]: Starting WPA supplicant...
Apr 08 11:30:59 raspberrypi systemd[1]: Starting Regenerate SSH host keys...
Apr 08 11:30:59 raspberrypi systemd[1]: Started Regular background program processing daemon.
Apr 08 11:30:59 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Apr 08 11:30:59 raspberrypi systemd[1]: Reached target Timers.
Apr 08 11:30:59 raspberrypi systemd[1]: Starting rng-tools.service...
Apr 08 11:30:59 raspberrypi cron[256]: (CRON) INFO (pidfile fd = 3)
Apr 08 11:30:59 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
Apr 08 11:31:00 raspberrypi cron[256]: (CRON) INFO (Running @reboot jobs)
Apr 08 11:31:00 raspberrypi dd[255]: 1+0 records in
Apr 08 11:31:00 raspberrypi dd[255]: 1+0 records out
Apr 08 11:31:00 raspberrypi dd[255]: 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.332994 s, 12.3 kB/s
Apr 08 11:31:00 raspberrypi wpa_supplicant[254]: Successfully initialized wpa_supplicant
Apr 08 11:31:00 raspberrypi rng-tools[257]: Starting Hardware RNG entropy gatherer daemon: rngd.
Apr 08 11:31:00 raspberrypi rngd[261]: rngd 2-unofficial-mt.14 starting up...
Apr 08 11:31:00 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Apr 08 11:31:00 raspberrypi alsactl[258]: /usr/sbin/alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
Apr 08 11:31:00 raspberrypi systemd[1]: Started System Logging Service.
Apr 08 11:31:00 raspberrypi alsactl[258]: Found hardware: "bcm2835_alsa" "Broadcom Mixer" "" "" ""
Apr 08 11:31:00 raspberrypi alsactl[258]: Hardware is initialized using a generic method
Apr 08 11:31:00 raspberrypi kernel: random: crng init done
Apr 08 11:31:00 raspberrypi kernel: random: 7 urandom warning(s) missed due to ratelimiting
Apr 08 11:31:00 raspberrypi rngd[261]: entropy feed to the kernel ready
Apr 08 11:31:00 raspberrypi systemd[1]: Started Check for v3d driver.
Apr 08 11:31:00 raspberrypi systemd[1]: Started rng-tools.service.
Apr 08 11:31:00 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
Apr 08 11:31:00 raspberrypi systemd[1]: Started Copy user wpa_supplicant.conf.
Apr 08 11:31:02 raspberrypi systemd[1]: Started WPA supplicant.
Apr 08 11:31:02 raspberrypi systemd-logind[224]: New seat seat0.
Apr 08 11:31:02 raspberrypi systemd[1]: Started Login Service.
Apr 08 11:31:02 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Apr 08 11:31:02 raspberrypi systemd[1]: Starting Disable WiFi if country not set...
Apr 08 11:31:03 raspberrypi systemd[1]: Started Disable WiFi if country not set.
Apr 08 11:31:03 raspberrypi dhcpcd[280]: dev: loaded udev
Apr 08 11:31:03 raspberrypi dhcpcd[280]: no valid interfaces found
Apr 08 11:31:03 raspberrypi dhcpcd[280]: forked to background, child pid 287
Apr 08 11:31:03 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: Core ver 2.22
Apr 08 11:31:04 raspberrypi kernel: NET: Registered protocol family 31
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: HCI device and connection manager initialized
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: HCI socket layer initialized
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: L2CAP socket layer initialized
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: SCO socket layer initialized
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: HCI UART driver ver 2.3
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: HCI UART protocol H4 registered
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
Apr 08 11:31:04 raspberrypi kernel: Bluetooth: HCI UART protocol Broadcom registered
Apr 08 11:31:04 raspberrypi btuart[225]: bcm43xx_init
Apr 08 11:31:04 raspberrypi btuart[225]: Flash firmware /lib/firmware/brcm/BCM43430A1.hcd
Apr 08 11:31:04 raspberrypi btuart[225]: Set BDADDR UART: b8:27:eb:18:63:df
Apr 08 11:31:04 raspberrypi btuart[225]: Set Controller UART speed to 3000000 bit/s
Apr 08 11:31:04 raspberrypi btuart[225]: Device setup complete
Apr 08 11:31:04 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Apr 08 11:31:04 raspberrypi systemd[1]: Reached target Sound Card.
Apr 08 11:31:05 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Apr 08 11:31:05 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Apr 08 11:31:06 raspberrypi systemd[1]: Created slice system-bthelper.slice.
Apr 08 11:31:06 raspberrypi systemd[1]: Starting Bluetooth service...
Apr 08 11:31:06 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Apr 08 11:31:06 raspberrypi systemd-udevd[114]: Process '/usr/sbin/alsactl -E HOME=/run/alsa restore 0' failed with exit code 99.
Apr 08 11:31:07 raspberrypi bluetoothd[305]: Bluetooth daemon 5.43
Apr 08 11:31:07 raspberrypi systemd[1]: Started Bluetooth service.
Apr 08 11:31:07 raspberrypi bluetoothd[305]: Starting SDP server
Apr 08 11:31:07 raspberrypi systemd[1]: Started BluezALSA proxy.
Apr 08 11:31:07 raspberrypi systemd[1]: Reached target Bluetooth.
Apr 08 11:31:07 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
Apr 08 11:31:07 raspberrypi kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Apr 08 11:31:07 raspberrypi kernel: Bluetooth: BNEP filters: protocol multicast
Apr 08 11:31:07 raspberrypi kernel: Bluetooth: BNEP socket layer initialized
Apr 08 11:31:07 raspberrypi bluetoothd[305]: Bluetooth management interface 1.14 initialized
Apr 08 11:31:07 raspberrypi bluetoothd[305]: Failed to obtain handles for "Service Changed" characteristic
Apr 08 11:31:07 raspberrypi dbus[227]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Apr 08 11:31:07 raspberrypi bluetoothd[305]: Sap driver initialization failed.
Apr 08 11:31:07 raspberrypi bluetoothd[305]: sap-server: Operation not permitted (1)
Apr 08 11:31:07 raspberrypi bluetoothd[305]: Failed to set privacy: Rejected (0x0b)
Apr 08 11:31:07 raspberrypi systemd[1]: Starting Hostname Service...
Apr 08 11:31:08 raspberrypi bluetoothd[305]: Endpoint registered: sender=:1.5 path=/A2DP/SBC/Source/1
Apr 08 11:31:08 raspberrypi kernel: Bluetooth: RFCOMM TTY layer initialized
Apr 08 11:31:08 raspberrypi kernel: Bluetooth: RFCOMM socket layer initialized
Apr 08 11:31:08 raspberrypi kernel: Bluetooth: RFCOMM ver 1.11
Apr 08 11:31:08 raspberrypi systemd-udevd[120]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:31:08 raspberrypi systemd-udevd[109]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:31:08 raspberrypi systemd-udevd[124]: Process '/sbin/crda' failed with exit code 249.
Apr 08 11:31:08 raspberrypi dbus[227]: [system] Successfully activated service 'org.freedesktop.hostname1'
Apr 08 11:31:08 raspberrypi systemd[1]: Started Hostname Service.
Apr 08 11:31:09 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 127 (plymouthd).
Apr 08 11:31:11 raspberrypi dphys-swapfile[205]: Starting dphys-swapfile swapfile setup ...
Apr 08 11:31:11 raspberrypi resize2fs_once[216]: Starting resize2fs_once:resize2fs 1.43.4 (31-Jan-2017)
Apr 08 11:31:11 raspberrypi kernel: EXT4-fs (mmcblk0p2): resizing filesystem from 837632 to 7779456 blocks
Apr 08 11:31:12 raspberrypi raspi-config[211]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
Apr 08 11:31:12 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Apr 08 11:31:13 raspberrypi systemd[1]: Started Raise network interfaces.
Apr 08 11:31:13 raspberrypi systemd[1]: Reached target Network.
Apr 08 11:31:13 raspberrypi systemd[1]: Starting Permit User Sessions...
Apr 08 11:31:13 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Apr 08 11:31:13 raspberrypi systemd[1]: Started Permit User Sessions.
Apr 08 11:31:13 raspberrypi systemd[1]: Starting Light Display Manager...
Apr 08 11:31:14 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Apr 08 11:31:14 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Apr 08 11:31:14 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Apr 08 11:31:15 raspberrypi dphys-swapfile[205]: want /var/swap=100MByte, generating swapfile ... of 100MBytes
Apr 08 11:31:15 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 127 (plymouthd).
Apr 08 11:31:15 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Apr 08 11:31:15 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Apr 08 11:31:15 raspberrypi kernel: Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
Apr 08 11:31:16 raspberrypi dphys-swapfile[205]: done.
Apr 08 11:31:16 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Apr 08 11:31:16 raspberrypi systemd[1]: Started Getty on tty1.
Apr 08 11:31:16 raspberrypi systemd[1]: Reached target Login Prompts.
Apr 08 11:31:23 raspberrypi kernel: EXT4-fs (mmcblk0p2): resized to 2621440 blocks
Apr 08 11:31:25 raspberrypi ssh-keygen[274]: ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
Apr 08 11:31:25 raspberrypi systemctl[403]: Removed /etc/systemd/system/multi-user.target.wants/regenerate_ssh_host_keys.service.
Apr 08 11:31:25 raspberrypi systemd[1]: Reloading.
Apr 08 11:31:27 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 38min 7.744050s random time.
Apr 08 11:31:27 raspberrypi systemd[1]: apt-daily.timer: Adding 10h 52min 17.310145s random time.
Apr 08 11:31:27 raspberrypi systemd[1]: Started Regenerate SSH host keys.
Apr 08 11:31:27 raspberrypi systemd[1]: Starting Turn on SSH if /boot/ssh is present...
Apr 08 11:31:29 raspberrypi lightdm[387]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Apr 08 11:31:30 raspberrypi systemd[1]: Started Light Display Manager.
Apr 08 11:31:30 raspberrypi lightdm[387]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
Apr 08 11:31:30 raspberrypi login[399]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Apr 08 11:31:30 raspberrypi systemd[1]: Created slice User Slice of pi.
Apr 08 11:31:30 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Apr 08 11:31:30 raspberrypi systemd-logind[224]: New session c1 of user pi.
Apr 08 11:31:31 raspberrypi systemd[1]: Started Session c1 of user pi.
Apr 08 11:31:31 raspberrypi lightdm[387]: session_get_login1_session_id: assertion 'session != NULL' failed
Apr 08 11:31:31 raspberrypi systemd[425]: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Apr 08 11:31:33 raspberrypi systemd[1]: Reloading.
Apr 08 11:31:33 raspberrypi systemd[425]: Reached target Timers.
Apr 08 11:31:33 raspberrypi systemd[425]: Listening on GnuPG cryptographic agent and passphrase cache.
Apr 08 11:31:33 raspberrypi systemd[425]: Reached target Paths.
Apr 08 11:31:33 raspberrypi systemd[425]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Apr 08 11:31:33 raspberrypi systemd[425]: Starting D-Bus User Message Bus Socket.
Apr 08 11:31:33 raspberrypi systemd[425]: Listening on GnuPG cryptographic agent (access for web browsers).
Apr 08 11:31:33 raspberrypi systemd[425]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Apr 08 11:31:34 raspberrypi systemd[425]: Listening on D-Bus User Message Bus Socket.
Apr 08 11:31:34 raspberrypi systemd[425]: Reached target Sockets.
Apr 08 11:31:34 raspberrypi systemd[425]: Reached target Basic System.
Apr 08 11:31:34 raspberrypi systemd[425]: Reached target Default.
Apr 08 11:31:34 raspberrypi systemd[425]: Startup finished in 2.890s.
Apr 08 11:31:35 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 30min 25.084509s random time.
Apr 08 11:31:35 raspberrypi systemd[1]: apt-daily.timer: Adding 59min 42.238761s random time.
Apr 08 11:31:35 raspberrypi systemd[1]: Started User Manager for UID 1000.
Apr 08 11:31:35 raspberrypi kernel: EXT4-fs (mmcblk0p2): resized to 4718592 blocks
Apr 08 11:31:36 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Apr 08 11:31:39 raspberrypi lightdm[387]: session_get_login1_session_id: assertion 'session != NULL' failed
Apr 08 11:31:39 raspberrypi sshd[464]: Server listening on 0.0.0.0 port 22.
Apr 08 11:31:39 raspberrypi sshd[464]: Server listening on :: port 22.
Apr 08 11:31:39 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Apr 08 11:31:39 raspberrypi systemd[1]: Started Turn on SSH if /boot/ssh is present.
Apr 08 11:31:46 raspberrypi kernel: EXT4-fs (mmcblk0p2): resized to 6815744 blocks
Apr 08 11:31:52 raspberrypi kernel: EXT4-fs (mmcblk0p2): resized filesystem to 7779456
Apr 08 11:31:54 raspberrypi resize2fs_once[216]: Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required
Apr 08 11:31:54 raspberrypi resize2fs_once[216]: old_desc_blocks = 1, new_desc_blocks = 2
Apr 08 11:31:54 raspberrypi resize2fs_once[216]: The filesystem on /dev/mmcblk0p2 is now 7779456 (4k) blocks long.
Apr 08 11:31:54 raspberrypi systemd[1]: Reloading.
Apr 08 11:31:56 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 56min 59.083763s random time.
Apr 08 11:31:56 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 16min 11.894405s random time.
Apr 08 11:31:56 raspberrypi systemd[1]: Reached target Multi-User System.
Apr 08 11:31:56 raspberrypi systemd[1]: Reached target Graphical Interface.
Apr 08 11:31:56 raspberrypi resize2fs_once[216]: .
Apr 08 11:31:56 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Apr 08 11:31:56 raspberrypi lightdm[507]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Apr 08 11:31:57 raspberrypi lightdm[507]: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Apr 08 11:31:57 raspberrypi systemd[1]: Started LSB: Resize the root filesystem to fill partition.
Apr 08 11:31:57 raspberrypi systemd-logind[224]: New session c2 of user pi.
Apr 08 11:31:57 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Apr 08 11:31:57 raspberrypi systemd[1]: Started Session c2 of user pi.
Apr 08 11:31:57 raspberrypi systemd[1]: Startup finished in 1.823s (kernel) + 1min 11.422s (userspace) = 1min 13.246s.
Apr 08 11:31:57 raspberrypi lightdm[387]: Error opening audit socket: Protocol not supported
Apr 08 11:31:57 raspberrypi systemd[425]: Started D-Bus User Message Bus.
Apr 08 11:32:01 raspberrypi dbus-daemon[530]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Apr 08 11:32:01 raspberrypi systemd[425]: Starting Virtual filesystem service...
Apr 08 11:32:01 raspberrypi dbus-daemon[530]: Successfully activated service 'org.gtk.vfs.Daemon'
Apr 08 11:32:01 raspberrypi systemd[425]: Started Virtual filesystem service.
Apr 08 11:32:01 raspberrypi kernel: fuse init (API version 7.26)
Apr 08 11:32:01 raspberrypi systemd[1]: Mounting FUSE Control File System...
Apr 08 11:32:02 raspberrypi systemd[1]: Mounted FUSE Control File System.
Apr 08 11:32:03 raspberrypi sudo[612]:       pi : TTY=unknown ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/piwiz
Apr 08 11:32:03 raspberrypi sudo[612]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:32:04 raspberrypi dbus[227]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Apr 08 11:32:04 raspberrypi systemd[1]: Starting Authorization Manager...
Apr 08 11:32:04 raspberrypi polkitd[625]: started daemon version 0.105 using authority implementation `local' version `0.105'
Apr 08 11:32:04 raspberrypi dbus[227]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Apr 08 11:32:04 raspberrypi systemd[1]: Started Authorization Manager.
Apr 08 11:32:04 raspberrypi polkitd(authority=local)[625]: Registered Authentication Agent for unix-session:c2 (system bus name :1.13 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Apr 08 11:32:13 raspberrypi dbus-daemon[530]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Apr 08 11:32:13 raspberrypi systemd[425]: Starting Virtual filesystem service - disk device monitor...
Apr 08 11:32:13 raspberrypi dbus[227]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Apr 08 11:32:13 raspberrypi systemd[1]: Starting Disk Manager...
Apr 08 11:32:14 raspberrypi udisksd[684]: udisks daemon version 2.1.8 starting
Apr 08 11:32:15 raspberrypi dbus[227]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Apr 08 11:32:15 raspberrypi systemd[1]: Started Disk Manager.
Apr 08 11:32:15 raspberrypi udisksd[684]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Apr 08 11:32:16 raspberrypi dbus-daemon[530]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Apr 08 11:32:16 raspberrypi systemd[425]: Started Virtual filesystem service - disk device monitor.
Apr 08 11:32:16 raspberrypi dbus-daemon[530]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Apr 08 11:32:16 raspberrypi systemd[425]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Apr 08 11:32:16 raspberrypi dbus-daemon[530]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Apr 08 11:32:16 raspberrypi systemd[425]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Apr 08 11:32:16 raspberrypi dbus-daemon[530]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Apr 08 11:32:16 raspberrypi systemd[425]: Starting Virtual filesystem service - Apple File Conduit monitor...
Apr 08 11:32:16 raspberrypi gvfs-afc-volume-monitor[703]: Volume monitor alive
Apr 08 11:32:16 raspberrypi dbus-daemon[530]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Apr 08 11:32:16 raspberrypi systemd[425]: Started Virtual filesystem service - Apple File Conduit monitor.
Apr 08 11:32:16 raspberrypi dbus-daemon[530]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Apr 08 11:32:16 raspberrypi systemd[425]: Starting Virtual filesystem service - digital camera monitor...
Apr 08 11:32:17 raspberrypi dbus-daemon[530]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Apr 08 11:32:17 raspberrypi systemd[425]: Started Virtual filesystem service - digital camera monitor.
Apr 08 11:32:17 raspberrypi dbus-daemon[530]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Apr 08 11:32:17 raspberrypi systemd[425]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Apr 08 11:32:17 raspberrypi dbus-daemon[530]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Apr 08 11:32:17 raspberrypi systemd[425]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Apr 08 11:32:40 raspberrypi passwd[903]: pam_unix(passwd:chauthtok): password changed for pi
Apr 08 11:32:43 raspberrypi dbus[227]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service'
Apr 08 11:32:43 raspberrypi systemd[1]: Starting PackageKit Daemon...
Apr 08 11:32:43 raspberrypi PackageKit[925]: daemon start
Apr 08 11:32:44 raspberrypi dbus[227]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Apr 08 11:32:44 raspberrypi systemd[1]: Started PackageKit Daemon.
Apr 08 11:32:44 raspberrypi PackageKit[925]: uid 0 is trying to obtain org.freedesktop.packagekit.system-sources-refresh auth (only_trusted:0)
Apr 08 11:32:44 raspberrypi PackageKit[925]: uid 0 obtained auth for org.freedesktop.packagekit.system-sources-refresh
Apr 08 11:33:12 raspberrypi PackageKit[925]: refresh-cache transaction /1_cdabcdbe from uid 0 finished with failed after 28227ms
Apr 08 11:33:30 raspberrypi sudo[612]: pam_unix(sudo:session): session closed for user root
Apr 08 11:34:05 raspberrypi sudo[1281]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/sbin/ifup wlan0
Apr 08 11:34:05 raspberrypi sudo[1281]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:34:06 raspberrypi sudo[1281]: pam_unix(sudo:session): session closed for user root
Apr 08 11:35:04 raspberrypi sudo[1294]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Apr 08 11:35:04 raspberrypi sudo[1294]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:36:10 raspberrypi sudo[1294]: pam_unix(sudo:session): session closed for user root
Apr 08 11:36:25 raspberrypi sudo[1316]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Apr 08 11:36:25 raspberrypi sudo[1316]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:36:34 raspberrypi sudo[1316]: pam_unix(sudo:session): session closed for user root
Apr 08 11:36:37 raspberrypi sudo[1325]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Apr 08 11:36:37 raspberrypi sudo[1325]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:36:37 raspberrypi sudo[1325]: pam_unix(sudo:session): session closed for user root
Apr 08 11:37:07 raspberrypi sudo[1334]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Apr 08 11:37:08 raspberrypi sudo[1334]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:37:08 raspberrypi sudo[1334]: pam_unix(sudo:session): session closed for user root
Apr 08 11:37:21 raspberrypi sudo[1345]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/sbin/modinfo
Apr 08 11:37:21 raspberrypi sudo[1345]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:37:21 raspberrypi sudo[1345]: pam_unix(sudo:session): session closed for user root
Apr 08 11:38:36 raspberrypi sudo[1372]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Apr 08 11:38:36 raspberrypi sudo[1372]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:38:36 raspberrypi sudo[1372]: pam_unix(sudo:session): session closed for user root
Apr 08 11:44:48 raspberrypi kernel: usb 1-1: USB disconnect, device number 2
Apr 08 11:44:52 raspberrypi kernel: Indeed it is in host mode hprt0 = 00021501
Apr 08 11:44:52 raspberrypi kernel: usb 1-1: new full-speed USB device number 3 using dwc_otg
Apr 08 11:44:52 raspberrypi kernel: usb 1-1: New USB device found, idVendor=046d, idProduct=c52b
Apr 08 11:44:52 raspberrypi kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 08 11:44:52 raspberrypi kernel: usb 1-1: Product: USB Receiver
Apr 08 11:44:52 raspberrypi kernel: usb 1-1: Manufacturer: Logitech
Apr 08 11:44:52 raspberrypi mtp-probe[1416]: checking bus 1, device 3: "/sys/devices/platform/soc/20980000.usb/usb1/1-1"
Apr 08 11:44:52 raspberrypi mtp-probe[1416]: bus: 1, device: 3 was not an MTP device
Apr 08 11:44:52 raspberrypi kernel: logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-20980000.usb-1/input2
Apr 08 11:44:53 raspberrypi kernel: input: Logitech M310 as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0005/0003:046D:1024.0006/input/input2
Apr 08 11:44:53 raspberrypi kernel: logitech-hidpp-device 0003:046D:1024.0006: input,hidraw1: USB HID v1.11 Mouse [Logitech M310] on usb-20980000.usb-1:1
Apr 08 11:44:53 raspberrypi kernel: input: Logitech K520 as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0005/0003:046D:2011.0007/input/input3
Apr 08 11:44:53 raspberrypi kernel: logitech-hidpp-device 0003:046D:2011.0007: input,hidraw2: USB HID v1.11 Keyboard [Logitech K520] on usb-20980000.usb-1:2
Apr 08 11:44:53 raspberrypi kernel: input: Logitech M505/B605 as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0005/0003:046D:101D.0008/input/input4
Apr 08 11:44:53 raspberrypi kernel: logitech-hidpp-device 0003:046D:101D.0008: input,hidraw3: USB HID v1.11 Mouse [Logitech M505/B605] on usb-20980000.usb-1:3
Apr 08 11:44:53 raspberrypi kernel: input: Logitech M705 as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0005/0003:046D:101B.0009/input/input5
Apr 08 11:44:53 raspberrypi kernel: logitech-hidpp-device 0003:046D:101B.0009: input,hidraw4: USB HID v1.11 Mouse [Logitech M705] on usb-20980000.usb-1:4
Apr 08 11:44:53 raspberrypi kernel: input: Logitech K400 as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0005/0003:046D:4024.000A/input/input6
Apr 08 11:44:53 raspberrypi kernel: logitech-hidpp-device 0003:046D:4024.000A: input,hidraw5: USB HID v1.11 Keyboard [Logitech K400] on usb-20980000.usb-1:5
Apr 08 11:44:54 raspberrypi systemd-udevd[1422]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:44:54 raspberrypi systemd-udevd[1417]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:44:54 raspberrypi systemd-udevd[1419]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:44:54 raspberrypi systemd-udevd[1423]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:44:54 raspberrypi systemd-udevd[1420]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:44:54 raspberrypi systemd-udevd[1425]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:44:54 raspberrypi systemd-udevd[1418]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:44:54 raspberrypi systemd-udevd[1424]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Apr 08 11:45:04 raspberrypi kernel: logitech-hidpp-device 0003:046D:4024.000A: HID++ 2.0 device connected.
Apr 08 11:45:50 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
Apr 08 11:45:50 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
Apr 08 11:47:04 raspberrypi sudo[1458]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/raspi-config
Apr 08 11:47:04 raspberrypi sudo[1458]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:47:12 raspberrypi sudo[1458]: pam_unix(sudo:session): session closed for user root
Apr 08 11:50:34 raspberrypi sudo[1483]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Apr 08 11:50:34 raspberrypi sudo[1483]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 11:52:50 raspberrypi sudo[1483]: pam_unix(sudo:session): session closed for user root
Apr 08 11:52:58 raspberrypi sudo[1500]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Apr 08 11:52:58 raspberrypi sudo[1500]: pam_unix(sudo:session): session opened for user root by (uid=0)
Andyroo
Wed Aug 28, 2019 4:41 pm
Can you try the following:
0) Power off and power on the access point and router you are trying to connect to - do not miss this step even if the family get annoyed :lol:
1) Create a Stretch Lite image (with ssh file if needed)
2) Boot and using either SSH or the keyboard / monitor run
sudo raspi-config
Set the host name to something different from any computer on your network (2/N1)
Set the Wifi details (2/N2)
Set the Locale and WIFI country (3/ ALL OF THEM)
Finish and reboot when prompted
Do not miss any of the Locale options even if you do not change anything
Do not change anything else
Is it a hidden SSID you are trying to connect to? These do give the Pi boards problems and do not really add anything to security!
If so you will need to
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
add
scan_ssid=1
on the line after the SSID entry INDENT it to match the lines above and below - DO NOT change anything else, do not add anything else, save the file and reboot (sudo reboot - not pull the power)
If possible turn 5Ghz off while testing :o
Can you detail what type of network you are trying to connect to (WPA / WPA2 etc) and what channel the network is on
