raspbian_beginner
Upgrade Distribution Failure
Sun Aug 04, 2019 8:03 pm
I'm very new at this. I have Raspbian (Stretch) which I attempted to upgrade as follows:
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get autoclean
Then I rebooted. On reboot all I got was a black screen with a partial window header at the top of the screen titled 'Unnamed Window'.
I cannot close the window or do anything else.
Where do I go from here?
dominic03
Re: Upgrade Distribution Failure
Sun Aug 04, 2019 10:35 pm
What model Pi?
After rebooting, did it show a Raspberry Pi logo (or multiple)?
Can you use CTRL + ALT + F1 to get to a text terminal?
Raspberry Pi 4B running Raspbian Buster v3.1 (via PINN)
Kingston 32 GB C10 (U1) microSD
Sceptre E225W 22" 75hz 1080p monitor
Flash drive for backups and swap
-or-
pi-top 3 running Raspbian with drivers and pi-topHUB 2.0 / 16GB SanDisk C10 microSD
Sun Aug 04, 2019 11:06 pm
sudo apt-get update
Raspbian Buster is the currently supported Operating System:
https://www.raspberrypi.org/downloads/raspbian/
Retired disgracefully.....
dominic03
Mon Aug 05, 2019 11:03 am
sudo apt-get update
Yes, and they are trying to upgrade to Buster from Stretch.
-or-
Mon Aug 05, 2019 11:13 am
sudo apt-get update
The OP can not upgrade from Stretch to Buster using those steps, see:
https://www.raspberrypi.org/blog/buster ... -raspbian/
B.Goode
Mon Aug 05, 2019 11:16 am
... they are trying to upgrade to Buster from Stretch.
How do you know? There is nothing in the single post from @raspbian_beginner to indicate that.
dominic03
Mon Aug 05, 2019 12:09 pm
I assumed that from this text:
True, they didn't say that is what exactly they are doing, and they may be trying to update. But that's what I initially thought.
-or-
raspbian_beginner
Mon Aug 05, 2019 1:10 pm
Hi
Thanks for everyone's comments. Yes I was trying to upgrade from Stretch to Buster. What I did do was the standard upgrade process I described. BUT what I should have done first is (see https://www.raspberrypi.org/blog/buster ... -raspbian/)
"In the files /etc/apt/sources.list and /etc/apt/sources.list.d/raspi.list, change every use of the word “stretch” to “buster”."
It doesn't look like I can reverse anything or change any files a this point so it'll be a reinstall.
Thanks again.
Mon Aug 05, 2019 1:40 pm
Hi
Thanks again.
Going from one release to another has never been recommended, especially without creating a back up first...
